Old 11-10-2013, 10:09 PM   #1
Matt90
Matt90's Avatar
Drives: 2013 Raven Scion FR-S
Right headlight wont turn on
I have an HID kit from precision, . And noticed my right light was out. I at first thought faulty bulb.. but checked the outlet with a stock bulb, nothing. Tried other side, bulb worked fine. Should I take it this to the dealer?? Any ideas? No power coming from right headlight connector.
Matt90 is offline   Reply With Quote
Old 11-10-2013, 11:15 PM   #2
fistpoint
Drives: Supercharged Golf Cart
I didn't even have to open the thread before knowing it was HID related...do any of these kits ever go in without causing issues? Or is the issue always the installer?
Considering how many "help me fix my lighting after attempting to install HID" threads, I'm pretty sure if I ever desire to get them I will have someone do it for me.
Good luck, free bump. Oh, why the dealer? I'd pick a local shop over the dealer any day for stuff not under warranty. Dealers are for warranty work only.
fistpoint is offline   Reply With Quote
Old 11-10-2013, 11:17 PM   #3
Matt90
Matt90's Avatar
ive had this kit on for over 5 months with no issues, one day the right headlight just went out. and now not even stock bulbs will work on that side, could it be a fuse? if so , is that located under the hood or side panel?
also reason i say dealer, is who knows what this could be?, the HID could have very well NOT been the issue, there for warranty work could be done.
Old 11-11-2013, 12:35 AM   #4
Matt90
Matt90's Avatar
anybody?? i cant be the only one
Old 11-11-2013, 12:46 AM   #5
humfrz
Originally Posted by Matt90 View Post
.............could it be a fuse? if so , is that located under the hood or side panel?
The fuse is the first thing I would check. The socket would be the second and the wiring the third.
Your owners manual gives you a diagram/chart of which fuses control which circuits.....
Sorry, I can't be more help .... my car doesn't have HIDs.....
humfrz
Old 11-11-2013, 12:55 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
I can't help but I see so many german cars where 1 HID is out. I wonder what causes that...
Old 11-11-2013, 01:11 AM   #7
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Unlikely it was the Fuse, if it was the fuse both headlights would be out. Check it anyways just to be sure, however most likely this is a connection issue somewhere. I'd venture a bet you have been drawing too much amperage through the wire and have a burned out pin on a connector somewhere under the hood.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 11-11-2013, 10:53 AM   #8
Matt90
Matt90's Avatar
Thanks guys looks like its off to the dealer if its not fuse related..
Old 11-11-2013, 01:22 PM   #9
frslee
Just drive it
Drives: 13' FR-S
@Matt90
there is 1 fuse to each headlight. Try swapping out the fuses and see if other light turns on. Fuse box is on left side of engine bay.
My right headlight fuse went out when I first installed the HID. I thought it was the faulty ballast, but new fuse fixed it.
frslee is offline   Reply With Quote
Old 11-11-2013, 03:56 PM   #10
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
Originally Posted by frslee View Post
@Matt90
Same here, My right headlight fuse went out. Changed the fuse and all was good.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
