Old 03-28-2014, 12:35 AM   #57
varun
Drives: 2013 FRS
Any1?
varun is offline   Reply With Quote
Old 03-28-2014, 02:08 AM   #58
shattered_memory
Drives: Satin White BRZ Limited
Originally Posted by varun View Post
I have a problem with my new setup
Some told me this will be tight, and most told me this wont rub, hence I went with:
SSR 18x8.5 49+ offset
Toyo R1R 245/40/18 (should have gotten 245/35)
I went with this size as I really wanted the sticky Toyos, and a taller sidewall is nice as it protects the wheels from damage or bends. This is a track setup I'm going for.
The car is sitting fairly low on KW clubsports and IT RUBS at full lock. Went over some bumps and its not hitting the wheel well.
If I raise it, will it prevent some of that rubing at full lock? I cannot return the tires, so what are my options at this point?
From all of the research I have done on this forum on wheels/offset, I believe your offset is 1mm higher than OEM spec. Not to mention that your wheels are 1.5 inches wider than stock, which makes it closer to the suspension. I think the best solution is for you to try 5mm hubcentric wheel spacers and see what happens.
shattered_memory is offline   Reply With Quote
Old 04-14-2014, 01:46 PM   #59
varun
Drives: 2013 FRS
Great, thanks for the tip, i'll try a 5mm wheel spacer. I'm guesising I need four, all around yes? Any suggestions on where I can find a good quality one? Tirerack doesnt seem to carry them, and what bolt pattern am I looking for?
Old 04-14-2014, 02:29 PM   #60
CSG David
CSG David's Avatar
+49 is really inboard. Get a 10mm spacer and find some 245/35 tires. HMU if you need spacers.
Who did you purchase all your parts from? That kind of sucks if they didn't offer any type of help with your setup.
Old 04-14-2014, 04:21 PM   #61
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
18x10.5 +20
CSG David (04-14-2014)
Old 04-14-2014, 04:27 PM   #62
CSG David
CSG David's Avatar
18x10.5 +20
If people really want, I would get some extra wide fenders made to run 12s...but yea...unnecessary...LOL
Old 05-01-2014, 01:44 PM   #63
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
Whiteout frs
17 x 9
40 offset
velvet blue or velvet red
tires: 255 45
dunnr is offline   Reply With Quote
Old 05-21-2014, 12:02 AM   #64
ZionsWrath
Thanks
ZionsWrath's Avatar
Please respond
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
235/40/18 on 8.5 rim width, all around. recommended offset? terenshu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-05-2013 10:27 AM
Need Opinions on Wheel Offset (+35 or +15) for Flush Fitment Dustin2JZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-30-2013 08:33 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
