Old 11-14-2013, 12:49 PM   #15
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
OP, have you spoken to a reputable local audio installer? He may be able to get your install debugged for a reasonable fee.
I'd recommend my audio guy to you, but that's a bit long of a drive .
I try and do what I can on the electrical side with my cars, but since I live in an apartment complex, the room I've got to work on my car is a bit limited in space. So, for the stuff I can't do (or to double check my work when that's going to be exposed anyway), I use my local guy. Ensures the work is done right, at least in my case.
^GT5 Replay Photo Mode^
Old 11-14-2013, 12:49 PM   #16
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by #944_10_Series_FRS View Post
This is applied to the factory HU on our car only. it is not applied to aftermarket HU.
I have the factory HU and no, it doesn't do that. I can start the car, drive forward out of my parking space, get to work, shift into reverse, and the cam will come on.
Unless the BRZ is different.
post_break is offline   Reply With Quote
Old 11-14-2013, 12:50 PM   #17
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Damn I wish I had this piece of information before I started...Oh well
So I'll re-wire to tap into reverse light instead I guess...
So my next question...I'll be repairing the amp wire (dark green) so what's a good way to test if it is fully functional or not? In other words...How do I know I have successfully repaired the dark green wire back to stock?
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 11-14-2013, 12:52 PM   #18
tiz22
tiz22's Avatar
And you tapped into the reverse bulb wire?
Old 11-14-2013, 12:53 PM   #19
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Did you use David(ae64) and/or beat sonic's harness?
#944_10_Series_FRS is offline   Reply With Quote
Old 11-14-2013, 12:54 PM   #20
tiz22
tiz22's Avatar
Aside from the initial install, I haven't done anything to troubleshoot what's going on...I simply did the install - saw it wasn't working the way I had planned, and came to this forum (because it was 11pm and that's past my bedtime haha)
When I go back to the wiring tonight, hopefully I'll try a few things and it'll work. If not - I may take up this suggestion
Thanks!
Old 11-14-2013, 01:04 PM   #21
post_break
post_break's Avatar
I tapped into the reverse harness yes, but that's shit for a trigger wire. You could just tap the fuse on the drivers side.
Just a heads up, that reverse wire is only powerful enough to drive the camera and the reverse lights. It doesn't have enough juice to trigger the head unit (at least in my experience).
Nope, I just repinned the stock harness. You honestly don't even need a harness, it's 3 wires. Trigger, RCA in, RCA Ground.
Old 11-14-2013, 01:28 PM   #22
#944_10_Series_FRS
Great to know. Look like the following link from David @ AE64 is misleading then. I used his harness.
http://ae64.com/Rear-camera-16p-operation.htm
Old 11-17-2013, 10:46 PM   #23
tiz22
tiz22's Avatar
Ok for anyone interested I hooked it up tonight successfully!
For the AVIC Z150BH, you need the following wires hooked up to make your reverse camera function properly:
- Red power wire to dark green 12v Amp wire in the trunk
- Black GND wire to a metal bolt (I used one in driver side trunk)
- Yellow RCA (on camera) to brown RCA (on HU) labelled "reverse camera in"
Here is what tripped me up:
- **Red "reverse signal anode input" wire goes to NOTHING
- Lengthen the purple/white wire coming from the accessory connector on HU and attach it to the light pink reverse wire (located driver side wheel-well PIN5)
DONE
Old 12-06-2013, 06:23 AM   #24
JBV88
Drives: 2013 Subaru BRZ
Thank-you!!
I too have been struggling to figure this out. I found a link showing the pink wire:
http://simplicity.elitecaraudio.org/bfrs49.JPG
JBV88 is offline   Reply With Quote
Old 06-21-2015, 10:28 PM   #25
Zhangy
Drives: 2015 FRS
just put the red to reverse pink, and put the black wire to a ground then connect output to where it is suppose to be in the headunit.
"You have to start the car in reverse in order for the camera to work" THIS DOES NOT APPLY IN ANY CASE
Zhangy is offline   Reply With Quote
Old 08-28-2019, 05:19 PM   #26
iconic
Drives: 2015 Scion FRS Auto
For the connection in the footwell 30 pin connector that is 5 down and a pink wire... do I replace this wire with the new wire that is the "reverse trigger wire" that routes to my headunit? Or I do I "t-tap"/splice into this wire?
iconic is offline   Reply With Quote
Old 08-29-2019, 04:38 PM   #27
RickyBobby
Drives: 2013 Firestorm FR-S AT
http://www.ft86club.com/forums/showp...5&postcount=20
RickyBobby is offline   Reply With Quote
Old 08-30-2019, 10:36 PM   #28
iconic
Originally Posted by RickyBobby View Post
I took my car to a radio shop, he wired everything up correctly, the screen still wont trigger when in reverse, i think the reverse trigger wire may be a dud.
reverse camera wiring derka-derka Electronics | Audio | NAV | Infotainment 14 06-16-2015 03:09 AM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
