Old 03-23-2014, 12:08 PM   #2241
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by JoCruz89 View Post
This is all overwhelming/confusing to me. There are so many different routes to take. I'm new to owning a FR-S, and modding in general. From what I've gathered a 9" wide wheel is an underpowered car? I want "flush" wheels but not the cost of performance. I hate how the OEM's are tucked inside of the wheel wells? I see so many people running so many different H/W/O's, to the point that I don't know which route to go. I want an 18, Pretty flush with the fender, I don't want to make fender mods, and want a wheel wider that the 7" factory. Also, I plan on adding Eibach Sportline within the next week until funds are sufficient for coilovers. Has anyone done a similar setup? Or can anyone help me?
Thanks
JoCruz
Easy, 18x8 with an offset around +35 (+32 to +40). Put a 225/40R18 on and call it a day.
+32
http://www.ft86club.com/forums/showthread.php?t=25207
+35
http://www.ft86club.com/forums/showthread.php?t=11393
+40
http://www.ft86club.com/forums/showthread.php?t=24155
Slick is offline   Reply With Quote
Old 03-23-2014, 12:18 PM   #2242
JoCruz89
Originally Posted by Slick View Post
Thank you sir... I'm really liking the +32. Is there any way to give good reputation to someone on here? If so, I can't find it lol
JoCruz89 is offline   Reply With Quote
Old 03-23-2014, 02:05 PM   #2243
Gps360
Drives: 2003 FR-S
See post above yours...
Unless he has an FR-S, I wouldn't worry what he thinks. That's why you're on the forum, for FR-S specific advice right?
Yes, the sales guy is based on the specifications from tirerack for the suggestions.
I google searched 18x8 front with 225 tires and 18x9.5 rear with 255 tires, it seemed the fitments are okay. The front wheels look like just tug in about a few mm behind the fender instead of popping out. I know if the wheels pop out a few mm beneath the fender, it may has a chance that the debris on the road picked up by the wheels and scratched the paint.
Is 0.5 really make a big difference? I can finalize my order tomorrow.
Thanks.
Gps360 is offline   Reply With Quote
Old 03-23-2014, 02:24 PM   #2244
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
17x8 +48 on 215/45/17 tires on stock suspension ?
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-24-2014, 12:47 AM   #2245
drift94
Drives: 2013 scion frs whiteout
Dropping on coilovers or lowering springs? That's the first question to answer before any others.
Tire size for a 9.5" wide rim is 245/35-265/35. Above answer will determine what makes most sense for you.
coilovers definitely
drift94 is offline   Reply With Quote
Old 03-24-2014, 06:53 AM   #2246
Slick
Slick's Avatar
Thanks.
Not saying they don't know what they're doing at all, just that tire shops including Tirerack will give you conservative options, like for Mom that wants a nicer set of wheels for her Accord.
All you need to do is look through the sticky'd wheel gallery in this forum and look for the sizes you want and click on their link for fitment details.
Good luck.
Old 03-24-2014, 07:39 AM   #2247
jshadeck
jshadeck's Avatar
Tirerack isnt ALWAYS conservative..
My is300 with "tire rack approved" sizing 19x8 +38 no fender work
jshadeck is offline   Reply With Quote
Old 03-24-2014, 09:00 AM   #2248
Gps360
Drives: 2003 FR-S
Good luck.
Okay, the wheel store guy emailed me this morning, he told me that the 18 x 8 for the fronts with offset ET35 instead of ET45. Is this okay? The front wheels with this setup will be lighter as well.
In summary, the front will be 18x8 ET35 with 225 tires, and the rear will be 18x9.5 ET45 with 255 tires.
I am going to pay the deposit today if this setup okay? Please advise, thanks.
Regarding the wheel lugs, I did some researches this weekend, it looks like Rays lugs are good. However, should I pick 35mm or 50mm long lugs?
Are Rays lugs made in China?
Old 03-24-2014, 09:30 AM   #2249
Slick
Slick's Avatar
Attachment 71697
And, is that aggressive? How is that relevant?
TireRack will tell you that a 18x9+35 in the front doesn't fit, even though we all know here that it does. The lowest offset they offer is around +40 on 8.5" and 9-9.5" wide wheels are only available for the rear.
My point is the OP came here to get advice on FRS-specific wheel fitment, which we know works since many other members have the same combo, yet is getting told that it won't fit.
Its really up to the OP to decide what he wants to do and who he chooses to believe.
Old 03-24-2014, 11:41 AM   #2250
jshadeck
jshadeck's Avatar
My point was clearly stated in my first sentence
Old 03-24-2014, 11:52 AM   #2251
Gps360
Drives: 2003 FR-S
You know what? I will go to the route based on all the pictures that I see and suggestions in this forum. Period.
Thanks for all the advises, guys.
Old 03-24-2014, 04:54 PM   #2252
Young_makaveli
Drives: 2013 frs
Hi guys I'm purchasing enkei rpf1 rims and I was wondering if 17x8 +45 would fit perfect with 215/45/ 17 tires on stock suspension?
Would the rims poke out a bit or sit flush? Thanks
Old 03-24-2014, 05:19 PM   #2253
Slick
Slick's Avatar
No issues, see here.
http://www.ft86club.com/forums/showthread.php?t=10257
Old 03-24-2014, 05:46 PM   #2254
Young_makaveli
Drives: 2013 frs
Thanks a lot
Hopefully nothing rubs
I'll switch to 225/45 once I burn thru the 215/45
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
