Old 12-09-2013, 04:07 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
HKS Kansai carbon driveshaft coming - lighter than current carbon drive shafts
No pricing, still in development (I checked again this morning)
Weight is claimed to be 4.2kg, which is at least 1kg lighter than the current carbon driveshafts available.
Will post when I know more.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
OICU812 (12-10-2013)
Old 12-09-2013, 04:43 PM   #2
bakerr6
Drives: 2013 raven black fr-s
would love to have a ds this light, but not looking to spend 2k on this type of part atm.
Still, I'm liking where they are going. Thanks for posting this
bakerr6 is offline   Reply With Quote
Old 12-09-2013, 05:26 PM   #3
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
How do you know it'll be 2k?
chiefshayan is offline   Reply With Quote
Old 12-09-2013, 06:00 PM   #4
xDanger_208x
xDanger_208x's Avatar
Drives:
3 letters...
H
K
S
xDanger_208x is offline   Reply With Quote
The Following 11 Users Say Thank You to xDanger_208x For This Useful Post:
charged86 (12-13-2013), FirestormFRS (12-29-2013), flippy (04-09-2014), Freeman (12-10-2013), Ganthrithor (04-09-2014), GT86_PRAGUE (10-08-2015), hamzam (01-20-2014), Pekingduck (10-18-2014), SpeedR (12-10-2013), wparsons (01-20-2014), z3ro (12-29-2013)
Old 12-09-2013, 06:11 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by xDanger_208x View Post
3 letters...
H
K
S
+ Kansai.
http://www.kansaisv.co.jp/index.html
http://www.kansaisv.co.jp/demo_car/p...odel=democar_1
Everything put on the car is $$$.
-alex
Old 12-09-2013, 08:10 PM   #6
slava
slava's Avatar
Drives: brZed
Man thats pretty
slava is offline   Reply With Quote
Old 12-09-2013, 08:15 PM   #7
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Carbon prop shafts for S2000 costs about 390000~450000yen so I think price should be around there.
AJ PwR is offline   Reply With Quote
Old 12-09-2013, 08:22 PM   #8
ciro
Drives: Scion FR-S
Finally a company uses the correct weave.
ciro is offline   Reply With Quote
Old 12-10-2013, 12:21 AM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Why is this the correct weave and by inference the others incorrect weave?
Old 12-10-2013, 01:43 AM   #10
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
This is interesting. As I've tried a cf shaft let me explain what I hope this shaft has difference wise. I had a DSS shaft great piece btw. Acceleration and lack of slop was fantastic. No vibration or drive ability issues per say. Only I'm very sensitive "hearing wise" when I'd get to around 70-85mph there would be an air like noise, super hard to explain. Again no vibes etc but to me it was so different it was strange. Now I spoke in great length to some folks that had same concern again only hearing and they had their custom with microballs of styrofoam so like an acoustical filler if you will inside the shaft. I wonder if this shaft comes with any sort of coustic filler???
My other concerns is their glue and what rpm they're balanced to and how their balanced. Good find though gonna sub for updates thanks!!
The Following User Says Thank You to OICU812 For This Useful Post:
Old 12-10-2013, 09:10 AM   #11
ciro
Drives: Scion FR-S
I'm not going to get to much into this but it is basically the angles of the threads and how they braid the threads. The only reason I think this is done better is from reading lots about carbon fiber and how to make it stronger in different directions. Other shafts I have seen use unidirectional weave which is awesome for body panels and random parts made from carbon fiber but not in a shaft that is receiving really only torque and no other stresses.
Sent from my HTCONE using Tapatalk
Old 12-10-2013, 12:29 PM   #12
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Carbon fiber is a lot like wood - it's not uniformly strong in all directions. It's much stronger along the grain/weave than it is perpendicular to it. For a shaft loaded in torsion (in other words, pretty much every driveshaft ever made), the maximum loads will be at a 45 degree angle to the shaft. So, for a carbon fiber part (or fiberglass), you want the fibers to be wound at a 45 degree angle for the best strength with the minimum amount of material. Since it can be loaded in either direction (acceleration or engine braking), you want fibers wound around it in both directions, at 45 degrees. You can see this in the shaft above.
For some reason (that I do not understand), many carbon driveshafts instead have the fibers wound very nearly circumferentially, at least at the surface of the driveshaft. This gives very little strength against a twisting load (but it would be great for a pressure vessel, like a composite scuba tank). They must have fibers in some other orientations internally as well, to give them the necessary strength, but even so, the fibers wound circumferentially at the surface are doing almost nothing aside from adding weight - for a driveshaft, you really want all of the fibers at or near 45 degrees (you could maybe make a case for varying the winding angle between perhaps 30 and 60 degrees in the various layers, but even that isn't really necessary).
This also probably explains why they can make it lighter than other CF driveshafts. They also could be using a higher grade carbon - all CF isn't created equal. A standard carbon fiber might have a modulus (stiffness) of around 230GPa and a strength of around 3.5GPa, while a high modulus carbon will have a similar strength and a modulus of around 550-600GPa (so it's 2 or 3 times stiffer, but not a lot stronger). A high strength carbon fiber on the other hand might have a modulus around 300GPa (only a bit stiffer than the basic stuff), but an ultimate strength of around 6GPa or even a bit more (so nearly twice as strong as the basic carbon fiber). Of course, the high stiffness and high strength carbon fibers are a lot more expensive than the ordinary carbon, but using them can significantly improve the strength and stiffness (or reduce the weight for the same strength and stiffness) compared to a component made with basic CF.
chrisl is offline   Reply With Quote
The Following 12 Users Say Thank You to chrisl For This Useful Post:
akyp (12-11-2013), Captain Snooze (12-10-2013), ciro (12-10-2013), dem00n (12-10-2013), flippy (04-09-2014), Freeman (12-10-2013), Ganthrithor (04-09-2014), GT86_PRAGUE (10-08-2015), JohnJuan (10-17-2014), OICU812 (12-25-2013), Pekingduck (10-18-2014), SubiePig (12-11-2013)
Old 12-10-2013, 04:57 PM   #13
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Sick looking CF DS, this will be easily $2k or higher like others said HKS Kansai
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 12-10-2013, 07:30 PM   #14
Turdinator
Señor Member
Turdinator's Avatar
Interesting info
Could the circumferentially wound carbon be a safty measure, to hold the shaft together better at high rpms?
1974 TA22 Celica
2013 86 GT
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
We have carbon drive shaft, yno carbon axles? diss7 Engine, Exhaust, Transmission 2 10-26-2013 09:40 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
Are dry carbon fiber front 1/4 panels lighter than OEM? Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 5 05-27-2013 03:47 AM
HKS Kansai - Carbon Fiber lip spoiler Citrus Cosmetic Modification (Interior/Exterior/Lighting) 6 02-10-2013 11:02 PM
