Old 02-16-2014, 01:51 PM   #15
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Originally Posted by CoupedUpSubie View Post
How long have you had the track pipe on your car? The AVCS on these cars kicks in somewhere between 3500 to 4000 rpms also.
It's been on for a couple of months now. If what you are trying to get at is a recent change causing the issue its highly unlikely.
Thanks for input tough, could you hear what I'm talking about?
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
MaXimus is offline   Reply With Quote
Old 02-16-2014, 02:22 PM   #16
CoupedUpSubie
Drives: 2013 BRZ Limited
I think I heard something like what you are describing but it sounded pretty even, I'll have to listen to mine closely next time I drive it. It doesn't seem like it's having a problem as it comes up through the rpms in that range. One thing with the exhaust I was thinking of is it moving just right in that rpm range as I had that problem with my impreza at one point.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 02-16-2014, 11:12 PM   #17
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
it's difficult to hear it but i know what you're mentioning. i also agree on trying different gas?
Old 02-17-2014, 12:17 AM   #18
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Sounds like a UEL exhaust system. But I do hear something, sounds like a cylinder is missing slightly. Could be bad spark plug, coil, injector, or cylinder leakage (blown DI seal, poor compression due to leaking rings or valves) all spring to mind. That's just seat of the pants guestimation. You can rule out most of that by doing a compression test, and checking the plugs and coils.....good luck. Also one more thing it also sounds like the cam belt skipped a tooth - I know it's chain driven but that could mean that the AVCS could be acting up and possibly phasing the cams improperly at low RPMs and when you get to high RPMs they engine responds better?
Gords_zenith is offline   Reply With Quote
Old 02-18-2014, 01:28 PM   #19
aagun
Drives: 86
i had same issues . visit AFM for test ur DI injectors for failure or burned DI seal . only use 98 RON or higher
aagun is offline   Reply With Quote
Old 02-18-2014, 08:03 PM   #20
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
That is a misfire. You can hear it and see it on the tach.
Xero-Limit is offline   Reply With Quote
Old 02-18-2014, 08:16 PM   #21
TrqlessWonder
Drives: 2014 FR-S
That's my call on that, too. Cylinder dropping out. Got that noise out of my old altima. Trick is, what's causing the misfire? In the altima, it was weak/no spark, I pulled the plug boots to do a little clean up and ultimately ended up severing the wire inside the boot. Very expensive way to find a $10 problem. Didn't throw a cel, though it should have.
I also had similar issues in other old GM V6's with coil packs going bad. Got worse when under load. Need 4 things for combustion fuel, air, compression and spark. The tech needs to find out which one (or more) of those components is missing.
TrqlessWonder is offline   Reply With Quote
Old 02-18-2014, 08:51 PM   #22
Xero-Limit
Xero-Limit's Avatar
If you have the EcuTek ProECU you can check via the logging to see if it is misfiring or not. (see attached screen)
Otherwise the next step would be to hook it up to a scanner and see if it is misfiring or running rich. Misfiring is usually caused by an overly rich condition, or a bad ignition component. If knock caused the misfire you'd hear a sound similar to pool balls hitting eachother just prior to the misfire.
Old 03-04-2014, 01:32 PM   #23
MaXimus
Meh!
MaXimus's Avatar
Hey Guys,
Gave the car to dealership and got told issue is fixed. My question was what did you do? Apparently a ecu update and pulling and cleaning the injectors sorted it.
Well bull, it's not as bad sound wise, but same if not worse performance wise. I feel like I'm driving a stock last gen civic type R. No power torque anything under 5k and then whoopy a Fkn normal car.
Argh! I don't know what to do. No CEL no buneos!
Old 03-06-2014, 07:51 AM   #24
aagun
Drives: 86
do u have poping after fix the issues by AFM ?
the power is came after 5k u have rev it high to get it .that best for fuel economy .
Old 03-08-2014, 05:14 AM   #25
regal
Drives: Scion FR-S/Toyota Yaris
Have you owned a Subaru before? This is how the factory tune sounds. Unfortunately with Subaru the best thing you can do is have a little tuning done by someone experienced with subarus. They have a rep for not honoring warranty anyay.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-08-2014, 07:06 PM   #26
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
last video at 22 seconds you can hear a pop, not sure it is from outside or you bumping the phone but sounded like the DI seal failure pop when you give the car throttle. I could not tell the difference for awhile and in that range of RPM anyways the car has very little torque. That is where the torque dip lies.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 03-12-2014, 07:56 AM   #27
regal
What was the verdict?
Mods:
Old 03-12-2014, 03:05 PM   #28
MaXimus
Meh!
MaXimus's Avatar
Hi All,
Sorry it's been a while. I have owner a Forester from brand new to over 110,000km trust me I know full well about torque dip and boxer motors.
Anyways finally got AFM technical team involved and after several days the have confirmed direct injection issue. I've told them to also check spark plugs considering the related issues.
I'll post back once I get the car and see if I can ask for original parts with some photos for you guys. Interesting to know I don't have a CEL and the issue doesn't seem to be like anyone else with DI issue.
Cheers,
Sam
Engine bogging down FRiSson Issues | Warranty | Recalls / TSB 6 08-14-2015 08:07 PM
Wheel bearing gone at 1,500k!? Muskokan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-02-2014 03:58 PM
Transmission Dry Sound & Bogging jjkerr626 Engine, Exhaust, Transmission 3 06-11-2013 12:10 AM
Bogging Question??!! Help needed... ScionFrsFan Engine, Exhaust, Transmission 36 02-05-2013 06:44 PM
