#57 |
Drives: 2014 SWP BRZ Limited
If you plan on getting a header in the future, I would add it. It will be cheaper to do it now in the long run than to have to try and add it later. It is also a fairly inexpensive addition at $65.
-Ryan @ Nameless |
#58 |
Drives: Raven Scion FR-S
and how long to make and ship out wight the resonator and non resonated?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#59 | |
Our lead time right now is right around 3-4 weeks for fabrication, seeing as we build almost every single part to order here in our tiny shop in La Center, WA. The helmholtz resonator has no impact on the lead time, however. -Ryan @ Nameless |
#60 |
okay perfect then ill just go with the helmholtz just to play it safe
#61 |
Drives: 2013 WRB BRZ Limited
Hey, thanks again about adding the resonator onto my downpipe today. Hope I didn't cause too many issues.
| The Following User Says Thank You to Pen.suhl For This Useful Post: | Ryan@Nameless (12-14-2013) |
#62 |
#63 |
Drives: 13' BRZ
pumped to get my fp/dp combo. gonna put it on with the revworks header sitting here. have to wait till the snow clears though....
#64 | |
Drives: Subaru BRZ
We are speaking about ours specifically, because we go for thicker piping and different design ours is meant for manual transmission, we designed it originally on a manual transmission first and did not produce an automatic transmission one. Not quoting all helmholtz designs in general just to clarify.
#65 |
Drives: Subaru BRZ (6027xx) Premium Manual
Why is the catted Nameless DP listed as "OFF-ROAD only"?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
#66 |
Drives: Pavement MT GR86
Because our communist overlords have deemed it illegal to tamper with any emissions equipment on automobiles.
So barring a failure you can't "legally" remove or replace cats.
GR86 MT premium
| The Following User Says Thank You to StormTrooper For This Useful Post: | Ryan@Nameless (12-17-2013) |
#67 |
Drives: 2014 FR-S MT Asphalt Grey
Would the catless op/dp with the helmholtz be raspy? I don't mind a little volume but cannot deal with the pissed off bumblebee sound.
As far as emissions are concerned...screw the overlords. |
| The Following User Says Thank You to shaunsweeney For This Useful Post: | tbertran (12-28-2013) |
#68 |
Drives: White BRZ Limited
I have an equal length header, a nonresonated/non catted front pipe, an overpipe, and a q300 catback. Since I went forced induction my car obviously became really loud. I'm trying to quiet the car down. I don't really have any rasp, but it's too loud. Without doing a catalytic converter would your Helmholtz resonater quiet the car down?
| Will Helmholtz resonator decrease power? | shu5892001 | Engine, Exhaust, Transmission | 31 | 01-07-2015 10:37 AM |
| Agency Power Front/Over pipe (Combo pipe) - Cheap! | seven | Engine, Exhaust, Bolt-Ons | 12 | 03-09-2013 02:40 AM |
| Will a resonated front pipe make alot less noise than test pipe? | Mike86 | Engine, Exhaust, Transmission | 8 | 01-26-2013 08:24 PM |
| Ordering Nameless Exhaust - Helmholtz Resonator?? | Umbie | Engine, Exhaust, Transmission | 16 | 12-03-2012 02:48 PM |
