Old 11-25-2012, 09:24 AM   #1
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
HELP!!! I SMELL ANTIFREEZE
I've noticed that after driving the car and getting it fully warmed up. Lets just say about 30 miles. When I stop at wherever I may be going, I smell antifreeze if I roll the windows down or if I get out. Its not a SUPER STRONG smell, but its enough that I can smell it. There are NO LEAKS on the ground... and there is NO STEAM coming from under the hood. I don't see any visible wet areas under the hood. I have not checked clamps from the radiator to the block nor the block to the radiator return line. That will be my first step.
ravenblackfrs is offline   Reply With Quote
Old 11-25-2012, 09:38 AM   #2
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Check to see if your passenger floor mat is damp. I had a heater core issue on my WRX which caused coolant to leak into the cabin -- along with smells of coolant and a lovely sugary coating on everything in the vehicle.
cobrabyte is offline   Reply With Quote
Old 11-25-2012, 09:44 AM   #3
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
how many miles have you put on the car since you purchased?
DanoFA20 is offline   Reply With Quote
Old 11-25-2012, 09:46 AM   #4
ravenblackfrs
Approx. 3100 give or take a couple miles.
Old 11-25-2012, 09:51 AM   #5
ravenblackfrs
I don't notice it when the doors are shut... I cant smell anything like antifreeze. But if I roll the windows down or stop and get out of the car... then I can smell it. And the heat blows just fine btw.
Old 11-25-2012, 12:21 PM   #6
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Most likely a very small leak somewhere in the engine compartment. Check all the hose clamps and water pump bolts. Could even be the radiator cap.
My wife's car a 2002 PT Cruiser had this smell and I could never find the source. I put in 4oz. of liquid Bars Stop Leak and took a long drive. That was years ago and it's still odor free.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 11-25-2012, 04:31 PM   #7
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Make sure the overflow tank isn't over filled. It could be burping out of that if it has been over filled, perhaps during PDI.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 12-02-2012, 05:08 PM   #8
telamon
telamon's Avatar
Drives: CBS BRZ
I recently test drove an FR-S and it also had an antifreeze smell when I was blasting the heat.
telamon is offline   Reply With Quote
Old 03-07-2013, 05:47 PM   #9
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Was there any resolution to this?
1010110 is offline   Reply With Quote
Old 02-24-2014, 09:28 AM   #10
mrnurse
Drives: 2013 scion FR-S
Did you ever get an answer to what was going on? I took mine into the dealer when we were picking up my wife's Camry for service. Mentioned it to the service advisor and he said to bring it in to have it checked out. I was there in it so I pulled it up to the service drive. Popped the hood and we were both hit with a strong wave of coolant smell. I left it there and now after four tris back with my engine removed at least twice, my dash "accessed" at least twice, pressure tested every time, coolant smell verified every time, toyota training center communicated with on last visit and scheduled visit march 3rd for toyota engineer ( only because I talked with GM about my issues) I have been told the problem with my scion is it has a Subaru engine in it, the coolant is different and has a lower boiling point and I'm smelling the coolant flash off out of the strange venting system Subaru uses, I have a sensitive nose, this is normal, if you want to trade your car in I can set you up with a salesman, you should go to another dealer and see if they can fix it and go drive the hell out of it if you blow the motor we replace it under warranty. I'm pretty pissed at the service I have been getting and quite frankly I really just want to get out of this car. Oh and also with all the visits to the dealer I now have a rattle trap when I drive down the road
mrnurse is offline   Reply With Quote
Old 04-30-2016, 09:36 PM   #11
Reedarobinson
Drives: 2014 Scion FRS MONOGRAM
Hello,
Did you ever get a factual answer for this problem? I'm in League City and Mac Haik is jerking me around as well.
Thanks, Reed R
Reedarobinson is offline   Reply With Quote
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
Smell after highflow cat? xn7485 Issues | Warranty | Recalls / TSB 8 11-20-2012 02:40 PM
Anyone else smell rubber? pinoyplaya BRZ First-Gen (2012+) — General Topics 15 09-24-2012 03:40 AM
strange smell - kerosine karlos13 AUSTRALIA 7 08-20-2012 12:50 AM
Clutch/brake smell mr2lor Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 01:45 PM
