Old 05-11-2013, 12:36 PM   #1
slowbrz
Drives: '13 black BRZ MT
Square vs staggered setup
I have three choices:
Square 17x8
Square 17x9
Staggered 17x8/17x9
Which setup should I go with? They will be TC105n and I will not be boosting my car
slowbrz is offline   Reply With Quote
Old 05-11-2013, 01:00 PM   #2
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
well what are you doing with the car?
daily?
show car?
spirited driving?
autocross?
circuit?
what kind of tires?
dori. is offline   Reply With Quote
Old 05-11-2013, 01:05 PM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
square 17x9 +35 has a little poke up front on stock suspension/mild drops, if you aren't boosting or lowering i'd say 17x8 square.
JoeBoxer is offline   Reply With Quote
Old 05-11-2013, 02:26 PM   #4
fatoni
17x9 is going to be the fastest in just about every circumstance.
Old 05-11-2013, 03:45 PM   #5
slowbrz
daily?
show car?
spirited driving?
autocross?
circuit?
what kind of tires?
it will be mostly for daily driving but spirited driving on the weekend. But I also want it to look a bit aggressive.
Im dropped on eibach prokits... 1" all around
I thought the car didnt output enough power to warrant 17x9. I can see the advantages for braking though
Old 05-11-2013, 04:37 PM   #6
fatoni
i think thats a way of thinking from when tire compounds were they way that they are now. it takes more to heat up a wider tire but compounds now are so much better that its easier to be at its optimal temps.
then again, its just a guess based off of what happens on miatas. a 15x9 is faster than a 15x8 and thats with 100 hp on a car that is even more sensitive to unsprung weight.
Old 05-11-2013, 05:04 PM   #7
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
17x9 +42 square with a 1" drop is delicious. Better than a Blumpkin, even.
Starscream15 is offline   Reply With Quote
Old 05-11-2013, 05:21 PM   #8
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
All are good options and since you aren't doing time attack or something and trying to get that last .01 seconds. I went staggered because I like the fitment of the 17x9 +35 in the rear but pokes a little much for my taste up front. Not to mention really throws a lot of road debris on your door and rocker from the offset. So for me the 17x8 was a better option up front.
kask2_6.0 is offline   Reply With Quote
Old 05-11-2013, 05:45 PM   #9
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
staggered 17x8/9F and 17x9/10R or somewhere like that. Thats what i would go with. Good luck. Besides, the staggered look, looks a hell of a lot better on a sports car IMHO.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 05-11-2013, 09:28 PM   #10
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
I was originally toying with the idea of going staggered, but after reading about all the ECU interference and the ice mode, I decided against it! Why? Because staggered "tires" have different circumferences, and having different circumferences means that your ECU is detecting slight slipping between front and rear. So when you are skidding around, it just kicks in and trigger ECU control of the car that much earlier. Also traction control input won't be quite right.
For tracking the car, I went with 17x8, because I think 245 is too much and rubs Hp, so no need to go bigger than 8, but with 8 you can fit 225 or 235's.
My last track car with about 60 more Hp and about 400 pounds more weight was nicely happy on the track with 225's and the right suspension set up.
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 05-11-2013, 10:18 PM   #11
mrk1
Drives: Sterling BRZ Ltd
I love square. My M3 had staggered from the factory, now run a 265 square setup and its amazing. Whenever the stock brz rubber wears out i will go to a 225 square.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Staggered or Square? tdoggy57 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-26-2014 07:55 AM
Staggered wheels + square tyre setup? white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-18-2013 09:27 AM
Wheel Directory: WedsSport TC105N 17x8.0 +42 / 17x9.0 +35 hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 03-08-2013 12:10 PM
Staggered vs. Square WWEVOX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-12-2013 03:57 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 09:40 PM
