Old 03-26-2014, 07:58 PM   #1
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
245 square setup... Need advice
Looking at getting a 245/40/18 tires on a 9.5 wheel. Just wondering if that is the best way to go to improve traction and handling. With the vortech kit on a 3.125 pulley I would assume the wide tires are suitable for the application. Probably going with the direzza z2 for tires and enkai raijin for wheels.
cjsporl1996 is offline
Old 03-26-2014, 08:14 PM   #2
djdnz
1337
Drives: 2013 BRZ WRB S/C
255/35/18 at least. 245 is stretched on a 9.5.
If you want traction, 255 or 265 is what you want.
djdnz is offline
Old 03-26-2014, 08:18 PM   #3
rainmonkey
Drives: BRZ - Dark Grey
don't you already have a similar thread running? I believe CSG Mike is helping out plenty there...
rainmonkey is offline
Old 03-26-2014, 08:21 PM   #4
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
245 is good for 9.0 or 8.5
adprokid is offline
Old 03-26-2014, 09:05 PM   #5
cjsporl1996
So 245 front with 255 in the rear?
Old 03-26-2014, 09:14 PM   #6
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
I second going with 255s on 18x9.5 square. My offset was 40mm. No rubbing issues while turning lock to lock. I'm also on Stance Coil overs.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline
Old 03-26-2014, 09:31 PM   #7
cjsporl1996
Attachment 72093
seems like you see some poke on 255 with the 18x9.5 maybe a 10 would be better?
Old 03-26-2014, 09:33 PM   #8
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Even if you run 245, go 245/35R18 instead of 245/40R18.
If I were you, I would run 255/35 on 9.5 rims.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline
Old 03-26-2014, 09:34 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because 1 thread isn't enough to answer his question. It needs 2 side by side, real time updates.
-alex
mav1178 is offline
Old 03-27-2014, 01:04 AM   #10
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
running 255/35/18 on 18x9.5 +40 no rubbing issues. this is with -2 camber all around though from my previous setup on 17s. What is you reason for wanting 245? it seems like you really want to run it that way..
Build Thread
Instagram
midnight23 is offline
Old 03-27-2014, 09:46 AM   #11
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
At 25.7", the ZII in 245/40-18 is 1.0" taller than OEM; you may have rubbing issues.
The tread width of 9.5" matches your wheel width; this is good. For handling, the rule of thumb is that the tire's tread width be +/- 1.0" of the wheel width. A wheel width greater than the tread width will generally favor handling. Wide tires on narrow wheels are to be avoided if handling is your priority.
The 9.5" tread width of the ZII is more than sufficient for your power; it's not too much and it's not too little.
dradernh is offline
Old 03-27-2014, 02:01 PM   #12
cjsporl1996
Ok so you saying a 255/35/18 would be ideal for my wheel? How much negative camber should I run for improved handling?
Old 03-27-2014, 05:19 PM   #13
dradernh
In the ZII, that would probably be a better tire for you to run as it's only 0.3" taller than the OEM tire, and its tread width of 9.6" maps well to your wheel width of 9.5". As an aside, does it make you wonder how it is that a 245 Dunlop ZII has a tread width of 9.5", and the same tire in 255 has a tread width of 9.6"?
I have no idea what camber you should run; use tire temperatures to guide you on that - after you use Mike's guidance on initial camber settings.
dradernh is offline
Old 03-27-2014, 06:39 PM   #14
cjsporl1996
Does it matter between 9.6 and 9.5. I'm thinking of actually going with a 235 upfront with 255 in the rear due to the tires following the groove of the wheels.
Not sure if that messes with the tread width.
enkai, tire advice
Square Tires on Staggered Setup OjiGeorge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-10-2014 09:31 AM
Which square or staggered setup should I go with? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 01-07-2014 11:51 AM
Square vs staggered setup slowbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-11-2013 10:18 PM
Rays 57 Xtreme - 18x9.5 +40 - Square setup No Limit Motorsport Wheels and Tires 16 01-21-2013 02:59 PM
Square Setup w/ Rear Spacers thejevans Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-11-2013 04:53 PM
