Old 07-18-2012, 10:31 AM   #1
sirhc
sirhc's Avatar
Drives: fr-s
Stock FR-S amp
So I was playing around yesterday and found out some information I didnt see posted anywhere. In my trunk there is a stock amp for the radio how ever it only does the front door speakers and the 3.5" in the dash, if you unplug it, the tweeters in the dash and the ones in the back still play
I am going to find out what rms it pushes as soon as I get a little more time
sirhc is offline   Reply With Quote
The Following 4 Users Say Thank You to sirhc For This Useful Post:
Calum (07-18-2012), Dru670 (05-31-2016), empower-auto (07-18-2012), MattR (07-27-2012)
Old 07-18-2012, 11:21 AM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
do share
actually while you're investigating this you should come up with a full stereo schematic of the car. list all speakers, what they are powered from, and how much power they are receiving.
it would be great info for anyone looking to upgrade.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-18-2012, 08:08 PM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
There is already such info everywhere , if I recall correctly its a 2 channel 300w amp
mashal is offline   Reply With Quote
Old 07-18-2012, 09:39 PM   #4
skoodge
Addicted to cars
skoodge's Avatar
Drives: 2013 Whiteout FR-S AT
Can it be used to drive anything? Say a small subwoofer?
2009 370z (sold), 2011 Mustang v6 Premium (sold), 2013 FR-S [Whiteout](current)
skoodge is offline   Reply With Quote
Old 07-18-2012, 11:26 PM   #5
Lytheum
Drives: 2013 BRZ Premium 6MT
i highly doubt its 300w rms. you would also have to find what kind of ohm load it can handle to power other stuff with it.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 07-19-2012, 02:11 AM   #6
cruzinbill
Drives: Argento 6spd FR-S
I agree it prolly does 25x2
cruzinbill is offline   Reply With Quote
Old 07-19-2012, 11:42 AM   #7
sirhc
sirhc's Avatar
Drives: fr-s
I doubt you can run a any kind of sub off of it. and im sure its not a 2 channel 300 watt amp either , if the whole system is 300 watts and its only powering 4 out of the 8 speakers. my quesss its probobly like a 100-200w. I am going to be tied up this weekend but I will get some info on it as soon a I have the chance
Old 07-19-2012, 09:26 PM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
Did i say RMS? Its a peak value.. every amp advertises their peak value.. I dont know the RMS, I would guess 75 watts per channel RMS? Maybe 70?
Ofcourse you can power a Sub.. but will you will be supplying enough power with it.. HELL NO.
I will let you know tomorrow when I get my car, I will measure the value for you with a DMM
Old 07-23-2012, 09:31 PM   #9
pkny
Drives: Firestorm FR-S 6MT
See here:
http://www.ft86club.com/forums/showthread.php?t=5280
Page 4, standard audio system -- 140w(peak) 2ch amp.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 07-23-2012, 09:58 PM   #10
sirhc
sirhc's Avatar
Drives: fr-s
sweet thanks
Old 10-25-2012, 04:30 PM   #11
dj petey
dj petey's Avatar
Most aftermarket manufacturers list the inflated max or peak power at 14.4V at an ugly THD at a 2ohm load. This generally accepted marketing practice is quite dubious in my opinion since this condition isn't the expected real world conditions the amp will see. Since this is a 2 ch amp the max watt/ch is 70. Let's drop 20% for 12.5V operating range and it goes from 70w to 56w. Now half that to get your rms which is 28w, calculate for a load of 4ohm, which most audio speakers are spec'd at, and you're down to maybe 17w rms if you're lucky. I won't speculate what the real wattage is at a THD of <1% but it'll be less than 17w rms.
Now considering that the stock in dash and rear speakers have a power handling of 15w RMS it would make sense that the amp would only have 17w rms at 4ohm at <1%thd.
The head unit is 160w max divided by 4 ch gives you 40w max or 20wrms at 14.4v, or 16wrms at 12.5v assuming it was already rated at 4ohm at <1%THD. This puts it in line with the 2 channel amp in the back and in line with the 15w power rating of the speakers.
dj petey is offline   Reply With Quote
Old 12-29-2013, 12:29 AM   #12
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
So I'm looking to just add a powered subwoofer to my FR-S while leaving the rest stock. Does it make sense to have it connect via the head unit or extend off the wires going to the stock amp somehow? Below are two frontrunners.
[ame="http://www.amazon.com/Kicker-Hideaway-Compact-Powered-Sub/dp/B007LQWSYC"]Amazon.com: Kicker Hideaway Compact Powered Sub: Car Electronics[/ame]
[ame="http://www.amazon.com/gp/product/B004HW6F9M"]Amazon.com: Pioneer TS-SWX251 10" Flat Subwoofer with Enclosure 800 Watts: Car Electronics[/ame] with amp
I just want a little extra low end but be able to pull it out easily or keep most of my trunk space.
oldpueblo is offline   Reply With Quote
Old 12-29-2013, 01:11 AM   #13
onefitz
Drives: 13 GBS BRZ
Amazon.com: Pioneer TS-SWX251 10" Flat Subwoofer with Enclosure 800 Watts: Car Electronics with amp
Infinity basslink should fit your needs with out having to get an amp or do crazy wiring.
onefitz is offline   Reply With Quote
Old 12-29-2013, 01:50 AM   #14
oldpueblo
oldpueblo's Avatar
Can I just piggyback off the power and audio cables going to the stock amp in back or do I need to run the new cables all the way up the length of the car to the head unit/battery?
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
BRZ stock in BC delsol97 CANADA 8 07-05-2012 09:39 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
BRZ stock nav - does it have RCA out? wootloops Electronics | Audio | NAV | Infotainment 1 06-17-2012 02:01 AM
Stock or JZ? Samdajiggaman Engine, Exhaust, Transmission 62 05-25-2011 06:12 PM
