#99 |
Higher octane burns slower (and less efficiently) if the tune doesn't have timing set for it, plus Petro 94 has 10% ethanol while Shell 91 is 0% ethanol.
#100 |
Fanboy
Drives: 2013 ultramarine frs
The ethanol would certainly account for the mpg. I think you've contradicted yourself about slow burn being inefficient. The slow burn allows for higher compression and more advance which increases efficiency. This is assuming it is gasoline and not an ethanol blend. The reason ethanol blends have a higher stated octane yet are less efficient is because of the energy density of ethanol being lower than gasoline. Higher octane pure gasoline is more efficient than lower octane pure gasoline. But pure 91 vs e10 94 is not apples to apples.
#101 |
^^ Re-read what I said... if you're running a tune that isn't optimized for higher octane, you lose efficiency because you get less complete combustion.
Now if the tune is set to take advantage of the higher octane then you'll definitely make more power at a higher efficiency, but just throwing higher octane in on a lower octane tune will definitely be less efficient.
#102 |
Fanboy
I see what you meant. Wouldn't a 91 tune be able to add a little advance over time?
#103 |
Depends how much advance was tuned in. If it was already maxing out the advance (ie no knock at all) on 91 octane, putting in 94 octane wouldn't net any gains without adjusting the tune. If it was getting some knock on 91 and not running the full desired advance then 94 would net some gains.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#104 |
Fanboy
Fair point it's unlikely that an off the shelf tune would go knock hunting. Far more likely it would max at a relatively conservative level. Thanks for having a civil conversation on the Internet with me! Refreshing stuff.
#105 | |
Drives: 2013 Argento FR-S
With it being in the 20's in Atlanta in the morning the past few days, it has been a PITA starting my car. Using the photo below, I edited the cranking parameters in RR. I'm happy to say I had no difficulty starting the car this morning.
#106 |
Drives: 2013 FRS
Good work Malt! If i get some more positive feedback from those changes (from people still having cold start issues), I'll incorporate your updates to the OTS mapping
#107 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
I had my first cold start issues today, without the revisions. Stumbling after an initially successful seeming start. Wasn't a big deal though, second attempt worked great.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
#108 |
Drives: 2013 Scion FRS
I'm in San Diego and it's been 65 degrees at 8am when I try to start my car and I've had multiple failed starts every morning. Today I had 6 failed starts with a couple of spits and sputters each before it finally started on the 7th turn. My neighbors must think I drive a clunker...
It wasn't this bad from my first few tanks of e85 but then I switched to a brand new station that opened up closer to my house. I'm thinking the newer one has higher levels of ethanol and that is causing the rough start but I haven't tested it yet. I would love a fix because I can feel the power and don't want to give that up
#109 | |
Drives: FRS(sold), AP2, R35, FJC, ED9
i had identical experience. even at 65F in my garage the car would burp and fart horribly before finally starting. finally gave up and went back to 91oct. when the cold starts gets addressed i'll go back to e85. i miss the power already.
#110 |
It was 7 degrees in Atlanta this morning. It took 25 cranks to finally get my car started. Once it did start, a massive amount of blue smoke came out of the exhaust. Hopefully that was due to the number of times I had to crank it before it started. After the engine was running for 10 seconds, the blue smoke went away. I think I will be going back to 93 octane until this Arctic blast covering the country dissipates.
#111 |
So instead of admitting defeat & going back to 93, I increased the cranking tables in my map by 10 to 20 percent. I did this to the all coolant levels 32 & below. It's 20 degrees in Atlanta right now and the car started on the 1st try. It did gurgle a little bit but at least it started right up. Here is a screenshot of my cranking tables
#112 |
Drives: 2013 SWP Limited BRZ, MT
I'm on my second tank of e85 and i'm starting to get the failed starts. I had to press the starter 3 times one time, kind of embarrassing cuz i had a female in the car lol.... The sputter/slow start is normal now. I'm hoping SHIV will incorporate the changes other users are doing for cold starts or else this will be my last tank of e85...
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet E85 (and gasoline) Maps now available | Shiv@Openflash | Software Tuning | 401 | 08-13-2014 11:14 PM |
| OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my | Shiv@Openflash | Software Tuning | 122 | 12-14-2013 10:17 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
