Old 11-13-2013, 09:38 AM   #1933
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by JDM-dono View Post
Will this fit:
- 18x8.5 +33 (all around)
- 235/40R18 (all around)
- 15mm lowering (stock suspension + springs)
No issues at all with wheel fitment, but would recommend 245/35R18 tire size so you maintain the correct diameter. 235/40 are 20mm taller than stock.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
JDM-dono (11-15-2013)
Old 11-13-2013, 09:48 AM   #1934
Slick
Slick's Avatar
Originally Posted by NYCsubaruBRZ View Post
17x8 +35 offset 245/45/17 fits all around no rub
Statement or question?
Wheel size is great but tire size is too tall, consider going to a 245/40R17 tire if you haven't gone to this setup already. Your combo is an inch taller than stock and will affect gearing, acceleration and speedo accuracy.
ill86 (11-20-2013)
Old 11-15-2013, 03:50 AM   #1935
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
no. im letting people know that the combo fits.
even tho my acceleration has decreased im still faster off the line than most brz's with light mods.
not as much wheel spin.
top speed increased.
smoother ride.
speedo is deff way off... reads a lower speed than the true speed.
yes it makes the handling worse 2 cause ur up a bit higher. but i have performance bracing to fix that and its even better. i like a decent size profile tire for the street what can i say?
NYCsubaruBRZ is offline   Reply With Quote
Old 11-15-2013, 04:00 AM   #1936
NYCsubaruBRZ
245/40R17 tire.
i will prob throw on a set of 245/40-17 tires when some shows start up around ny. the tire shop got me on a free set of brand new rubber for the first show(gotta throw on a vinyl window sticker with their logo)
Old 11-16-2013, 12:22 PM   #1937
juanam0909
Drives: scion fr-s
will this fit ?
18X9.75 +20 REAR
18x8.75 +20 front
225/40/18
droped on eibach sportlines ( 1.4 inches )
will i need any adjustments?
juanam0909 is offline   Reply With Quote
Old 11-16-2013, 04:33 PM   #1938
Slick
Slick's Avatar
Originally Posted by juanam0909 View Post
will this fit ?
18X9.75 +20 REAR
18x8.75 +20 front
225/40/18
Maybe, don't know for sure, but check here:
http://www.ft86club.com/forums/showthread.php?t=25171
Both F & R should easily clear the struts though not sure about the fenders.
Old 11-16-2013, 10:38 PM   #1939
ft86me
ft86me's Avatar
Drives: 2013 FRS
quick question. currently have 18x9.5 +38 on 245 40 18 all around. have rear cusco arms and bolts up front for camber adjustments. Also am on KW v3 with drop height that came straight from the box. didnt touch the coils to go lower. the height seemed good to me straight from the box.
rear is currently -1.8 front is -1.3.
Looking to go 18x9.5 +40 so +2 on the offset all around. Will I need to run more camber to make it fit? or will i be fine slapping the tires on the wheels and driving with the current camber setup. thanks guys!
bonus lol: will i be able to fit a larger tire such as a 255 40 18 (i chose this because i only use falken rt615 or nt05) without MAJOR camber adjustments?
ft86me is offline   Reply With Quote
Old 11-17-2013, 05:58 PM   #1940
TRD_86
Drives: 2013 86 white
Need some input from expert regarding just tire & rim fitting question only, assume no rubbing issue. I have a pair of 265x35x18 evo12 and I try to mount it on 18x8.5 rear rim for one of my car, and I plan to order 235x40x18 ev12 to fit on 18x8 front rim. Will that cause any problem for over size tire for the rim. (The oem tire for that was 255 and 225), so it just basically a 10mm bump for each.
TRD_86 is offline   Reply With Quote
Old 11-18-2013, 01:08 AM   #1941
Antheezy
Okay I just ordered some 18x8.5+48 squared weds sport sa-15r. I plan on getting 245/35/18 tires, would this work? Also considering getting 10mm spacers for rears to have equal amount of slight sunk. What do yall think?
Antheezy is offline   Reply With Quote
Old 11-18-2013, 10:02 AM   #1942
RavSpec
Drives: Rx7
Yeah that will work.
RavSpec is offline   Reply With Quote
Old 11-18-2013, 10:03 AM   #1943
RavSpec
Drives: Rx7
It should work but it's major over size.
Best way to find out are visiting the tire manufacturer website and look up the width requirement for the tire. It should give you a range of suggested wheels width.
Mark
Old 11-18-2013, 10:05 AM   #1944
RavSpec
Drives: Rx7
+40mm will sunk in 2mm more which doesn't really change much from your current setup.
So yeah it's fine.
Old 11-18-2013, 10:07 AM   #1945
RavSpec
Drives: Rx7
will this fit ?
18X9.75 +20 REAR
18x8.75 +20 front
225/40/18
With just spring , won't work. Need camber arms .
Front might work, rear major poke.
Old 11-18-2013, 10:08 AM   #1946
RavSpec
Drives: Rx7
Originally Posted by TONYpepperon1 View Post
Looking to fit 57 xtremes 18x9.5 +35 - 245/35/18 all around. Gonna be lowered on RCE yellows. Will these fit in the front the no rub?
It should be +40mm offset, that's the spec for 57xtreme.
Yes will work. Front has plenty of clearance.
The Following 2 Users Say Thank You to RavSpec For This Useful Post:
ft86me (11-18-2013), TONYpepperon1 (11-18-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
