Old 02-27-2014, 09:14 AM   #85
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by SirBrass View Post
Probably not. The tablet will use the port either for power or for hosting a slave device.
I'm on my phone so if I make mistakes, blame Sportsguy83
There's a huge thread on it in the tabletPC review forums. By luck found that @dwx has the tablet. There are tons of work arounds, but he has one that is simple, clean and allows simultaneously to charge/transfer data.
http://forum.tabletpcreview.com/dell...tml#post377144
Here is my setup.
I bought most of this on DX but I think most is available on Amazon now except the micro USB female to USB female.
USB Type A Female To micro-USB Female Adapter - USB Adapters has them for really cheap. It's in HK but shipping was really fast, much faster than DX.
I use a USB to micro USB adapter to plug into the V8P. The Y-cable has a female micro USB so I plug the normal power cable directly into there. The other part of the Y has a male micro USB so I either plug that directly into the device, or I use a male to female USB adapter to plug in other stuff.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
SirBrass (02-27-2014)
Old 03-01-2014, 06:27 PM   #86
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Originally Posted by 350matt View Post
add a usb 2.0 hub to your laptop and connect the EcuTek cable via that
it'll greatly reduce the flash time
+1 !!
I had to see it to believe it, but with an older laptop with 2.0 usb, flashing an EcuTek ROM was taking nearly 4 minutes. With a cheap 2.0 usb hub in between the laptop and EcuTek cable, flash times are now 45 seconds. WOW!
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 03-01-2014, 10:39 PM   #87
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Circuit Motorsports View Post
+1 !!
- Bob
So you upgraded from 2.0 to 2.0 and got an increase in speed... Makes perfect sense......
The only way that can make a difference is that the USB Hub might provide better power.
Is it possible that the cable/dongle/tactrix-thingy you are using can write to the OBD port faster with higher supply voltage?
Old 03-01-2014, 11:46 PM   #88
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Ms surface
Get one
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 03-09-2014, 09:37 PM   #89
Circuit Motorsports
Like I said, had to see it to believe it! Must be the chipset or hardware compatibility with the hardware in the cable, or EcuTek Drivers.
- Bob
Old 03-12-2014, 12:42 PM   #90
welllam
Drives: STi
Nice thread. I always thought that flashing took more than 10 mins until this thread appeared.
I have a Samsung series 9 X900 and it has SSD and I5 CPU. Believe it or not I used to use the USB 3.0 port for flashing. After reading this and realising the norm, I tried to use the other USB 2.0 port and the speed is about 2 mins. So 2.0 is faster than 3.0? Yes in our case but no in theory! But this should be like Bob said, it's the chipset.
Sent from my SM-N9005 using Tapatalk
welllam is offline   Reply With Quote
Old 03-12-2014, 01:51 PM   #91
jamesm
Picked up an asus x200ca on sale at best buy for $279. Flashes really fast, but windows 8 still sucks even with a real keyboard. It doesn't seem to know it's on a laptop, and tries to bring up a touch keyboard all the time. Maddening still, but it's more useable than the tablet was.
The Following User Says Thank You to jamesm For This Useful Post:
Sportsguy83 (03-13-2014)
Old 03-12-2014, 02:37 PM   #92
Circuit Motorsports
Agreed, windows 8 sucks... thinks everything is a tablet.
- Bob
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
jamesm (03-12-2014)
Old 03-12-2014, 02:41 PM   #93
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Server 2012 also thinks it's a tablet. Upside is rdp from my nexus works better than from a pc !
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-12-2014, 03:23 PM   #94
stugray
Has anyone ever tried to run a serial monitor for the USB port on the PC while flashing?
If we examined a serial trace file, we might be able to figure out the bottleneck.
I suspect that for the ones experiencing very slow flashing, that you are getting a lot of retries.
Old 03-12-2014, 03:33 PM   #95
jamesm
i think it's pretty well established that it has something to do with the usb chipset and the drivers for the cable. i'm not very familiar with windows in general, much less how their drivers work, but that seems to be the case given the evidence.
Old 03-12-2014, 04:24 PM   #96
Dezoris
Dezoris's Avatar
Originally Posted by DJCarbine View Post
Tonight I can link exactly which ones I got, and will try to time the flash. Its been flawless for me so far.
Im actually looking for virtual usb software, we use it at work to have virtual dongles on multiple computers over a network, it would be nice to only require the cable and not the dongle on a device with only a single usb port...
My end goal is to install the dongle/cables/hub out of sight so I just plug in the single usb connection to the tablet. Maybe have the connector hidden in the center console or something.
You ever figure that out how to get the license key virtual?
Old 03-12-2014, 07:24 PM   #97
DJCarbine
Thupercharged
DJCarbine's Avatar
Have not found any virtual USB software, only USB over IP which isn't a huge help.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Excelerate Performance: Now Selling EcuTek and Flashing Visconti Tunes!!! ExcelerateRep Engine, Exhaust, Bolt-Ons 13 06-11-2014 10:52 AM
Laptop for tuning needs mrk1 Software Tuning 105 04-01-2014 04:38 PM
SOLD: Toshiba C855D Laptop swift996 Miscellaneous 0 01-10-2014 06:06 PM
Robispec * FTD and new Fastest Triplet time at Auto Center Speedway robispec Tracking / Autocross / HPDE / Drifting 16 02-25-2013 10:13 PM
ALIENWARE LAPTOP brichard0625 Off-Topic Lounge [WARNING: NO POLITICS] 68 11-06-2012 01:01 PM
