Old 12-10-2013, 10:52 PM   #1
cooldandani
Drives:
Antifreeze /coolant...
Hey guys!! Quick question so I have the frs whiteout. Its winter time now and was just wondering does the car have antifreeze included already or do I have to change the liquid and add antifreeze??
Sent from my SGH-T889 using Tapatalk
cooldandani is offline   Reply With Quote
Old 12-10-2013, 11:10 PM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Included. Long life too so you don't even need to flush it.
Suberman is offline   Reply With Quote
Old 12-10-2013, 11:12 PM   #3
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
[ame="http://www.youtube.com/watch?v=1TcnCYes85A"]http://www.youtube.com/watch?v=1TcnCYes85A[/ame]
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
Missy (12-14-2013)
Old 12-11-2013, 12:20 AM   #4
As mentioned, it came out of the box with anti-freeze.
You might check the level from time to time. If you feel compelled to add any, make sure it's the proper kind (see your drivers manual).
Old 12-11-2013, 12:47 AM   #5
cooldandani
Drives:
Wow thanks so much for the input!!! Makes me feel more calm knowing this.
Old 12-14-2013, 09:31 PM   #6
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
A word of warning for the uninitiated- don't put tap water or spring water in your radiator, use only distilled water, which can be purchased by the gallon in many stores. Any minerals in water added to the radiator can cause death to the aluminium radiator core- they accumulate in the small passages and reduce the rate of flow, causing overheating.
cwb48 is offline   Reply With Quote
Old 12-15-2013, 12:50 AM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The car already has anti-freeze. DO NOT TOP OFF COOLANT WITH NON-GENUINE SUBARU COOLANT OR NON GENUINE TOYOTA BLUE COOLANT. The factory fill lasts for 11 years. It will be shortened if topped off with other coolants (Peak, Prestone,etc)
Old 12-15-2013, 01:11 AM   #8
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
I've read the other messages in this thread, but still not sure if this is sarcasm or...? 11 years?
mike_ekim1024 is offline   Reply With Quote
Old 12-15-2013, 01:15 AM   #9
N1rve
N1rve's Avatar
That's what the Manual reads.
Edit:
First Coolant Service is 11 years or 137k Miles. Whichever comes first.
It will be shortened if you mix the coolant with something else (non OEM).
The Following User Says Thank You to N1rve For This Useful Post:
suaveflooder (12-15-2013)
Old 12-15-2013, 01:23 AM   #10
mike_ekim1024
Interesting. I just topped off today.. better check my coolant. Sound like if you do use other coolant it needs to be changed more often..
http://www.ft86club.com/forums/showthread.php?t=7216
Old 12-15-2013, 01:23 AM   #11
N1rve
N1rve's Avatar
Here's a snap of the manual.
It says 137,500 miles OR 132 Months (11 years)
After that, replace every 72 month or 75,000 miles.
The Following 2 Users Say Thank You to N1rve For This Useful Post:
humfrz (12-15-2013), mike_ekim1024 (12-15-2013)
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
HELP!!! I SMELL ANTIFREEZE ravenblackfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 04-30-2016 10:36 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 12:46 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
