Old 04-09-2014, 01:39 PM   #57
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
Originally Posted by feldy View Post
Yep it's that easy. Just did the red one this after noon. I like it.
How did you get the stock tune out I removed the clamp but I can't seem to remove the grey tune it looks like it's glued on
ProjectGT86 is offline   Reply With Quote
Old 04-09-2014, 04:35 PM   #58
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
it pulls out by hand.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-10-2014, 05:06 AM   #59
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Its just the rubber that "sticks" a bit, I did take a screwdriver and "lifted" the rubber a bit from the plastic on one side, and pulled it out afterwards. However, do it carefully, you dont want to damage the rubber.
Killerbee is offline   Reply With Quote
Old 04-11-2014, 04:14 AM   #60
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
Originally Posted by mwjcyber View Post
Today I took off my sound generator elbow referenced in this thread off my BRZ to gut it and increase the sound output. To my amazement the tube was hollow and devoid of any materials or filler.
I guess BRZ's come with a black version of the TRD red tube standard now.
Is this confirmed?
Cliu91 is offline   Reply With Quote
Old 04-11-2014, 08:30 PM   #61
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Originally Posted by Cliu91 View Post
Is this confirmed?
Negatory, it was the wrong elbow. My mistake
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 05-16-2014, 10:15 AM   #62
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
Originally Posted by livert View Post
If you only plan to remove the foam from the stock tube, you can easily expose the hole via the footwell by pulling the carpet down a bit and use a pair of tweezers to remove the yellow foam. Instant red tube in less than a minute. You don't even need to pop the hood.
Did this last night, because I'm a child and I like whooshy noises. Took all of fifteen seconds to stick some needlenose pliers in the footwell hole and pull out a clump of foam.
I figure this mod is good for at least +1.3whp.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
The Following User Says Thank You to codesplice For This Useful Post:
Chad86 (07-26-2014)
Old 05-29-2014, 10:49 PM   #63
DetroitJake
DetroitJake's Avatar
Drives: '13 FR-S 6MT / '14 Prius-C
Pricey
Ya I like noise, so I thought I'd try it.
$60 at RallySportDirect.
It adds a little bit, but not much.
The cheaper route would be to just pull the foam out of the stock tube.
Red Tube = No Foam
Green Tube = Less Foam
Stock Tube = With Foam
Blue Tube = Blocked passage (molded in wall to stop air flow).
Just FYI. The little divots on the Blue tube are just molding features to mold the wall in the blocked tube. You need that to control wall thinkness during injection molding processes.
You can see my installed red tube poking through the firewall in the passenger foot area.
DetroitJake is offline   Reply With Quote
The Following User Says Thank You to DetroitJake For This Useful Post:
jcw99 (10-04-2014)
Old 07-28-2014, 06:44 PM   #64
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
I did a drive comparison with the sound tube plugged with the AC plug and I don't know why people want to block this off.
refer to thread http://www.ft86club.com/forums/showthread.php?t=30659
I found the car sounded dead with the sound tube blocked off. I enjoy a nice growl in the cockpit and plan to remove the insides of the sound tube to increase sound satisfaction!
Chad86 is offline   Reply With Quote
Old 07-28-2014, 09:30 PM   #65
CatDaddysBBQ
Drives: '13 FR-S
I just gutted the stock one. Growls plenty and was free!
CatDaddysBBQ is offline   Reply With Quote
Old 12-03-2014, 05:35 AM   #66
Lokenzi
Drives: 2015 Blue.Series.BRZ
Just did this to mine... Vrooom
Lokenzi is offline   Reply With Quote
Old 02-19-2015, 02:29 AM   #67
Lambrzy
Lambrzy's Avatar
Drives: Subaru BRZ
oh god.. that brought in a new definition of 'cant find the hole'..
got there in the end.. covered in brown grease from the steering rack.. stuffed that hole back up in the end. it was a little fiddly with these fat fingers. sounds decent though with a k&n filter. good illusion, worth the 30 dollars
Lambrzy is offline   Reply With Quote
Old 02-19-2015, 02:31 AM   #68
WesleyG
Drives: 2014 Satin White Pearl GTS auto
not really worth the 30 dollars....gutting stock tube give same effect and is free
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Installing JDM Window Visors Calidrifter DIY (Do-It-Yourself) Guides 65 07-01-2019 12:25 AM
SARD PCD changer 5x114.3 TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-15-2012 08:34 AM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 02:08 PM
TRD sound changer! Surok Engine, Exhaust, Transmission 2 08-26-2012 10:20 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 07:12 PM
