Old 04-05-2014, 10:02 AM   #1
z3ro
Long Start
Anyone else having an issue with a long start after a period of driving?
Example:
  • Car fires up quickly in the morning after sitting for 8 to 12 hours
  • Car fires up quickly in the afternoon after sitting for ~9 hours
  • Drive to the grocery store, 5-10 minutes
  • Car sits for 15-20 minutes
  • Car cranks for a bit longer after the brief drive and sitting for <30 minutes, but ultimately fires up.
I'm not talking an obnoxious amount of cranking, but easily double when the car is cold. Also I should note it has never failed to fire up. I just think it's weird because typically a car would FTF when it's cold, not warm.
Any thoughts?
z3ro is offline   Reply With Quote
The Following User Says Thank You to z3ro For This Useful Post:
ZionsWrath (04-05-2014)
Old 04-05-2014, 10:20 AM   #2
bk201_q8
bk201_q8's Avatar
Drives: 2013 PW Toyota GT86 with body kit
Same thing happens to me, but if I enter the car and give it 5 to 10 seconds it starts up normally.
I hope that helps.
bk201_q8 is offline   Reply With Quote
The Following User Says Thank You to bk201_q8 For This Useful Post:
Old 04-05-2014, 10:21 AM   #3
sshole
Add my BRZ has having this issue. It's quite noticeable with the push start since I'm used to pushing, waiting for 2 cranks, then setting off. These longer cranks are like 4-6 cranks before the engine will cough to life.
It sounds kinda like what my older coworkers would describe as vapor lock on a carbureted car.
sshole is offline   Reply With Quote
The Following User Says Thank You to sshole For This Useful Post:
Old 04-05-2014, 10:25 AM   #4
z3ro
The only thing i can think of is if the ECU is determining whether or not to start in closed or open loop. Not sure if that's even possible, just a thought.
Old 04-05-2014, 10:45 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
I usually start when I hear fuel pump finish priming, haven't had any problems
Old 04-05-2014, 11:15 AM   #6
z3ro
I'll give that a try and see if it makes any difference.
Old 04-05-2014, 12:09 PM   #7
FRStock
Drives: 13 FRS
I usually wait and I've had it happened 3 times in the past month.
FRStock is offline   Reply With Quote
Old 04-05-2014, 12:30 PM   #8
tyrantcf
Drives: '16 WRX, CBR1000RR
This is common on motorcycles too. All of my bikes have done this to an extent. I chalk it up to heat soak, the engine is just harder to start when all the engine components are hot.
tyrantcf is offline   Reply With Quote
The Following User Says Thank You to tyrantcf For This Useful Post:
humfrz (04-05-2014)
Old 04-08-2014, 08:37 PM   #9
John86
Drives: BMW 228i TPK , 13 BRZ (LemonLawed)
I've actually had trouble recently with mine not even attempting to start. The push button will turn the car on, but it won't start it. It's happened about 5 times in the last month and a half. When it happens I've had to cycle through all the modes as many as 6-7 times and then it'll crank. I contacted the dealer and they weren't any help. I thought the key might have a weak battery, but that wasn't it, and the clutch is all the way in when I start it. I did have the High Pressure Fuel Pump replaced recently. Has anyone else experienced anything similar? I did a search, but didn't see anything.
John86 is offline   Reply With Quote
Old 04-08-2014, 08:46 PM   #10
John86
I just saw the TSB on long starts (NUMBER: 11-130-13R), so I'm guessing that must be it? A problem with the cam shaft sensor? I'm really starting to worry about this car, as this will be the 4th time I've had to bring it in for warranty work. Does anyone know if they're extending the warranties on all these TSB's? My car is just up over 30k miles and seems to be having every recall problem possible. I'm shocked by how many little things are going wrong in the first 2 years of ownership.
Old 04-08-2014, 09:44 PM   #11
mike the snake
On mine, and other cars I've owned that did this, if I armed the car and ignition, but held off on pushing the clutch in (and engaging the starter) until after I hear the fuel pump finish priming, and after the tach had finished with it's sweep.
This always helped with long cranks when really hot.
Old 04-08-2014, 10:38 PM   #12
ninedice
ninedice's Avatar
Drives: Series 10 #177 M/T
Mine did this today for the first time (999 miles). It cranked over for a good 10 seconds before firing up. I tried turning it off and back on when I got home and it wouldn't start. I'll try again in the morning.
Also, I can't find a PDF on that TSB. Is that a TSB or an SSB?
ninedice is offline   Reply With Quote
Old 04-09-2014, 12:37 PM   #13
Krispeee
I experienced the same issue about a month ago. Clutch in, pressed the start button, and took it about 7 cranks to start the engine up.
I've had previous vehicles that featured a start button and this is a first for me.
Is there a TSB for this issue?
Krispeee is offline   Reply With Quote
Old 04-09-2014, 02:13 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
TSB:
http://www.ft86club.com/forums/showp...&postcount=145
Long start up. Not weather related. Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 17 03-28-2015 06:39 AM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
How long to hold push button start. Dorb BRZ First-Gen (2012+) — General Topics 11 01-21-2013 05:57 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
