Old 01-04-2014, 01:13 AM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Midnight23 White on White Greddy Turbo Kit 275whp ***Evasive Tuned***
Finished our good friend and customer Jonathan aka @midnight23 clean BRZ. Just wanted to share this build for you guys to enjoy. The car made 275whp / 207tq on our Mustang dyno which is very impressive with a bolt on kit . The car is one of the higher numbers we hit on pump 91.
91 Pump Gas
275WHP (MUSTANG DYNO)
201TQ
Current mod list:
Exterior:
APR Front Splitter
JDM Side Markers
Rally Armor Mudflaps
VG Shark Fin
Circuit Motorsports Carbon Fiber Hood Dampers
Driveway Labs Rear Diffuser Type 1
Interior:
Lathe Werks weighted shift knob
GReddy Multi D/A Boost Gauge
GReddy Profec Electronic Boost Controller
OEM Armrest
OEM Audio 400+ System
Performance:
GReddy Tuner Turbo Kit
GReddy Magnetic Oil Drain Plug
Invidia Q300 Ti Tips
Invidia Q300 resonated front pipe
Action Clutch Prototype
ECUTEK Tuned by Evasive Motorsports
Evasive Spec Fuel System
Perrin overpipe
APR Radiator Cooling Plate
Full Blown Radiator
Full Blown Oil Cooler
Full Blown Radiator Shroud with 12" Spal Fans
Full Blown Radiator Hoses
Suspension:
Tein Flex coilovers
Cusco Lower Control Arms
Grimmspeed front strut bar
Evasive Spec Alignment and Corner Balance
Wheels/Tires:
Advan RG-D 18x9.5 +40 custom powder coated pearl white
Advan Racing center caps
Michellin Pilot Super Sports 255/35/18
Evasive Super Lap Lug Nuts
UPDATE 3/17/14 New Wheels Advan RG-D - 18x9.5 / +40 / 5x100 (White)
Evasive Motorsports is offline   Reply With Quote
Old 01-04-2014, 01:41 AM   #2
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
Can you post a mod list supporting the kit? Also what sort of ems?
Been thinking about something like this and those numbers are very good.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 01-04-2014, 01:44 AM   #3
Evasive Motorsports
Mods are listed. We used ecutek for the tuning.
Old 01-04-2014, 03:06 AM   #4
vincent201089
vincent201089's Avatar
Drives: frs
Is that number at 7psi?
vincent201089 is offline   Reply With Quote
Old 01-04-2014, 08:18 AM   #5
Redlinedfrs86
Redlinedfrs86's Avatar
Drives: 2013 Firestorm FR-S
so clean!
Redlinedfrs86 is offline   Reply With Quote
Old 01-04-2014, 02:55 PM   #6
Boss Paco
Boss Paco's Avatar
Very nice! Without compromising your business or secrets, could you give me an idea of what your fuel system entails?
I expected what you posted for a mod list thus far. I was wondering mainly if a high flow pump and some decent injectors would get it, which I assume would. Just would like to know what you went with to achieve these numbers aside from awesome tuning skills!
Old 01-05-2014, 11:52 AM   #7
JS + BRZ
Drives: 2010 MS3
Lovely set up! Thanks for the work.
Can you pm me how much it cost for this type of set up ? I'm making a side funding for a FI kit. Thanks.
Sent from my SCH-I605 using Tapatalk
Old 01-10-2014, 05:46 AM   #8
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Sorry guys I didn't notice Evasive made a thread on this section as well I'll answer all your questions
10-11psi
700cc injectors + fuel pump
Pm'd
Build Thread
Instagram
Old 01-10-2014, 12:47 PM   #9
Boss Paco
Boss Paco's Avatar
Nice. Which pump did you select? Any plans for E85? I think OK gas quality is similar to CA's but we have E85 in the OKC metro so I was thinking of adding a flex fuel setup to mine.
You got a nice ride!
Old 01-10-2014, 09:10 PM   #10
midnight23
DW 265LPH, and yes E85 will happen eventually however the power right now is great for pump gas, with e85 it should hit 350 without an issue but I don't think my tires would like it .
Build Thread
Instagram
Old 01-10-2014, 09:12 PM   #11
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
damn these are the perfect numbers i want to see honestly on CA roads you don't need and can't use 300 hp honestly
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
Old 01-11-2014, 12:56 AM   #12
Boss Paco
Boss Paco's Avatar
Haha DW is in my backyard. I'm friends with some of the gang. My E85 STi is much hungrier than my BRZ and was wondering if any of the boosted 86 guys were going with any of the big E pumps. 265 seems kinda small to me.
Your setup is something like what my build is going to look like. Just don't wanna reinvent the wheel if someone (you) has already been there and done that. If mine turns out similar to yours I will be very happy.
Old 01-11-2014, 02:32 AM   #13
midnight23
Your STi sounds beast, I had an 05 and it was honestly the most solid and reliable car I've ever had. I ran e85 on my supra before this with dual pumps and 1000cc injectors, my only gripe with it is the major temp changes during winter when it screws the startup and needs tuning adjustment, and the fact that I had to fill up every 3 days haha. I believe the pump should be good for at least 400 considering people were getting 300~ with the stock one.
Build Thread
Instagram
Old 01-11-2014, 11:16 PM   #14
Boss Paco
Boss Paco's Avatar
Should have the STi making noise soon. I run two 044s from a surge tank and net about 12mpg the last time I had her running. Looking forward to the long breakin because of the fresh ppg upgraded 2007 trans and rear going in. New block and heads too. This thing has been a bear to say the least. Should make great power when she's buttoned up.
The snooping I've done should turn out well. Not sure if I should go with 1000s either. I know me and after I get some boost I will buy a case and start the upgrades. Thanks for sharing your build!
ImperiousRex Time Attack BRZ **Evasive Tuned 271whp Greddy Turbo** Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 18 07-24-2014 07:38 PM
ImperiousRex Time Attack BRZ **Evasive Tuned 271whp Greddy Turbo** Evasive Motorsports Forced Induction 21 02-07-2014 11:12 AM
Midnight23 Greddy Turbo Kit 270whp ***Evasive Tuned*** Evasive Motorsports Forced Induction 27 01-27-2014 01:51 AM
Bon Sleeper BRZ AVO TURBO **Evasive Tuned** Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 37 12-27-2013 02:29 AM
Bon Sleeper BRZ AVO TURBO GRAPH **Evasive Tuned** Evasive Motorsports Forced Induction 42 09-26-2013 09:26 PM
