Old 05-11-2013, 08:23 AM   #57
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
Originally Posted by sierra View Post
Just detonation!!! Detonation is what melts pistons.
If you can hear it then it's outside the range of the knock sensors because they will detect it and adjust before you can hear it.
I'm surprised that 95RON made it pre-ignite because the book does say it can be used if 85 is unavailable but 98+ is what it's tuned for. 98 RON only on the filler cap, so I don't know how they can sell it in US states with only 91AKI available?
Be careful using octane booster. I think it can damage the catalytic converters?
Yeah detonation melts pistons only if its detonating for a extended period of time, say for a hr or so. I am also equally surprised it detonates at only 95RON. But the general consensus is if you fill up with 95RON, dont redline it at every stop light haha!
CSI:86 is offline   Reply With Quote
Old 05-11-2013, 08:42 AM   #58
JimLill
Drives: 2013 Subaru BRZ-L
http://www.racegas.com/fuelfinder might help
detonation can also hammer rod bearings
JimLill is offline   Reply With Quote
Old 05-11-2013, 09:20 AM   #59
CSI:86
86 = First New Car
Detonation also damages your cylinder head, damages your pistons, mix your fuel system with your engine oil etc etc etc
Thankfully i didnt redline when i heard it pinging for less than 5 mins, until i pulled over into a BP station and filled her up with some good lovely BP ultimate
Old 05-11-2013, 09:42 AM   #60
Ryeong86
Ryeong86's Avatar
Drives: 2015 Sti Launch Edition
Originally Posted by BunnyRZed View Post
In modern cars we have octane & knock sensors that can retard the timing in order to compensate for lower octane fuels. You'll lose a little performance but nothing to worry about. Just pump the correct octane next time you pump gas.
You know most dealers do not fill up the tank with premium. For normal driving, I use 87 octane and haven't heard any pinging or any problems with my car. On auto x days or when gas prices are down, I do use 92 octane from Wawa. I never let my tank go lower than 1/4 and I usually switch on and off on 92 octane to 87.
\/Invidia N1 Titanium Tip Catback\/Rexspeed Carbon Fiber Front Lip\/Koni Sport Yellows\/Stivo Ducktail Lip Spoiler\/Porterfield Carbon Kevlar Front Pads\/TSW Nurburgrings 17x8 wrapped in 235/40/17 Nitto NT-05\/[/I]
Ryeong86 is offline   Reply With Quote
Old 05-11-2013, 10:13 AM   #61
sierra
Drives: Skoda Yeti DSG diesel 4x4
Remind me not to buy a used car from you!
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
SirBrass (03-27-2014)
Old 05-11-2013, 12:29 PM   #62
CSI:86
86 = First New Car
Woah! I always use 98RON/93AKI no matter what! It gives better mileage and better performance. I always fill up at 1/4 tank to 3/4 tank or full tank. But please always fill up with premium, never settle for anything worse
Old 05-11-2013, 02:03 PM   #63
Ryeong86
Ryeong86's Avatar
I wasn't planning on selling it.
Old 05-11-2013, 02:05 PM   #64
Ryeong86
Ryeong86's Avatar
That's I am averaging 34-37 MPG on the highway and with city driving mixed in, I have an average fuel economy of 29-32mpg :/
Old 05-11-2013, 02:16 PM   #65
DarkSunrise
DarkSunrise's Avatar
If you're absolutely determined to use 87 in this car, don't keep switching between 87 and 92. Let the ECU adjust to 87 and leave it at that.
If you keep switching, you'll get detonation when the ECU is adjusting down from 92 to 87.
2022 BRZ Build
2013 FR-S Build
Old 05-12-2013, 09:23 AM   #66
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Originally Posted by Richard Cranium View Post
So what say you to the people in the Midwest that only have access to 91? 93 pumps are *extremely* rare in Nebraska and Iowa and most of the ones that are 93 are E10.
Most, if not all gas stations in the northeast only have E10 gas for 87-93.
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 05-12-2013, 11:00 AM   #67
FRiSson
Drives: FR-S MT
On a car that is designed to run on premium, and that specifies its exclusive use, using low-octane is foolish. You are forcing the engine to de-tune itself and run less efficiently. In addition, not all "pinging", as opposed to "detonation" is audible, so you are likely causing damage to your engine before it can respond to the problem.
FRiSson is offline   Reply With Quote
Old 05-12-2013, 11:32 AM   #68
CSI:86
86 = First New Car
I agree. buts it weird that i pinged on 95RON/91. Maybe it was because i redlined every single traffic light. Has anyone else had issues with 91 in their car, and redllining it frequently?
Old 05-12-2013, 12:45 PM   #69
jsqui28
FR-S Enthusiast
Drives: FRS 6MT
First of all put octance boost in your car if you havent already. then slap your dad. finally it should not have hurt the car at all. you can always change the fuel in a car if need be. but the A/f ratio was designed to run on 91+ The worst it will do is give you poor gas mileage and it might foul up the spark plugs. you will lose a little power. I would suggest not doing it again.
jsqui28 is offline   Reply With Quote
Old 03-27-2014, 11:56 AM   #70
J_kennington
Drives: 2013 asphalt scion FRS
93+ is the recommended octane rating in the US.
91 can be used when it's not available, without detriment but it's going to lose power and can't be good long term because it's designed to run on 93 octane or higher.
87 would void the warranty and almost certainly cause engine damage.
I guess I'm screwed, since in the south we only have 91. However, 91 is perfectly fine for the car. Will not cause issues, will not cause less power. It's still a very high octane fuel.
87 is not gonna void the warranty, and honestly doubt would cause any damage. Remember, cars are a lot smarter than you think.
J_kennington is offline   Reply With Quote
Downforce: you're doing it wrong. ATL BRZ Cosmetic Modification (Interior/Exterior/Lighting) 28 04-12-2013 01:31 AM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 07:36 PM
am I doing something wrong? shiud Scion FR-S / Toyota 86 GT86 General Forum 20 07-17-2012 05:21 PM
Was I in the wrong? D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 18 06-15-2012 01:46 AM
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 06:08 PM
