Old 10-31-2013, 04:44 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Suspension Weak Link?
I was at the suspension shop today having the rear camber altered and having a bit of a chat to the owner of the shop about some bent lower control arms that were sitting on the counter. (I didn't get around to asking what car they were from). I was told the owner had had an off track excursion, lost control and clipped the edge of the track going side ways bending the arms. I asked wouldn't stronger arms be the answer and was told fitting stronger arms would transfer the force somewhere else. Sure, all elementary but not something I had considered. (I don't know what I don't know). He said it was cheaper to replace the arms as opposed to potentially bending sub-frames or bodies.
Maybe something for consideration?
Calum (10-31-2013)
Old 10-31-2013, 09:48 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes this is an important engineering consideration
this is why i'm weary of super-stiff control arms. If they need to bend, and don't, something else will.
A properly engineered arm should have just enough stiffness to fight deflection generated by your grip levels, and let lose the moment it experiences anything greater.
full blown racecars generally have the attachement points made to shear off, so when you're fixing the thing you're just welding on the hookups and not having to straighten the whole frame.
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
CSG David (10-31-2013), wparsons (12-17-2013)
Old 10-31-2013, 10:23 AM   #3
J-W
J-W's Avatar
Drives: '13 Subaru BRZ Limited
I recently(over the weekend) bent an oem front control arm. The bend is visually noticeable. Weak points enginerred into a design is a good thing, but still, an oem arm is ~$250. At this time, there are no parts in the dealerships in the US, according to my local dealer. Add some adjustment points to that and the price alone is comparable to aftermarket options. I've decided to upgrade mine and be a little more careful in tight corners.
-Jay
J-W is offline   Reply With Quote
Old 10-31-2013, 10:27 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
$250 is nothing compared to having to straighten a tweaked unibody...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Calum (10-31-2013), wparsons (12-17-2013)
Old 10-31-2013, 10:28 AM   #5
J-W
J-W's Avatar
True, that's why I'm going to be more careful. Curbs and 45 mph don't get along.
-Jay
Old 10-31-2013, 12:04 PM   #6
CSG David
CSG David's Avatar
Yup. A lot of guys who simply just street keep talking about control arm rigidity as if they are the suspension gurus. The arms bend because they are designed to bend during an impact. Obviously if you want to extract the very most out of your suspension, these control arms will be replaced by some nice pieces, but you're also trading it off for potential deflection in the chassis. The energy has to go somewhere...
The Following User Says Thank You to CSG David For This Useful Post:
Enraged21 (10-31-2013)
Old 12-17-2013, 01:12 PM   #7
mike156
Drives: EVO
A control arm that bends easily also means it can end up pushing the tire and inner fender area into the driver's compartment. This is why many organizations require a bar as part of the cage that will protect the driver's legs from just this happening. The OEM pieces are likely designed in a way to fail but in a predictable manner that controls where the tire goes and how energy is dispersed.
But so is the intake manifold, radiator, engine mounts, hood... EVERYTHING in a modern car is designed around crash safety to some degree.
mike156 is offline   Reply With Quote
AC weak at idle qoncept Issues | Warranty | Recalls / TSB 15 03-23-2014 04:49 PM
Stock brakes too weak? Alabang BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 111 09-13-2013 04:41 PM
Weak Japanese horn mit_peid Scion FR-S / Toyota 86 GT86 General Forum 29 06-13-2013 11:43 AM
weak paint on bumper 1strwdcar Cosmetic Modification (Interior/Exterior/Lighting) 6 08-15-2012 09:19 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
