Drives: Silver GT86
reverse camera wiring
considering getting a cheapo revrse camera on ebay. I got a aftermarket pioneer HU which has a "reverse" wire. where should i wire that to? I believe its a signal wire that tells the HU to switch to Video In when in reverse gear.
thnx |
Drives: Scion FR-S
Hey I'm not really good with cars but you could always go on crutchfield.com and be like "I'm buying your aftermarket camera could you tell me where it goes in my headunit." And they will probably will help you faster!
Drives: Argento 6spd FR-S
Reverse wire is wired to the reverse wire of the car. It senses when you are in reverse to switch to the rear view cam.
You should be fine with most of the ebay reverse cams, most are pretty good quality. |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Tap into the pink reverse light wire running down driver side wire bundle. It is a tiny wire so be careful. You can use this as power for your camera or tie it directly to the back of your Pioneer HU. If you tie it directly, you will need to figure out another way to get your camera power.
Drives: Silver GT86
thnx mit. is the pink wire a signal wire or is it actual 12v +ve wire for reverse lights?
Drives: 2013 Subaru BRZ & 99' Ford Explorer
is there a connection for a reverse camera on the stock BRZ headunit?
#7 | |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Drives: 2013 Subaru BRZ limited
get the reverse camera kit from beat-sonic, check on the groupbuy.
its pretty much plug and play, splicing one wire. |
#9 | |
Skeptic
Drives: 2013 FR-S Ultramarine 6A
It's a little larger in gauge, you have more room to tap into it, and it's a bit more stealthy. TEST FIRST! I installed a JVC audio/GPS system, the backup camera is working like a champ now. Refer to the Subaru BRZ (same as the FR-S) wiring diagram, P. 162. http://www.ft86club.com/forums/showt...wiring+diagram Here's what I did: ![]()
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green Last edited by ChiefG; 12-06-2013 at 12:09 AM. |
#10 |
Orange Wire
What does the orange wire feed? Is it reverse related or an accessory wire?
#12 |
Drives: Subaru BRZ '13 WRB
No need to tap into these wires! Stock BRZ headunit connectors already have reverse wire. It is second pin on largest 28pin connector (first pin is unused - empty). As I recall that wire had orange stripe, but I am afraid to be mistaken. It does give 12V out when in reverse
#13 |
Drives: 2015 Base Scion Frs
Hi, I recently purchased a Scion Frs, and I am going to install a backup camera soon. Does any have suggestions? What brand should I go with? Thanks in advance.
#14 |
Drives: RED LIMITED BRZ
FIT CAMERA
http://www.ebay.com/itm/PLUGandGO-In...a352d2&vxp=mtr
SUBARU MAKES A CLEARER ONE BUT WOULD MESS WITH YOUR WARRANTY |
| Valenti Japen LED Reverse Tailight USDM Wiring | Furtive | DIY (Do-It-Yourself) Guides | 12 | 08-21-2015 09:31 AM |
| FYI - it's possible to add a reverse camera for $20. | SloS13 | Electronics | Audio | NAV | Infotainment | 25 | 09-09-2013 10:03 PM |
| Rear-view camera/reverse cam. What do you have? | joergasm | Audio/Visual, Electronics, Infotainment, NAV | 0 | 05-24-2013 12:25 PM |
| Reverse Camera | FT86_Zero | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-05-2012 08:05 PM |
| Reverse camera? | dorkymork | BRZ First-Gen (2012+) — General Topics | 28 | 05-21-2012 10:21 AM |
