#183 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Well the RPM table is zeroed stock - but maybe give it a little bit of compensation - trial and error I guess until it ticks over no problem. |
#184 |
Has anyone running e85 had their AM move down? Mine had been rock solid at 1 until today. 42 degree morning, car took a bit of extra cranking (it's in a garage so no too bad). After idle stabilized I drove off slowly as I normally do. About 2 blocks away I hear loud det. Then I heard it again. So I hooked up my OF and saw the AM had dropped to .93 (I know, not terrible). I didn't hear any det from that point on but I drove carefully for the first 15 miles (40 mile commute). I loaded it up a little and the AM went up to .96. I loaded it up again but it dipped to .90. By the time the temps got into the 50s outside, loading up the motor got AM back to 1.
For reference, this tank of e85 has my LTFT a tad on the lean side (4% or so). WOT pulls are also a little leaner that I'd prefer...staying high 12s up top. This is the first tank of e85 that I haven't added a gallon of 91 to. The other tanks seemed way too high E content.
#185 |
Drives: WRBrz
I haven't encountered the same problem as you have. But then again, I've been adding a gallon of 91 to the tank on the last couple fill ups...
I'll try going pure e85 on my next tank and post an update later. |
#186 | |
Drives: 2013 Argento FR-S
#187 |
Drives: FRS
I don't see how E85 itself can trigger a fuel level sensor code. I would just clear the code with the OFT and see if it comes back.
#188 |
Code has been cleared. However, right after I got the code, I topped of my tank with more E85. The needle on my gas gauge didn't go to full. I hope my gas gauge isn't fried.
#189 | |
Drives: FRS(sold), AP2, R35, FJC, ED9
I've been having cold start issues too. Second tank of e85. Last two difficult starts have results in a loud pop before it fired up. Not sure what the sound was if it was detonation or something else. Might switch back to reg gas if this persists at least until the weather warms up.
Will adding a gallon of reg gas on a tank of e85 really make cold starting easier. Wouldn't that make it less than e85, more like e78 assuming you start with actual e85? Quote:
#190 | |
Drives: FRS
#191 |
I hope its just a backfire because the pop sound seem like it was coming from the engine bay not the exhaust. I will open the windows on the next cold start and pay better attention.
#192 | |
Drives: FRS
Detonation is a completely different beast altogether and won't happen at cranking speeds and low engine loads. With E85, there is always going to be some degree of cold start crankiness in the winter. This is the case on everything platform I've run E85 on (GTR, Evo, Suby, etc,.) Especially with E85 mixes that high unusually high E content (as we are seeing lately in CA at least). But once you are past the few seconds of running, everything should be fine. But if this initial cold start issue is irksome, no harm in just running gasoline until temps warm up a bit. |
| The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post: | garfull (12-06-2013) |
#193 |
Drives: 2013 Scion FRS
First day with stage 1 OFT loaded - should I be concerned that my AFR drops to 11.25 during a WOT run?
Vishnu said that Ign Advance should be in Mid 20s Mine ranges from 29.5 down to 26 (mid to high 20's) Vishnu said that AFR should be mid 12's Mine ranges from 12.75 down to 11.25 Automatic 91 Octane gas K&N Drop-in Nameless Combo pipe with high flow cat NVidia Q300 Image of Log |
#194 |
Drives: Sc10n FRS "DCLXIV"
Soft Rev Limit
Received my OFT a few days ago and tonight I was out testing the 1.34 map; specifically the soft rev limit and to my surprise it did not change from the normal fuel cutoff at 7400. I was doing a WOT pull in first and rung it out expecting a slight rev limit bounce and was greeted a power loss. I didn't try second gear because I assumed the same thing would happen.
Anyone else have this issue? Which chart/table should I be checking for the soft rev limit? What should the settings be? Thanks in advance!
Sc10n FRS #0664
#195 | |
Drives: 2015 WRX
#196 | |
Slack Bum
Drives: FT86
http://datazap.me/u/burn/first-3-gea...7-8-9-10-11-12 |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 10:03 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
