Old 12-12-2013, 05:53 PM   #29
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Okay, what's the flow on these things? I don't know how dual injection works, but on single injection cars with ~500cc injectors people were running 1000cc PLUS injectors to get that kind of horsepower.
I guess really it's about how much overhead there is on stock injectors at HP level. I imagine IDCs are just about maxed?
Just realize you have 8 injectors, not 4. Yes the ports are small at about 225cc or something like that, but add in those direct injectors which maybe close to say ~ 400cc (relative guess) in comparison to port injectors. Now you have yourself what seems like another 600+ cc.
There is a way to run them both with EcuTeK RaceROM, as you need the custom mapping to be able to run 8 injectors versus 4. Basically I found a way to do it and you are the first person to ever really comment on it and ask. So thanks for asking.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Lawnik (12-12-2013), whataboutbob (12-12-2013)
Old 12-12-2013, 09:25 PM   #30
Astroboy
Astroboy's Avatar
Drives: None
Is this w/ the intercooler? I'm getting this set up
Astroboy is offline   Reply With Quote
Old 12-12-2013, 09:58 PM   #31
Turdinator
Señor Member
Turdinator's Avatar
Cheers,
William Knose
Just so I am clear on this, the stock tune has either port or direct injection running at any time? It doesn't blend between the two?
1974 TA22 Celica
2013 86 GT
Old 12-12-2013, 10:02 PM   #32
xxscaxx
Drives: 2013 SWP BRZ
At first there were no check engine lights just a weird hiccup at about 6K RPM's under heavy load in 5th gear. Not really anything serious but could never determine what it was. So we ignored it.
After a while it became more pronounced and started throwing P0352 codes for coil pack malfunction on cylinder 2. So we replaced it with the spark plug and all was good.
Cheers,
William Knose
hm...I wonder if this is the issue i'm having. Every once and a while I get what feels like a hesitation or better yet like traction control kicks on with no light, then goes right back to power. I have tried to capture it on a damn data log but every time I do so, it seems I can never catch it lol.
I originally thought it could be a vacuum leak or something. Guess I will have to keep my eye out for this.
What other leak issues have you encountered, other than the few that have been documented on the forums?
xxscaxx is offline   Reply With Quote
Old 12-12-2013, 10:28 PM   #33
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Good job Bill
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 12-12-2013, 10:41 PM   #34
whataboutbob
AutoX-10/10ths every run
Originally Posted by swift996 View Post
Just curious if this is on a stock clutch/flywheel? I haven't upgraded mine yet and know that's pushing the limits.
Yes. Owner has 16k on OEM parts. Only a matter of time before time for an upgrade.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
DriftEm (12-13-2013)
Old 12-12-2013, 10:43 PM   #35
whataboutbob
Yes.
Build thread:Here
Astroboy (12-13-2013)
Old 12-12-2013, 10:47 PM   #36
jamesm
No, the stock system uses either or both at any given time, and there are a few tables that control the ratios at a given load/engine speed for different coolant temperatures.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
mad_sb (12-15-2013), Turdinator (12-13-2013)
Old 12-13-2013, 02:28 AM   #37
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
So that's about 10 more Whp than robispec innovative that had no IC?
http://www.delicioustuning.com/node/152
Mars2 is offline   Reply With Quote
Old 12-13-2013, 10:09 AM   #38
phloozy
phloozy's Avatar
Drives: Scion FR-S
Awesome job! Can't wait to get back to modding in the spring.
phloozy is offline   Reply With Quote
Old 12-13-2013, 11:01 AM   #39
DeliciousTuning
Not completely the whole story.
This one also has a catalytic converter and intercooler. Slightly different.
Too boot we pushed Robi's to the bleeding edge for the track, where as the tune in this post is far more realistic for the daily driver.
Cheers,
William Knose
DriftEm (12-13-2013), whataboutbob (12-14-2013)
Old 12-15-2013, 04:51 AM   #40
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Cheers,
William Knose
Bill, you not going to believe, after 2 weeks of a fixed no leak SC, CEL came on PO351 Ignition Coil Primary/secondary circuit.
Ryan86 is offline   Reply With Quote
Old 12-15-2013, 10:41 AM   #41
mad_sb
Drives: 2013 Asphalt FR-S
Hi All,
Well we managed to break the 300 whp mark with the Innovate Supercharger with some basic upgrades and FlexFuel E85 with EcuTeK RaceROM. With a lot of fine tuning on this car is able to hit 300+ wheel horsepower on a DynoJet Dyno.
Whats happening from 6500 and up? Everything looks perfectly happy up to that point. If it were pump gas i would say knock retard but on corn that is less likely.
Old 12-17-2013, 10:28 PM   #42
DeliciousTuning
Finally got a chance to look at the logs again. Basically the timing is going flat at this point. I also believe there maybe an airflow limitation on the intake, though I can not verify that, but the airflow values are also pretty flat at this point.
I have another intake from a reputable vendor coming in that I will be testing on my vehicle soon. Along with the a supercharger or two or three.
Also working on some turbo kit tunes next. AVO is one we have been developing with multiple boost map options. But we have a coupe other kits we are looking into also.
Lot of new developments for next year so keep an eye out.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
DriftEm (12-17-2013), mad_sb (12-23-2013), whataboutbob (12-17-2013), xjohnx (12-17-2013)
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! Circuit Motorsports Forced Induction 91 10-24-2013 12:07 PM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
p000d CEL+Innovate supercharger MattF Forced Induction 13 08-16-2013 12:22 AM
