Old 12-05-2013, 01:04 PM   #155
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by Malt View Post
I'm just going to swap back to the normal stage 2 maps until shiv has time to get the E85 maps fully functional for cold starting. As it stands right now, they are not. I can't expect him to drop everything to fix my issues and I'm obviously over my head in this whole modifying my own tune thing seeing how I can't get romraider to work and tunerpro doesn't seem to have the tables I need to adjust to fix this.
I appreciate your help but for now the fact that I can't get my car to start like normal when its 65 degrees outside is unacceptable to me. Maybe I'll try E85 again in the summer.
I'm a little confused now - if you didn't manage to get RR working, how did you edit the cranking pulse width tables (the 3d ones are the main ones)? If you send me your rom, I can edit it for you if you still want to give it one last shot.
Sent from my iPad using Tapatalk HD
Td-d is offline   Reply With Quote
Old 12-05-2013, 01:07 PM   #156
jamesm
not related to the openflash maps, but i switched to e85 this morning and i'm loving it! very simple to convert my pump gas map. it's amazing how much smoother and stronger it is with no changes beyond scaling. i'll be going on the dyno soon to up the boost and fine-tune the timing. exciting!
Old 12-05-2013, 02:05 PM   #157
Malt
Drives: 2015 WRX
I used Tuner Pro to adjust the cranking pulse width tables that were accessible with the definition files that shiv has provided. It's quite possible that I'm not adjusting the right tables which is why I'm still having issues. I'd love to get romraider working so when I get home I'll try to get it working again.If I can't get it working I'll send mine to you too adjust, thanks.
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
Old 12-05-2013, 02:24 PM   #158
Td-d
No problem - let me know, happy to help in editing the map and to help you set up romraider.
The Following User Says Thank You to Td-d For This Useful Post:
Malt (12-05-2013)
Old 12-05-2013, 03:47 PM   #159
Malt
Drives: 2015 WRX
Just took some logs. This is when the engine is at operating temperature. http://www.datazap.me/u/malt/12-5-13?1-2-8-9-11
Unfortunately I don't have any logs of cold starts.
I've noticed that my LTFT's have gone from 3.2ish at the start of this tank down to -1.56 today. I'm wondering if I just got a tank of bad E85 as the first tank I put in had absolutely no issues with the standard Stage 2 E85 maps shiv provided. I filled back up and I've had issues starting ever since.
As for getting rom raider working. I've got it installed and I went to ECU definition manager and added the XML file ZA1JA01C that I downloaded from shiv's site. When I go to open the Stage 2 image I get an error message that says "ECU Definition Not Found."
Suggestions or ideas on what I need to do to get RR working. I've got an image of some cold start tables for E85 on one of the threads here from RR, those might work if I could just get it loaded.
Old 12-05-2013, 04:27 PM   #160
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You gonna post your tunes for us to see?
Old 12-05-2013, 04:29 PM   #161
jeebus
I wouldn't be concerned with -1.56 LTFT at all. That's about perfect. I actually prefer my LTFT be on the slightly rich side like that. The reason you are probably having starting issues is it's getting colder outside. My car lives in my garage overnight and I live in SoCal so it doesn't get THAT cold, but even still it takes me an extra handful of cranks to start.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
Malt (12-05-2013)
Old 12-05-2013, 04:39 PM   #162
Malt
Drives: 2015 WRX
I'm not concerned with the -1.56 LTFT, I'm concerned that it went from 0 to 3.8 to 3.2 to -1.56 all in the same tank. Seems a bit weird to me, but what do I know.
My main issue is the cranking when its "cold". I'd prefer it to crank on the first try instead of taking 20+ attempts like the maps that shiv provided at the start of this tank. Maybe I got a tank full of E95 like a couple people in cali had. A couple other members helped out with suggesting to modify the injector pulse width and that helped some, but even still it took 5 cranking attempts to get the car started in 68 degree weather. 68 degrees isn't cold in my book and if that's what I have to look forward to every single day then that's just not something I'm willing to deal with. I had hoped that there was some fix to the issue instead of just going back to 93, which is why I've resorted to asking here since Shiv is banned and didn't answer my email (I'm sure he's busy).
It seems through the conversations here that I've been modifying the wrong tables, but the tables I changed were the only ones available through tuner pro, which is why some people suggested to used romraider.... except I can't get romraider to load using the XML files provided by shiv. Again... its probably something I'm doing wrong.
Old 12-05-2013, 04:51 PM   #163
Td-d
Don't stress about those LTFTs, as long as you're between -5% to 5% (some are comfortable with -8% to 8%) you're good.
Maybe try using the direct source of the XMLs - i.e. here: https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01C.xml
Malt (12-05-2013)
Old 12-05-2013, 04:55 PM   #164
Malt
Drives: 2015 WRX
Should I be getting a Error - Checksums Failed message?
I am using shiv's Stage 2 E85 ZA1JA01C map
Old 12-05-2013, 05:00 PM   #165
Td-d
Yes, that's normal - when you save, it will ask you whether you want to fix the checksum - say yes, and save.
I must actually remind Shiv to save all the OTS tunes with Romraider if they are migrating across, not to alarm users
But from the note, I assume you now can open the rom using Romraider?
Malt (12-05-2013)
Old 12-05-2013, 05:04 PM   #166
Malt
Drives: 2015 WRX
I can, I'm looking at the cranking fuel injector pulse width tables that I found here http://www.ft86club.com/forums/showp...&postcount=643
They look identical to Shiv's standard Stg 2 E85 maps. So where and what should I change to potentially fix my cold start issues?
EDIT: Of course they are identical... derp, that is shivs maps displayed LOL. I hate to be such a bother, but I'm new at this and I'd love to learn how to fix this stuff so I don't have to bother people with my issues. Thanks again for any help.
Old 12-05-2013, 05:11 PM   #167
Td-d
Those logs look pretty decent - you are carrying a small amount of AF learning into open look though (-1.56) which is leaning you out a bit. Basically, the learning from AF learning range D is carried across into open loop - so it's best to have it at zero.
There's a trick to deal with that quite easily - set the af learning range C (the last one) to 60. It will disable learning carrying across into open loop.
Malt (12-05-2013)
Old 12-05-2013, 05:18 PM   #168
Td-d
Mate, it's seriously no bother - we all started off learning somewhere.
Follow mad_sb's directions - multiply those cells where you are having problems (i.e. 32, 50 and 68 in your case I would imagine?) by a factor - try those suggested by mad_sb (i.e. 1.3 for the lower and lower for the 68 cell - 1.2). You have to be careful not to overfuel it, because that also creates problems cranking. Do it on all 6 tables (including the 2D table).
Once we get you sorted here, hopefully you won't have warm restart issues, which can present with E85 as well - but there's a fix for that too
Malt (12-05-2013)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 11:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
