Old 11-15-2012, 10:14 PM   #1
ScionFrsFan
Car wont start? Anyone else?
Hello, every so often it takes a few tries to get the car started...I assume this isn't normal on a new car
... happen maybe 4 times total since I bought it in late Aug.
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 11-16-2012, 12:01 AM   #2
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
If it's manual, make sure you're not pressing against the gas pedal. The engine floods easily.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 11-16-2012, 12:03 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Check your battery voltage, could be a bad battery or bad connections.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-16-2012, 01:35 AM   #4
wheelhaus
wheelhaus's Avatar
Please define "a few tries"...
Do you mean it turns over several times before firing up, or are you turning the key and just getting nothing, clicks, weak/slow start, etc?
wheelhaus is offline   Reply With Quote
Old 11-16-2012, 07:00 AM   #5
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
Happened to me once so far. Let it crank for about 5 seconds. Cranked strong but wouldn't turn over. Cranked second time for about 10 seconds. Cranked fine but again didn't fire up. Third try must have been the charm bc it fired right up. Hoping it was just a fluke.
BoostedWrbBrz is offline   Reply With Quote
Old 11-16-2012, 09:58 AM   #6
ScionFrsFan
It's a auto and yes I turn it over and nothing, it tries to start put doesn't lol. I hope it was a fluke too! ... 4 times already.
ScionFrsFan
Old 11-16-2012, 10:41 AM   #7
einzlr
Drives: several
+1 on checking the battery and connections. If it's that, then eventually you will get stranded.
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 11-16-2012, 10:53 AM   #8
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
The Evo X came with those same Panasonic batteries and we had problems starting almost every car with them. When we replaced them with an Optima battery, the problem was solved. I'm not sure if it really is the battery but having worked for a dealer that dealt with those batteries, I wouldn't be surprised.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 11-16-2012, 11:05 AM   #9
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Try giving it a moment once you turn the key to the first position for the fuel pump to prime the injectors. I've had this problem occasionally.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 11-16-2012, 11:33 AM   #10
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
If it's an AT make sure it's in Park or neutral ?
Spartan65 is offline   Reply With Quote
Old 11-16-2012, 12:01 PM   #11
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It happened to me 4 times in 45 days...it's been a long time since the last time it did it.
The engine cranks but takes about 4 seconds to start vs the normal 0.5-1 seconds. I'm not making a deal about it yet.
Rayme is offline   Reply With Quote
Old 11-16-2012, 12:03 PM   #12
mact
Drives: 13 GTI
Happend to me 1 time in 1800 miles.
mact is offline   Reply With Quote
Old 11-16-2012, 02:26 PM   #13
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
Has happened to me once also, 600km.
since then i have waited after i have turned the key to the first position for the fuel pump to prime and it has not happend since.
FR-S Hot Lava is offline   Reply With Quote
Old 11-17-2012, 12:25 AM   #14
3essess
Drives: frs
got 4000+ miles - happened to me about 3 times so far, exactly as you described
3essess is offline   Reply With Quote
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 03:28 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
