Old 11-12-2013, 03:27 PM   #2157
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by DarrenDriven View Post
Saw these two cars at SEMA with Innovate kits on them... anyone here?
Originally Posted by lbroskee View Post
2nd belongs to Beatsonic i think
Originally Posted by normancw View Post
Hehe... I could have guessed that... wanted to know if the owners were members on this site.
Old 11-12-2013, 03:38 PM   #2158
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
has any1 posted IC numbers yet? i wanna see stage 2 with FULL exhaust (maybe even intake and pulley?)
lbroskee is offline   Reply With Quote
Old 11-12-2013, 05:37 PM   #2159
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Originally Posted by ft_sjo View Post
I hope that wasn't the final fitment if the charge cooler element in the plenum? It appears to be mounted backwards!
I'll have to ask. How would I be able to tell if it was backwards? Is this what happened to you? Is it what was causing you to not see any improvement in IATs?
1010110 is offline   Reply With Quote
Old 11-12-2013, 06:01 PM   #2160
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by swift996 View Post
Not sure if this has been posted but the Edmunds update on their FRS (featuring the intercooled innovate kit):
http://www.edmunds.com/scion/fr-s/20...arger-kit.html
Edmunds' long term dept has fallen apart. I could write more in a week on the FR-S than than write in a year. I don't know why they've crumbled, but it's sad because they used to be a lot of fun.
Old 11-12-2013, 06:54 PM   #2161
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
^Did the car in that was Edmunds.com drove have a full exhaust and or was everything else on the engine stock?
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 11-13-2013, 12:13 AM   #2162
sw20kosh
Drives: 2013 Black FR-S
http://www.ft86club.com/forums/showp...postcount=2085
The Following User Says Thank You to sw20kosh For This Useful Post:
lbroskee (11-13-2013)
Old 11-13-2013, 12:14 AM   #2163
lbroskee
lbroskee's Avatar
Originally Posted by sw20kosh View Post
awesome, can't wait to see it with a good tune
Old 11-13-2013, 12:46 AM   #2164
whataboutbob
AutoX-10/10ths every run
Originally Posted by DeliciousTuning View Post
I would like to see how a PPE header works on the FRS. I have tuned a couple non-forced induction setups with the PPE's and they have really helped the top end power.
Took a look at the PPE setup today. Header and overpipe come as a set with thermal coating at a really good price. Thinking this may be a good option, but I'm wondering if it would be worth it to pay for upgraded materials instead of the mild steel stuff.
Build thread:Here
Old 11-13-2013, 02:04 AM   #2165
ft_sjo
Drives: GT86
The 'I' marked on the charge cooler element is supposed to face the front of the manifold according to the Sprintex instructions. No, I don't believe mine is fitted backwards. Other cars show similar charge cooling performance to mine. Less than ideal, but better than nothing (which I think is their view on this!). I still have more testing to do.
The Following User Says Thank You to ft_sjo For This Useful Post:
1010110 (11-13-2013)
Old 11-13-2013, 12:22 PM   #2166
Ethan
Drives: Subaru BRZ
I don't know about upgraded materials, but I completely agree that is a good price. The HKS header is twice as much with no overpipe. I notice that the PPE is a 4 to1 configuration, while some others like HKS and Nameless are going with 4 to 2 to 1. Apparently, 4 to 1 is better for top end power while 4 to 2 to 1 is better for low end. Does anyone know if this generalization holds true with our SC?
Ethan is offline   Reply With Quote
Old 11-13-2013, 02:59 PM   #2167
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Quick question---any luck with heat shielding on the bottom of the Sprintex manifold? Other aluminum manifold subies like it.
Subzero is offline   Reply With Quote
The Following User Says Thank You to Subzero For This Useful Post:
Calum (11-13-2013)
Old 11-13-2013, 09:52 PM   #2168
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
^This, I would be interested in as well.
Another thing I thought of when inspecting the manifold was a composite spacer to limit the heat transfer from the block. Although I don't think there is room under the stock hood, it could have been designed into the manifold.
So anyone willing to machine a composite spacer set and cut a hole in the hood?
Lawnik is offline   Reply With Quote
The Following User Says Thank You to Lawnik For This Useful Post:
KSpider (11-13-2013)
Old 11-13-2013, 10:09 PM   #2169
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Heat travels through aluminum at a crazy speed. And the worst kind of heat transfer is conduction. The manifold is bolted, with a large amount of surface area, directly to the heads. I don't care how much of a heat shield or blanket you use. It isn't going to help. Phenolic spacers might be a better option but without an intercooler you are still generating high temperatures from just compressing the air. The intercooler even looks like it might cool that cast insert which might even help cool the manifold. Long story short. Get the intercooler and make some good phenolic spacers. The charger already gives a "love bite" to the hood so I am not sure there is even room for a spacer.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 11-14-2013, 02:29 AM   #2170
EAGLE5
Dismember
EAGLE5's Avatar
With a 75mm pulley, how much clearance is there to the hood? A 70mm pulley will cut that by 2.5mm. Not a lot. How about the mythical 69mm pulley?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
