Old 03-14-2014, 12:02 PM   #1
s0sl0w
Proud of Boxer
Premature rusting?
Check your 86's guys found a smudge of rust last oil change so I decided I'd hit with some rust converter this oil change 5k later... Here's what I found (car has 10K and is less than a year in my possession, bought new).
The leading edge there is getting blasted and then rusted and if you examine carefully you can see rust along the edges. Just surface so far but surface rust leads to more rust and if you plan on keeping this car as long as I do (40+ years) then this is something that needs to be kept on top of.
This spring I'll be yanking the shielding and hitting everything with a wire wheel, converter, prime and paint, possibly do the leading edges that are getting material blasted.
s0sl0w is offline   Reply With Quote
Old 03-14-2014, 01:06 PM   #2
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
No offence, but if you plan on keeping your car that long, than why are you driving it in the winter?
Gords_zenith is offline   Reply With Quote
The Following User Says Thank You to Gords_zenith For This Useful Post:
Rayme (03-15-2014)
Old 03-14-2014, 01:14 PM   #3
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
Does the FRS come with rust protection? I know my BRZ does. Take it to your dealer and see.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 03-14-2014, 01:55 PM   #4
s0sl0w
Proud of Boxer
Because at the moment its my daily driver and I enjoy driving it.
The Following User Says Thank You to s0sl0w For This Useful Post:
chenshuo (03-16-2014)
Old 03-15-2014, 07:54 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You're a bit optimist to drive your car in the winter and expecting no rust at all. You did spot the rust so that's great it's better than to let it go. Sub-frame and suspension components usually don't have much rust protection compared to the body panels (who should take 6-7 years of winter beating before rusting).
This is my 2nd winter with the FRS in the very salty roads, when it's all dried up I'll do up a thread with pictures of under my car underbelly, I don't think there's much worst condition than the roads we have here. I know my exhaust is pretty corroded so far!
Rayme is offline   Reply With Quote
Old 03-15-2014, 09:26 PM   #6
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
SOSLOW SAYS:
"The leading edge there is getting blasted and then rusted and if you examine carefully you can see rust along the edges. Just surface so far but surface rust leads to more rust and if you plan on keeping this car as long as I do (40+ years) then this is something that needs to be kept on top of."
Four (4) years or "(40+ years)"?
BRZfan is offline   Reply With Quote
Old 03-15-2014, 09:34 PM   #7
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I have a few spots on my car similar to that. I simply wired brushed the surface rust, primed it, and spray painted it black. Looks oem and it takes care of potential future rust. Newer cars are less prone to rust but unfortantly if you drive your car in the winter or live near the ocean. Your car will rust no matter what you do.
cjsporl1996 is offline   Reply With Quote
Old 03-15-2014, 10:07 PM   #8
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
  1. Wire brush the rusted area
  2. Single coat of Flat Black Rustoleum spray paint
  3. 2 Coats of Rustoleum UnderCoating
  4. Finished
  5. Routine rust-checkups
Additional coats are up to your preference.
Drift&Drag is offline   Reply With Quote
The Following 2 Users Say Thank You to Drift&Drag For This Useful Post:
Giccin (03-20-2014), ZeHeadBanger (03-20-2014)
Old 03-15-2014, 10:11 PM   #9
utekineir
blowhard
Drives: frs, project forester
Op is keeping car till he's 56?
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
extrashaky (03-15-2014)
Old 03-15-2014, 10:48 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
Giccin (03-20-2014), radroach (03-20-2014)
Old 03-15-2014, 10:52 PM   #11
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Lol rust is inevitable! Unless you plan on garaging it...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 03-16-2014, 01:34 AM   #12
radroach
Drives: car
I checked around the front of my car today, a bit of a mold is growing on the rubberized paint near the fog light housing. I've only been doing simple hand washes but might have to bust out some heavier duty cleaning supplies and clean in every nook and cranny.
Old 03-16-2014, 06:30 PM   #13
s0sl0w
Proud of Boxer
Originally Posted by BRZfan View Post
SOSLOW SAYS:
Why would it be anything other than what I wrote? 40+ years. If I wear only keeping it 4 years I doubt I'd care, it'd be someone elses issue and I'd just do "normal" maintenance.
Thanks for playing dipshit. In 12 years of driving, almost 9 years of personal car ownership and 9 cars later I know when I get a hold of car that I truly can enjoy indefinitely. This car is one of those cars for me and because I do intend on being it's only owner until it becomes my children or grandchildrens I want to make sure it's not a rusted to bits heap in 25 years and that starts by being obsessive now.
The other car that has a special place in my heart is my 1999 2.5Rs, a car that is going to have FAR too much money spent on it one day if I at all have the means.
This spring I'm pulling the shields, brushing/cleaning all the rust afflicted areas, hitting with converter and then coating to prevent further rust. While I'm not surprised by the rust I was hoping it wouldn't become an issue so quickly.
Old 03-17-2014, 10:08 AM   #14
BRZfan
BRZfan's Avatar
If you want to keep a car for forty years in a specific operating condition, to minimize oxidation, and it is driven in wintry and salty road conditions year after year, you must be able and willing to do the following;
1. Have an air conditioned garage and a dehumidifier in continuous operation depending upon the season.
2. Do not let salt stay with the car more than one day. That is on ALL surfaces, exterior paint, the underside and even in the interior. if you cannot do this and to MINIMIZE oxidation, DO NOT garage the vehicle but rather keep it outside. It has been shown (by paint manufacturers) that long term oxidation occurs more readily when the vehicle is kept in the garage after salt has accumulated on the surfaces for that day. It is best to keep it OUTSIDE where the oxidation process is slowed because the temperature is normally lower.
3. Inspect the car on a regular basis for any oxidation and correct the problem as soon as possible.
4. Be sure to maintain continuous and proper maintenance and replace any defective or warn/overused components before they affect other parts of the vehicle.
5. Be alert to the availability of replacement parts.
6. Realize that in forty years it will be the year 2054 and many changes will have taken place during that time - personal life, children and grandchildren interests/preferences, the economy, new technology, new government regulations and advanced road /driving conditions to name a few. I might suggest to keep us updated but in 15 years or less this forum and/or current posters will have disappeared from the scene...
OR
Make it a 'Garage Queen'.
Good Luck!
Originally Posted by s0sl0w View Post
Check your 86's guys found a smudge of rust last oil change.....
Premature low fuel light WolfpackS2k BRZ First-Gen (2012+) — General Topics 76 06-21-2013 10:45 AM
My FRS is already rusting! shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 17 04-29-2013 01:26 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 04:56 PM
Anybody else's car rusting yet? Selvedge Issues | Warranty | Recalls / TSB 17 10-31-2012 10:11 AM
