Old 03-27-2014, 07:41 PM   #15
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Originally Posted by cjsporl1996 View Post
Ok so you saying a 255/35/18 would be ideal for my wheel? How much negative camber should I run for improved handling?
I guess it also depends on if you're going to track your car. I'm running -1.2 in front and -1.5 in back for my daily driver and it's been great handling wise. It feels definitely much better than stock.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline
Old 03-27-2014, 07:55 PM   #16
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Originally Posted by djdnz View Post
255/35/18 at least. 245 is stretched on a 9.5.
If you want traction, 255 or 265 is what you want.
245 is perfectly fine, but it's just not as fit as 255
I went with 255. Some went with 225 on 9.5! =="
hanabie is offline
Old 03-27-2014, 08:56 PM   #17
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Ok, I was just wondering if 255 was going to feel weird and try to follow the road. I'm going with a 245 plus a 5mm spacer.
cjsporl1996 is offline
Old 03-27-2014, 08:59 PM   #18
hanabie
hanabie's Avatar
Lol no.. Id go without 5mm spacer. Also, you dont look like a pro driver. Either 245 or 255 wont make any diff for u. The only thing that bothers u is ur brain.
Sent from my SGH-T999 using Tapatalk
hanabie is offline
Old 03-27-2014, 11:23 PM   #19
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
245/40/18's on 18x9.5, it's not exactly stretched, but it's not perfectly square, also depends on tire brand.
MPI_Jack is offline
Old 03-29-2014, 09:48 PM   #20
mothespaceman
mothespaceman's Avatar
Drives: 2014 BRZ SWP
Sweet looking set up!
Did you need to add some additional negative camber in the front to eliminate any weird poke?
mothespaceman is offline
Old 03-29-2014, 09:51 PM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
My 255 Continental DWS looks like that 245, so brand matters
It is poking in the front
ZionsWrath is offline
Old 03-29-2014, 10:05 PM   #22
mothespaceman
I do see that, a bit. I test fit my 18x9.5s on stock ride height and it looked a bit extreme in the poke region.
I'm in a mental coilover debate, and trying to see if once it's lowered, that added camber is enough, or if I need to specifically add MORE camber with plates / bolts in the front.
Old 03-30-2014, 12:11 AM   #23
MPI_Jack
I did camber it in up front to the max the coilover slot had. It barely pokes out. Top of the tires is still under the fender.
MPI_Jack is offline
Old 03-31-2014, 10:52 PM   #24
mothespaceman
Thanks man! That helps. So, in the event of getting adjustable top hats, it basically goes towards its negative most setting?
Old 04-10-2014, 12:56 PM   #25
cjsporl1996
Ok, I am down to 3 wheels and i can't decide which one I like better. If you would list your opinions please.
These wheels will be on a WRB BRZ and they will be chrome when I order them
1.) Rota Torque
2.) Rota Grid
3. Enkai RPF1 SBC
Old 04-10-2014, 07:37 PM   #26
cjsporl1996
Bump
Old 04-10-2014, 10:46 PM   #27
Bigmaxy
Drives: Pegasus GTS86
I'm running 245/40-18's on 9.5. Best thing for me is that it made the digital speedo accurate finally.
Bigmaxy is offline
Old 04-11-2014, 01:03 AM   #28
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Here is a 245/45 on a 17x8. I think 245 on a 9.5 isn't wide enough, but I'm always a fan of a tire meeting the edge of the wheel.
Also of note: Im running an E85 Stg 2 NA tune with an intake and the 245 DII's are just the right amount of grip. I can stick or break free depending on how I feel like driving. With a SC kit a 245 wouldn't be enough tire IMO.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline
enkai, tire advice
Square Tires on Staggered Setup OjiGeorge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-10-2014 10:31 AM
Which square or staggered setup should I go with? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 01-07-2014 12:51 PM
Square vs staggered setup slowbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-11-2013 11:18 PM
Rays 57 Xtreme - 18x9.5 +40 - Square setup No Limit Motorsport Wheels and Tires 16 01-21-2013 03:59 PM
Square Setup w/ Rear Spacers thejevans Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-11-2013 05:53 PM
