#2157 | ||
NW Region Moderator
Drives: FR-S No More
#2158 |
Drives: 2023 WRB BRZ (MT)
has any1 posted IC numbers yet? i wanna see stage 2 with FULL exhaust (maybe even intake and pulley?)
#2159 |
Drives: 2013 Scion FR-S Manual in Whiteout
I'll have to ask. How would I be able to tell if it was backwards? Is this what happened to you? Is it what was causing you to not see any improvement in IATs?
#2160 | |
Dismember
Drives: 2013 Red Scion FR-S
#2161 |
Mark @ STILLEN
Drives: 2015 Subaru BRZ
^Did the car in that was Edmunds.com drove have a full exhaust and or was everything else on the engine stock?
#2162 | |
Drives: 2013 Black FR-S
| The Following User Says Thank You to sw20kosh For This Useful Post: | lbroskee (11-12-2013) |
#2163 | |
#2164 |
AutoX-10/10ths every run
Took a look at the PPE setup today. Header and overpipe come as a set with thermal coating at a really good price. Thinking this may be a good option, but I'm wondering if it would be worth it to pay for upgraded materials instead of the mild steel stuff.
#2165 | |
Drives: GT86
| The Following User Says Thank You to ft_sjo For This Useful Post: | 1010110 (11-13-2013) |
#2166 | |
Drives: Subaru BRZ
#2167 |
Old...
Drives: Subaru
Quick question---any luck with heat shielding on the bottom of the Sprintex manifold? Other aluminum manifold subies like it.
| The Following User Says Thank You to Subzero For This Useful Post: | Calum (11-13-2013) |
#2168 |
Drives: Flat grey Toyota 86
^This, I would be interested in as well.
Another thing I thought of when inspecting the manifold was a composite spacer to limit the heat transfer from the block. Although I don't think there is room under the stock hood, it could have been designed into the manifold. So anyone willing to machine a composite spacer set and cut a hole in the hood? |
| The Following User Says Thank You to Lawnik For This Useful Post: | KSpider (11-13-2013) |
#2169 |
Drives: Subaru BRZ with Delicious Innovate
Heat travels through aluminum at a crazy speed. And the worst kind of heat transfer is conduction. The manifold is bolted, with a large amount of surface area, directly to the heads. I don't care how much of a heat shield or blanket you use. It isn't going to help. Phenolic spacers might be a better option but without an intercooler you are still generating high temperatures from just compressing the air. The intercooler even looks like it might cool that cast insert which might even help cool the manifold. Long story short. Get the intercooler and make some good phenolic spacers. The charger already gives a "love bite" to the hood so I am not sure there is even room for a spacer.
#2170 |
Dismember
With a 75mm pulley, how much clearance is there to the hood? A 70mm pulley will cut that by 2.5mm. Not a lot. How about the mythical 69mm pulley?
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
