Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 06-18-2012, 05:30 AM   #1
eckoflyte
Drives: Toyota 86 GTS
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels
Taking delivery of GTS in October. Just wondering if anyone else who is taking delivery in the same month would be interested in trading rims as stated in the title.
Reason is just personal preference. I hate the look of the 17" rims and would prefer the 16". I will be changing wheels soon to a more performance orientated set up so whatever I have stock on the car doesn't bother me, its just the 17" is an eyesore in the mean time.
Asking for straight swap, no cash adjustment required.
If anyone is interested shoot me a PM.
eckoflyte is offline   Reply With Quote
Old 06-18-2012, 05:35 AM   #2
coyote
coyote's Avatar
Drives: Slowly
Will they clear the brakes?
coyote is offline   Reply With Quote
Old 06-18-2012, 05:37 AM   #3
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
they should easily clear the brakes. the caliper is the same, as well as the offset of the caliper/rotor.
spiller is offline   Reply With Quote
Old 06-18-2012, 05:47 AM   #4
JiB
JiB's Avatar
Drives: GT86
im picking up the GT, but i also prefer the 16's over the 17's. i dont think you will have any trouble finding someone to trade with
JiB is offline   Reply With Quote
Old 06-18-2012, 05:51 AM   #5
Nardi330
Nardi330's Avatar
Drives: 86
U sure the brake calipers are the same? My research shows the rear pads are different.
Should still clear the wheels tho I think....
Nardi330 is offline   Reply With Quote
Old 06-18-2012, 05:53 AM   #6
450hp/tonne
Drives: 2011 Corolla Ascent Sport
spiller, please note that all 4 calipers, rotors and even pads are different between GT and GTS. The biggest issue will be the larger diameter front rotors (GT:277, GTS:294).
You will also find the ride and handling performance is reduced (16" tyre has a stiffer sidewall and stiffer ride), so might want to test drive both to see if that upsets you.
450hp/tonne is offline   Reply With Quote
Old 06-18-2012, 06:02 AM   #7
nix
nix's Avatar
Drives: AVO BRZ
A stiffer sidewall would increase handling performance. The 16s have 205/55s vs 215/45s. Seems unlikely the overall ride would be stiffer. Not sure about clearance here's some photos:
17"
VS
16"
nix is offline   Reply With Quote
Old 06-18-2012, 07:21 AM   #8
eckoflyte
If we were going to do it, I'd probably come to his/her place and we can just do a test fit, if its a no then so be it!
If anything, it'd be more likely I'd have problems fitting it on my car. However, as far as I'm aware, calipers are identical but the rotors are 294mm for GTS vs 277mm for GT.
I'm not concerned about stiffness or performance as ideally I would prefer an aftermarket forged or lightweight cast set of rims (e.g. enkei M.A.T cast wheels) and 245/40/17 all round for performance. I would like 245/40 as it is closest in rolling diameter to 215/45 and is good compromise between going too wide or too thin.
If its a mod I'm doing to the car, the preference is always performance before comfort.
I digress, in any case I'm after the 16s because I personally think they look better and I would probably have to roll around on them for a few months before I find the right set of rims for the right price.
Old 06-18-2012, 07:42 AM   #9
spiller
really? I am VERY surprised by this, given that the difference in rotor size is fairly minimal...
Old 06-18-2012, 07:48 AM   #10
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
The calipers are the same. the mounting pins & rotors are different
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 06-18-2012, 07:56 AM   #11
nix
nix's Avatar
Drives: AVO BRZ
Cool. I will go 235 or 245/35/18 all round (99.3 and 100.3 kph at speedo 100).
Old 06-18-2012, 08:17 AM   #12
Fussy08X
Fussy08X's Avatar
Drives: Toyota GT 86 Pearl White
i thought abt swapping with you for a moment but then i kinda like the 16s myself. I wanna at least drive on the 16s for awhile before I decide to get different wheels. Like another poster said im sure you'll find some1 to swap with relative ease.
Fussy08X is offline   Reply With Quote
225/45/17 on stock 7" wheels? ubersoph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-09-2014 04:59 PM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
Which stock JDM wheels do you prefer? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 40 02-08-2012 07:34 PM
