Old 12-06-2013, 09:03 AM   #183
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by Malt View Post
66 degrees this morning and it almost cranked right up. If I had given it a little tap of the gas pedal during the 2-3 seconds the idle was stumbling it probably would if been fine. It cranked just fine on the second attempt.
So we're close. The next part is to add fuel to the cranking enrichment table? Suggestions as to how much to add since I reset everything back to 0 like suggested?
Sent from my SCH-R970C using Tapatalk
Good to hear!
Well the RPM table is zeroed stock - but maybe give it a little bit of compensation - trial and error I guess until it ticks over no problem.
Td-d is offline   Reply With Quote
Old 12-06-2013, 11:37 AM   #184
jeebus
Has anyone running e85 had their AM move down? Mine had been rock solid at 1 until today. 42 degree morning, car took a bit of extra cranking (it's in a garage so no too bad). After idle stabilized I drove off slowly as I normally do. About 2 blocks away I hear loud det. Then I heard it again. So I hooked up my OF and saw the AM had dropped to .93 (I know, not terrible). I didn't hear any det from that point on but I drove carefully for the first 15 miles (40 mile commute). I loaded it up a little and the AM went up to .96. I loaded it up again but it dipped to .90. By the time the temps got into the 50s outside, loading up the motor got AM back to 1.
For reference, this tank of e85 has my LTFT a tad on the lean side (4% or so). WOT pulls are also a little leaner that I'd prefer...staying high 12s up top. This is the first tank of e85 that I haven't added a gallon of 91 to. The other tanks seemed way too high E content.
jeebus is offline   Reply With Quote
Old 12-06-2013, 12:48 PM   #185
WRB5titch
Drives: WRBrz
I haven't encountered the same problem as you have. But then again, I've been adding a gallon of 91 to the tank on the last couple fill ups...
I'll try going pure e85 on my next tank and post an update later.
WRB5titch is offline   Reply With Quote
Old 12-06-2013, 04:39 PM   #186
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
Originally Posted by Hanni_0176 View Post
Installed the OFT tonight. Drove around for a bit, and noticed that my traction control and ABS lights were on, on the dash... I did some datalogging with both the OFT and Torque Pro (not at the same time), and this was the CEL issue:
Stage 1 v1.34
Vehicle Calibration ID: ZA1JA01C
Pending Fault Log
P0462: Fuel Level Sensor Circuit Low Input
I drove it home, shut off the car, and then turned the car back on. The displays on the dash are no longer there. I'll check again tomorrow, and run another diagnostic on it.
The car felt fine during the drive, no weird noises, no bogging. I didn't really notice a difference from v1.33, but it definitely didn't feel worse. Hopefully I don't get any more CEL issues.
After I get some more driving in and my ECU adjusts some more, I'll post up my opinions/reviews. Also, if the CEL pops again, I'll let everyone know.
I just got this code after being on E85 for 40 miles.
Terrapin77 is offline   Reply With Quote
Old 12-06-2013, 04:42 PM   #187
Rombinhood@OpenFlash
Drives: FRS
I don't see how E85 itself can trigger a fuel level sensor code. I would just clear the code with the OFT and see if it comes back.
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-06-2013, 05:03 PM   #188
Terrapin77
Terrapin77's Avatar
Code has been cleared. However, right after I got the code, I topped of my tank with more E85. The needle on my gas gauge didn't go to full. I hope my gas gauge isn't fried.
Old 12-06-2013, 09:03 PM   #189
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
I've been having cold start issues too. Second tank of e85. Last two difficult starts have results in a loud pop before it fired up. Not sure what the sound was if it was detonation or something else. Might switch back to reg gas if this persists at least until the weather warms up.
Will adding a gallon of reg gas on a tank of e85 really make cold starting easier. Wouldn't that make it less than e85, more like e78 assuming you start with actual e85?
garfull is offline   Reply With Quote
Old 12-06-2013, 09:06 PM   #190
Drives: FRS
That pop was just a minor backfire and is not terribly uncommon during cranking conditions when running e85 in cold temps. Nothing to worry about. That is very different than detonation which is harmful.
Old 12-06-2013, 09:10 PM   #191
garfull
garfull's Avatar
I hope its just a backfire because the pop sound seem like it was coming from the engine bay not the exhaust. I will open the windows on the next cold start and pay better attention.
Old 12-06-2013, 09:17 PM   #192
Drives: FRS
If it's coming from the engine bay, it's intake backfire. Same concept as exhaust backfire but just initiates in different points in the combustion process. In the case intake pop/backfire, it's usually caused during cranking while running insufficient timing. In the case of E85 in cold weather, this can be induced because the air/fuel charge is harder to ignition at start up.
Detonation is a completely different beast altogether and won't happen at cranking speeds and low engine loads.
With E85, there is always going to be some degree of cold start crankiness in the winter. This is the case on everything platform I've run E85 on (GTR, Evo, Suby, etc,.) Especially with E85 mixes that high unusually high E content (as we are seeing lately in CA at least). But once you are past the few seconds of running, everything should be fine. But if this initial cold start issue is irksome, no harm in just running gasoline until temps warm up a bit.
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post:
garfull (12-06-2013)
Old 12-06-2013, 11:59 PM   #193
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
First day with stage 1 OFT loaded - should I be concerned that my AFR drops to 11.25 during a WOT run?
Vishnu said that Ign Advance should be in Mid 20s
Mine ranges from 29.5 down to 26 (mid to high 20's)
Vishnu said that AFR should be mid 12's
Mine ranges from 12.75 down to 11.25
Automatic
91 Octane gas
K&N Drop-in
Nameless Combo pipe with high flow cat
NVidia Q300
Image of Log
nlowell is offline   Reply With Quote
Old 12-07-2013, 03:13 AM   #194
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Soft Rev Limit
Received my OFT a few days ago and tonight I was out testing the 1.34 map; specifically the soft rev limit and to my surprise it did not change from the normal fuel cutoff at 7400. I was doing a WOT pull in first and rung it out expecting a slight rev limit bounce and was greeted a power loss. I didn't try second gear because I assumed the same thing would happen.
Anyone else have this issue? Which chart/table should I be checking for the soft rev limit? What should the settings be?
Thanks in advance!
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 12-07-2013, 05:03 AM   #195
Malt
Drives: 2015 WRX
Thanks in advance!
That's not an issue, that's how Shiv made the maps to implement a soft rev limit.
Malt is offline   Reply With Quote
Old 12-07-2013, 08:17 AM   #196
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Automatic
91 Octane gas
K&N Drop-in
NVidia Q300
Image of Log
Same as mine with stage 2 1.34B ROM (EU ROM: ZA1J700G).. here
http://datazap.me/u/burn/first-3-gea...7-8-9-10-11-12
Burn is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
