Old 03-28-2014, 02:58 PM   #85
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by imom View Post
and still think MTL is not good enough for cold weather in SOCAL. .
I really think you need to re-evaluate your definition of "cold" as it applies to cars.
Question: How much does it really take to fill the trans?
I see conflicting numbers online & in the manual.
Old 03-28-2014, 03:56 PM   #86
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Just went out to get me some Motul 300 today. Looking to change the fluid this weekend. I'm at 24000kms on the original fill. I feel kind of bad that I'm only getting around to it now. But the car sees only highway use and I haven't taken it lapping yet so all should be good.
Gonna run Redline 75w90 in the diff. I wanted to do all Motul but the shop only had two bottles of Motul left so I just grabbed a bottle of Redline for the rear.
hmong337 is offline   Reply With Quote
Old 04-04-2014, 10:01 PM   #87
imom
Drives: BRZ sold
Not as cold as where you are...but cold weather being 60F below which is mild to you...but having to wait for over 5 minutes to warm up the car and then drive another 15 to 30 minutes to have the tranny drive right is not correct for me. I suspect that the wrong oil was chosen by Subaru and so a lot of people have to deal with it. Pentosin has a 40C viscosity of 38.3...where as MTL has 54.1. A lot of metal to metal action happens because the oil doesn't get thin enough until temps are reached. I don't know what the viscosity for the stock tranny is.
imom is offline   Reply With Quote
Old 04-04-2014, 10:22 PM   #88
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
We use Gear300LS in our diff; it slightly alters the engagement characteristic of the differential.
How so? I know the oem is a lowly torsen... but, for better or for worse? Engages differently (earlier or later?), or mis-engagement.. or better more solid positive stronger more frequent/consistent engagement?
I assume drifters would feel the difference much more than a grip racer/track head.
fooddude is offline   Reply With Quote
Old 04-05-2014, 02:55 AM   #89
stugray
..but having to wait for over 5 minutes to warm up the car and then drive another 15 to 30 minutes to have the tranny drive right is not correct for me..
It sounds like you have a problem with your tranny.
I have had it below zero, and I begin driving within a minute of starting the car.
The tranny is a bit stiff at first, but it is back to normal within a few miles of driving.
And I believe I have the stock trans fluid at 16k miles.
Old 04-06-2014, 02:00 PM   #90
fooddude
Quickie Q:
How many quarts/liters to flush the trans? ..and diff?
And, also would like to know the frequency/time between flushes? ..recommended frequency for both a DD car, and also an occasional track car? (I am guessing it isn't as frequent as brake fluid flushes)
Want to go Motul
Old 04-06-2014, 03:14 PM   #91
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by fooddude View Post
Quickie Q:
Want to go Motul
Manual trans is 2.3 qt, and rear end is 1.2 qt.
I've experimented a bit with fluids, and now that I've found what I like, I will be changing them once a year in the spring. My car is a daily driver that sees little to no track time. I'm using Pentosin in the transmission and Redline 75W85 GL-5 gear oil in the differential. If you plan on track time, you may want something a little more robust in there.
The Following User Says Thank You to roddy For This Useful Post:
fooddude (04-07-2014)
Old 04-07-2014, 01:02 PM   #92
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Hey guys, are the tranny fluids (redline, motul) something you can get at your local auto parts store?
Old 04-07-2014, 07:18 PM   #93
Griever423
Drives: 2020 BRZ PP
Originally Posted by JS + BRZ View Post
What do you track junkie guys use for your transmission and differential fluid?
Pretty much all of the track guys both casual/weekend warrior and serious track cars are using Motul Gear 300 and 300v for the oil.
Griever423 is offline   Reply With Quote
Old 04-07-2014, 07:28 PM   #94
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Exclamation
300v in The motor is a race oil. It is NOT meant to stay in the car more than a weekend. So if you street drive your car DO NOT use this engine oil.
We had a long conversation at PRI (Motorsports industry show) this year with Motul and they have us all the explainations of their fluids etc.
Mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
continuecrushing (04-07-2014)
Old 04-07-2014, 10:50 PM   #95
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Mike
This is insanely important, and I feel like many people are clueless about it.
They think that, oh, this race team uses it, or this is meant for race cars so this must be great for my daily driver! When in reality it is frequently more important to make an extra few horse power, or be a little bit faster in a "race car" because long term durability/reliability is not as important. And that's what most people misunderstand.
But oh well, becauseracecar, right lol?
Old 04-08-2014, 01:33 AM   #96
fooddude
Is 300 trans fluid alright for DD and has the same longevity as standard/normal trans fluid?
Old 04-08-2014, 05:30 AM   #97
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Ya lost me at fluid makes diff engage different
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-08-2014, 09:22 AM   #98
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
When I was at Napa Auto Parts I bought some AMSOIL Gear Oil for my transmission. Paid about $13.00/qt and seems to be running great with my build.
shiro is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) Neurytic Cars for Sale/Trade 3 05-22-2013 11:54 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA ysagisan Cars for Sale/Trade 0 09-19-2012 11:24 AM
Got a line on two unclaimed BRZs (manual trans) Tainen BRZ First-Gen (2012+) — General Topics 0 07-05-2012 10:40 PM
