go_a_way1
Old 03-19-2014, 12:35 PM   #2213
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Hoping to get some good feedback here...First time buying aftermarket wheels
I think I've finally decided on a wheel...TSW Interlagos...Leaning towards 18" for the added sex...So 18x8 ET35 is what I'm currently thinking
http://www.1010tires.com/Wheels/TSW/Interlagos+RF/Painted/Matte+Black
Currently on stock suspension...Might get some coilovers in the future
I also think I've landed on Michelin Pilot Super Sports Tires as I've heard they are good grip for improved handling as a DD with good tread life and still a litttttle bit of slip/play for those fun corners..exactly what I'm looking for (if you have a better suggestion please let me know!)
So my questions...
- What tire specs would be best to keep overall area the same? 225/40/18? 245/35/18?
- Will this all fit on stock suspension? What about a 1" drop?
- Do I need any special hardware for the wheels? Hub ring, lug nuts, etc.?
Keeping in mind my overall goal is a fun DD with good tread life, better handling than stock and keeping the speedo as close to 0% off as possible...While keeping in mind that a 1" drop could be coming down the line.
Thanks!!
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 03-19-2014, 01:02 PM   #2214
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
So my questions...
Thanks!!
You could go with either size although the 225/40R18 is a better fit for the 8", the 245 can work too (range is 8-9.5" rim). Will all fit well on stock suspension or lowered with either tire. You will likely need tuner lugnuts and hubcentric rings.
Good choice of wheel, I like the look.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
tiz22 (03-19-2014)
Old 03-19-2014, 01:04 PM   #2215
Slick
Slick's Avatar
Originally Posted by Tainen View Post
OK. more background... 80% track car. Not looking to set lap records, just a fun predictable drive on the track. So tire size is not 100% the most important factor, but I'd like something that's not too heavy, not looks focused, etc. So I'd probably be okay with 225s, and I see the 17x7.5"s available in the right color I'm interested in. So maybe I'd just be okay with 225's then, not sure... those 9.5"s available in that wheel are just too big I'd guess, until I get coils to help reduce the chance of rubbing.
Go with 225/40R18 and save the weight, plus the contact patch is no longer ideal for tracking is you use a 245/35R18.
You'll have a great combo for the track with that set, just choose yourself a nice sticky tire.
Old 03-19-2014, 01:07 PM   #2216
Slick
Slick's Avatar
Originally Posted by drift94 View Post
going with 18x9.5
dropping 1.1 inch
what tire size should i run?
what ofset should i run?
want a flush like look but not going any lower so i just want the most grip i can get out of it.
Dropping on coilovers or lowering springs? That's the first question to answer before any others.
Tire size for a 9.5" wide rim is 245/35-265/35. Above answer will determine what makes most sense for you.
Old 03-19-2014, 01:09 PM   #2217
Slick
Slick's Avatar
Originally Posted by x Naq o View Post
So I'm looking to get the SA15R but not sure what size to go with. I have stock suspension at the moment but plan on dropping 1-1.5 inch so what tire/rims should I go with?
17x7.5 +45
18x7.5 +45
18x8.5 +48
18x9.5 +48
Those are high offsets for anything over 8" wide. Either option with 7.5" wide wheel will work, but for the 8.5 and 9.5 reduce offset by about 10mm.
Coilovers or coils?
Old 03-19-2014, 01:16 PM   #2218
tiz22
tiz22's Avatar
Appreciate it!
How can I determine for sure if it requires the tuner lugnuts or not? I guess I can ask the supplier..
Also, with that setup (225/40R18 on 18x8s) how flush do you think I'll be? And will my speedo be affected much?
Again, thanks!
Old 03-19-2014, 01:38 PM   #2219
Slick
Slick's Avatar
Appreciate it!
Again, thanks!
Discount tire will let you know if you need tuner lugs but likely needed for that wheel.
It will be pretty flush, one of our local guys is running the exact same combo and it looks great.
http://www.ft86club.com/forums/showthread.php?t=28003
That tire is pretty close to stock and probably within 1% of your speedo. Will read a touch higher (ie. 100 km/h indicated will be actually 101)
tiz22 (03-19-2014)
Old 03-19-2014, 02:38 PM   #2220
x Naq o
Drives: White
Coilovers or coils?
Plan on getting Suspension Techniques Coilovers.
x Naq o is offline   Reply With Quote
Old 03-19-2014, 03:03 PM   #2221
Slick
Slick's Avatar
17x7.5 +45
18x7.5 +45
18x8.5 +48
18x9.5 +48
With coilovers, you could run all except the 18x9.5 +48.
Even with the 18x8.5 +48, it's not an ideal offset, but it should fit.
If you're stuck on these wheels and no other offsets are available, then I'd suggest getting proper hubcentric spacers for an extra 10mm (like below). You could then run even the 9.5" wide wheels with a corrected offset of +38. You'll need extended wheel studs for these too.
Old 03-19-2014, 03:17 PM   #2222
x Naq o
Drives: White
I'm stuck on either those or Enkei Racing NT03, the SA15R those are the only offsets they offer.
I'm definitely a noob when it comes to wheels, tires and offsets so I really appreciate you helping out. I'll try to do some more research but think I'm going to go with the SA15R. So I should go with the 8.5 and just get the spacers and extended lug nuts?
Old 03-19-2014, 03:22 PM   #2223
Slick
Slick's Avatar
Yes, or go with the NT03's as their offsets are more FT86 friendly.
FYI, quality spacers like the H&R Trak (as posted) will come with the extended studs FYI.
Old 03-19-2014, 03:40 PM   #2224
x Naq o
Drives: White
Thanks for the heads up. One last questions, If I go with the NT03's whats a more reasonable offset to go with for our cars?
Old 03-19-2014, 03:52 PM   #2225
Tainen
Drives: First SWP BRZ-L
Stock for this year. next year, coilovers. Most likely V3s.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 03-19-2014, 04:05 PM   #2226
Slick
Slick's Avatar
Depends on the width. I think the 18x9.5 are available in +40 which is perfect with coilovers. 18x8 in +35 also is common. There's also a wide range of colours available (silver, SBC, black, white, gold, etc....)
Check out the vendor forums for group buys, I'm sure there's a few going on at the moment.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
