Old 03-31-2014, 03:19 AM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by glamcem View Post
Ok , so as I understand I can use OEM camber bolts for upper hole and SPC camber bolt for the bottom so that should get me ~-2.0 negative camber for front. What kind of camber adjustment and number I can get for the rear @solidONE?
Thanks again
How do you know this ?
With the OE crash bolt and the SPC lower camber bolt, I doubt you will get -2.0. Maybe -1.8 if you are lucky.
H&R TC112 or TC212. either one will work. The TC112 has a longer cam, so they're presumably stronger. I ordered the TC112 and received one of each in the package... The adjustment range is less than +- 0.5* when mounted on the inner rear lower control arm mount.
The Following User Says Thank You to solidONE For This Useful Post:
glamcem (03-31-2014)
Old 03-31-2014, 06:49 PM   #30
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thanks again
Im installing this setup this weekend and will get an alignment next week I'll will report back what i can get out of it.
Sent from my LT30at using Tapatalk
Old 03-31-2014, 07:16 PM   #31
Krispeee
couldn't you run the bottom bolt up top (in place of OEM camber bolt) and run spc camber bolts on the bottom? My fronts are set up this way and it looks like I got some additional negative camber from doing so, but no alignment yet to validate my claims.
Krispeee is offline   Reply With Quote
The Following User Says Thank You to Krispeee For This Useful Post:
solidONE (04-01-2014)
Old 03-31-2014, 10:34 PM   #32
solidONE
solidONE's Avatar
Just a side note on alignment. I just installed a track pipe and my rear toe went from 1/8" toe in to slightly toe out. I went to Sears for a free alignment check to confirm my numbers and my toe changed unexpectedly. Only thing I did was remover the factory muffler and install a track pipe I just fabbed up. Also my front toe went from slightly toe out to slightly toe in when they redid the alignment check after I got out of the car.
Lesson: Do your alignment fully weighted(or unweighted) to get accurate 'fight' alignment numbers.
Also my rear camber is lopsided.
Old 03-31-2014, 10:38 PM   #33
solidONE
solidONE's Avatar
Friggin eh man... Got to redo my alignment with my spare and jack out the trunk and a 150lbs ballast on the seat.
Old 03-31-2014, 11:48 PM   #34
Wepeel
Drives: '13 BRZ Ltd
Hmm.. that sounds peculiar - I wouldn't think a net ~25 lb reduction in the rear would change rear toe that much. The difference between a full tank and the fuel light on is probably a 70 lb swing. How did you verify?
(I've always wondered about laser alignment racks - I get they are accurate but it's completely dependent on the operator. I've talked to people who have done the alignment, removed the wheel laser bracket thingies, put them back on, and it read quite differently)
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Old 04-01-2014, 12:57 AM   #35
solidONE
solidONE's Avatar
Verified by Sears laser alignment. Maybe you're right. I will try to take it to another sears before I make any changes and get another alignment check.
My front toe was at 0 when I manually checked it without ballast. Rear camber was lop sided about the same amount every time. I did that purposely because I did not want to give up any negative camber just to even it out. There is a 0.5* difference left to right from the factory.
Old 04-01-2014, 01:18 AM   #36
solidONE
solidONE's Avatar
Exactamundo! The OE 'crash bolt' is simply the OE bottom bolt. so just buy the SPC camber bolt to replace the lower one and save some cashish.
Old 04-01-2014, 01:41 AM   #37
finch1750
finch1750's Avatar
I must have heard you talking about it at a meet and thats where I got the idea, cuz thats what I did. Lol
Old 04-01-2014, 03:55 AM   #38
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
FYI, I've had so many bad experiences with Sears alignment and so-called professional Corvette shops (was going sideways at drag strip once because of the incorrect toe!!) Then I started using a Firestone shop.. I would highly advise you to make a friend there
BTW, I have ordered my FA 500 series coilovers with Swift spring (9k/9k), radial bearing and extenders upgrades so hopefully passing -2.5_-3 camber won't be a problem once I install them
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Old 04-01-2014, 04:26 AM   #39
acx23
Drives: 2013 FRS (Silver)
If the top of the camber bolt (the dial part) isn't facing/pointing toward the front of the car, then it's on backwards.
For your reference, I'm on stock springs/height with proper camber bolts on the bottom strut slot, and I got -1.2* out of it.
Originally Posted by leicaboss View Post
FYI, I bought SPC camber bolts thinking I could achieve the advertised -1.75 camber.
Instead I was maxed out on -0.3 on the driver side, meaning I had to do the same on the passenger side to stay even. I'm lowered on Swift BRZ springs, stock struts, and only one set of those bolts.
acx23 is offline   Reply With Quote
Old 04-01-2014, 07:53 AM   #40
sshole
Originally Posted by ayau View Post
The bottom bolt IS the crash bolt.
I didn't know that. Looks like I need to make an appointment with my alignment guy.
sshole is offline   Reply With Quote
Old 04-01-2014, 08:45 AM   #41
bfrank1972
Drives: 2013 FR-S Argento
I bought a set of TC112's end of last year and getting ready to install them now that the weather is better up here - did you have to modify them to fit? I.e. grind down some threads - I've read mixed reports on this. Thx
Sent from my QMV7A using Tapatalk
Old 04-01-2014, 12:19 PM   #42
solidONE
solidONE's Avatar
Nope. TC112 are the longer ones and will not require modification. TC212 may have a couple threads caught on the subframe, but i didnt mod it and it still works fine.
bfrank1972 (04-01-2014)
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Cheapest way to get more camber on stock suspension Snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-11-2014 08:45 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 04:45 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
