Old 01-05-2014, 04:34 PM   #1
StRacngtC06
StRacngtC06's Avatar
Drives: 2013 Whiteout FR-S
6MT wont shift?
Car has 14000 miles and not driven too hard. I have not had any previous issues, then yesterday car wouldn't go into any gear while car is on, car off transmission works, no grinding or blockages. clutch still has pressure behind it. and no noises while trying to shift. any ideas. car is at dealership under warranty repair.
StRacngtC06 is offline   Reply With Quote
Old 01-05-2014, 06:03 PM   #2
Let's see if I have this straight.
Your MT car will NOT go into gear if the engine is running, but it WILL go into gear if the engine is NOT running .. ??
If this is the case, that's above my pay grade ...
Next ....
Mr.EvoMR (01-06-2014)
Old 01-05-2014, 06:13 PM   #3
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Next ....
One thing I love about @humfrz on this forum, is that even though he might not know the answer, he will post to either have a little fun or lighten the mood.
husker741 is offline   Reply With Quote
The Following 2 Users Say Thank You to husker741 For This Useful Post:
humfrz (01-05-2014), Mr.EvoMR (01-06-2014)
Old 01-05-2014, 06:14 PM   #4
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Sounds like it could be a couple of things 1) pilot bearing is toast which is causing the input shaft to still spin even with the clutch in ( this happened to me with my Truck), or 2) your slave cylinder/clutch master cylinder is toast and not releasing the clutch by depressing the pressure plate.
Gords_zenith is offline   Reply With Quote
The Following 2 Users Say Thank You to Gords_zenith For This Useful Post:
Mr.EvoMR (01-06-2014), StRacngtC06 (01-05-2014)
Old 01-06-2014, 04:51 PM   #5
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
Both possible.
Thread Starter:
What does the clutch fluid itself look like? Still yellow and transparent?
Car is at dealer? Let them figure it out then
TopGearSolutions is offline   Reply With Quote
Old 01-06-2014, 05:22 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Could be a broken clutch spring/assembly, manuf. defect.
Rayme is offline   Reply With Quote
Old 01-06-2014, 05:39 PM   #7
White64Goat
I will be interested in the answer to this when you find out. I have a 2001 PT Cruiser that has been sitting in a garage for 3 years with the same problem. All hydraulics are working as I can see the fingers on the pressure plate move when the clutch is depressed. Didn't have the money to fix it when it happened and I had another car to drive, so it's been sitting.
Old 01-06-2014, 10:14 PM   #8
StRacngtC06
I did check the clutch fluid and it was looking brand new. got a call from dealership, mechanics found broken clutch springs inside.... new clutch assembly ordered.
Old 01-07-2014, 12:07 AM   #9
UGH! ..... any idea what caused it to go bad .... ??
Old 01-07-2014, 12:30 AM   #10
StRacngtC06
well I didn't beat on it if that's what u mean...it always did feel really tight though.
Old 01-07-2014, 12:41 AM   #11
Dezoris
Dezoris's Avatar
Shocked the dealer did not tell you the reason for the failure was because you were born.
The Following User Says Thank You to Dezoris For This Useful Post:
sosick (01-08-2014)
Old 01-07-2014, 12:42 AM   #12
Nope, that's not what I meant ...
Well, maybe the techs will find a defective part or something.
Old 01-07-2014, 12:52 AM   #13
bobaab
Drives: 13 Subaru BRZ Limited
Are you the same humfrz from the Miata forums?? I think you are
I totaled my Miata on some slick roads so I am up for a new car...thinking the FR-S/BRZ. You must be in one now. Just wanted to say hi again
bobaab is offline   Reply With Quote
Old 01-07-2014, 10:54 AM   #14
Hi ya, bobaab,
Yep, the same old humfrz ..... after my miata, I got an FR-S; I wasn't quite ready for a Buick ..... yet ....
Sorry to hear you lost your miata .....
I replied to your PM.
This is a good forum .... ther folks are generally a bit "younger", but they still tolerate my "back in the day" stories (I think).
If you go with a FR-S/BRZ, come join us .....
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 03:56 PM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 08:57 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
