View Poll Results: Which square or staggered setup should I go with?
18x9.0 +44 (square) 22 28.57%
18x8.5 +43 (F) / 18x9.0 +44 (R) (used on TWS demo car w/ recommended 245/35R18 square tires) 5 6.49%
18x8.5 +43 (F) / 18x9.5 +45 (R) 16 20.78%
18x9.5 +45 w/ 245/35R18 tires (square) 7 9.09%
18x9.5 +45 w/ 255/35R18 tires (square) 27 35.06%
Voters: 77. You may not vote on this poll
Old 12-09-2013, 11:04 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by BlueDubbinTDI View Post
I think the 18x8.75 et33 square from the XXR 530s looks sick! I've decided this is what I'm doing. 225/40 or 235/40 cant decide though
I'd go 245/35-18. OEM tire diameter, 0.7" shorter (better gearing) than 235/40, same weight (sometimes lighter), and of course wider.
225 on an 8.75" wheel seems like underutilizing the wheel width to me...
BlueDubbinTDI (12-09-2013)
Old 12-09-2013, 11:16 AM   #16
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
How would that effect price? 225/40s are cheap. Also, would that still be safe for the front? Thanks though!
Old 12-09-2013, 11:58 AM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Can't say about fitment, but I would *think* that with camber bolts and increased negative camber 245/35-18s should clear. 235/40 might be more likely to rub due to greater diameter.
If price is a factor, get 17s! 245/40-17s are going to be $20-$60 cheaper than 245/35-18s.
Old 12-09-2013, 12:05 PM   #18
BlueDubbinTDI
Naw its 18s or continue saving Ive decided. 530s as well I believe. And yes Ive seen pics now with 245/35s square and they do indeed fit. Ill get camber bolts for the front and leave the rear at natural camber. On sportlines they look real nice!
Old 12-09-2013, 12:26 PM   #19
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Absolutely go with a square setup. It makes life 1000x easier! Being able to rotate tires is a huge advantage and a lot easier on the wallet in the long run. I personally am looking for a 17x9 setup with 255/40r17's on all four corners.
For what you're looking at, I'd do 18x9.5 square and run 265/35r18's. Should be beautiful.
...I know all too well the hassels of running a staggered setup (double staggered on my mr2).
hmong337 is offline   Reply With Quote
Old 12-09-2013, 01:35 PM   #20
djdnz
1337
Drives: 2013 BRZ WRB S/C
I vote the 9"+44, w/ 245/35/18.
Second choice would be the 9.5"+45 w/ 255/35/18
9.5 will require a bit more camber to make flush. The 9"+44 requires very little camber to be flush. I have 9" +42, and run 1.7deg front, 1deg rear and it is very flush. If you get the 9.5 you will need more camber.
The 9.5 will add weight as well, and depending on your power goals might be overkill.
The 8.5 will be tucked at that offset.
The 9 is a good balance between flush and weight.
djdnz is offline   Reply With Quote
Old 12-09-2013, 01:39 PM   #21
OrbitalEllipses
Drives: Attitude
I believe 9.5" is where you start running into possible clearance issues with the stock spring perch. @King Tut should have input on that.
Old 12-09-2013, 01:53 PM   #22
FR-S Matt
I ran 18X9.5 +38 on 245/35/18 with stock suspension for a bit. It was about | | far from hitting the spring with the tire. Any offset higher than that will rub with stock suspension. 100% confirmed. I even low trac'd on hard corners sometimes till I switched to Tarmac 0 coilovers. All problems went away after that and I even feel my handling increased by going a bit lower and wider.
The Following User Says Thank You to FR-S Matt For This Useful Post:
chanomatik (12-09-2013)
Old 12-09-2013, 02:47 PM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What tire? Different sidewall design will affect the clearance, sometimes too close for comfort.
-alex
Old 12-09-2013, 03:03 PM   #24
FM Wheels
FM Wheels's Avatar
Drives: a car with nice wheels.
I will have coilovers so inner clearance won't be a problem
Correct me if I'm wrong, but on most cars coilovers reduce inner clearance because the coilovers are thicker than struts and the springs sits lower. Those offsets seem a bit high for them to clear.
Like this...
FM Wheels is offline   Reply With Quote
Old 12-09-2013, 03:14 PM   #25
FR-S Matt
-alex
Continental ExtremeContact DW's
Old 12-09-2013, 03:25 PM   #26
mav1178
mav1178's Avatar
Like this...
Incorrect, most coilovers will be like this:
My stock front strut vs Ohlins.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
chanomatik (12-09-2013), djdnz (12-09-2013)
Old 12-09-2013, 05:29 PM   #27
FM Wheels
FM Wheels's Avatar
What I mean is where there wheel ends up, the space between the mount and the spring perch. I would like to see how 18x9.5 +45 would fit on the front with coil overs.
Old 12-09-2013, 05:32 PM   #28
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah was gonna say generally they're significantly thinner.
WheelDude.com | Rota Torque - Staggered and Square setup - IN STOCK and ready to ship WheelDude.com Wheels and Tires 6 08-20-2013 09:34 PM
Square vs staggered setup slowbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-11-2013 10:18 PM
Staggered wheels + square tyre setup? white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-18-2013 09:27 AM
Staggered vs. Square WWEVOX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-12-2013 03:57 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 09:40 PM
