Old 01-21-2013, 12:26 AM   #1
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Weak Japanese horn
When I choose to buy my FRS, I accepted that this car does not have monster HP #s and just has a basic interior. There is one thing I have not heard or read people complaining about yet (sorry haven't tried to search it). When I was on the 10 freeway yesterday this big Chevy Tahoe started to drift into my lane when I decided to let him know I was there with a honk of my horn. This was the first time using or even testing out the FRS horn. What came out was outright embarrassing, sounded like a clown car.
Does anybody have experience upgrading their horn? I want one that is LOUD! https://shop.bostonmotorsports.com/H...Kit_p_573.html
mit_peid is offline   Reply With Quote
Old 01-21-2013, 12:31 AM   #2
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
its not all japanese car horn sound *****ish. my altima coupe has a nice strong horn but the corolla has those little girl horn. i think its the class of car that matters which horn the manufacturer install.
let me know if u can upgrade horn. maybe install those train horn?
chenshuo is offline   Reply With Quote
Old 01-21-2013, 12:35 AM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
Oh wait there already is another thread on this: http://www.ft86club.com/forums/showt...ella+supertone
Old 01-21-2013, 12:42 AM   #4
CTB727
Drives: 2013 Subaru BRZ
My previous car ('99 Toyota Avalon) had a mean, intimidating horn. It really got people's attention quick. I hate the horn in the BRZ so much that I hesitate using it because of how weak it sounds
CTB727 is offline   Reply With Quote
Old 01-21-2013, 01:59 AM   #5
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Lol. I had the same reaction when using my FRS horn for the first time, I wanted to drive away quick and hide.
EK_Golfer is offline   Reply With Quote
Old 01-21-2013, 02:38 AM   #6
mangostick
Drives: whiteout FRS
I just put a pair on tonight.. its 230am though.. and GF is sound asleep lol.. cant exactly test 118DB worth of horn(s) atm. I previously had them on my wrx though and they were plenty loud. I'm assuming they will be no different on the FRS.
mangostick is offline   Reply With Quote
Old 01-21-2013, 02:58 AM   #7
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
A train horn will wake up sleeping tahoe drivers. You might have to remove some of the less important bits from the engine bay to make it fit though.
campy is offline   Reply With Quote
Old 01-21-2013, 09:55 AM   #8
mit_peid
Boosted Noob
mit_peid's Avatar
Sounds like you had prior experience installing this thing on the WRX. The DIY on this forum actually seem pretty involved. How long did it take for the install on your FRS? A full day? Did you have to remove the bumper?
Old 01-21-2013, 10:18 AM   #9
FRiSson
Drives: FR-S MT
The horn has to fit the car, otherwise you just sound like a poser. However, the guy who put the Supertones on his car got a sound that was loud, but about right for the car.
FRiSson is offline   Reply With Quote
Old 01-21-2013, 10:27 AM   #10
mangostick
You do have to remove the bumper.. which in itself is a job n half. They used a ton of fasteners. Also a good thing to remember is this assembly is designed to be assembled, not the other way around, so its a bit tedious to do it right without breaking anything. The side markers are pretty interesting. There's diy's on here if you search. There's one that displays a way to get the bumper off without removing the marker lights.. that worked quite well. Once the bumper was off I used a small pick to slowly and carefully wedge the metal clips for the marker lights from behind and they pop right out. Going back in is a matter of just putting bulb in, lining them up and pushing them in. No broken metal tabs makes for a good re-install.
The Relay style install was pretty easy but I did set up the harness and relay on a previous car. Relays are pretty easy to wire up and only require 4 connections. One for trigger (factory horn wire) one to ground the relay itself, one is power from the battery and the other is the lead that will power the horns. Deeper descriptions of relaying wiring can be found on www.the12volt.com .
Granted, it wasn't NEEDED for the FRS but since I already had it ready to go and it allowed me to not cut any wiring (leaving ability to go back to factory later if need be) I chose to go this route. I also used a relay socket from parts express ( www.partsexpress.com ) that makes it easier to wire and if the relay needs replacement later its as simple as removing the old and plugging in a new.
Time wise, took me about a hour n half of actual work taking my sweet old time. Most of that was removing the bumper, the rest was making sure everything was neat and bundled correctly (loose wires make fires). Mounting was pretty simple.. I used the factory high tone horn bracket and grounded to the horns to their mounting point similar to the install detailed above. Here are some pics.
No wires showing, I made sure to run the power wire in tight with the factory harness and keep it under the factory terminal cover.
lol.. that's funny, cuz I'd much rather sound like a poser than have some asshat drive into me while not paying attention. Weigh it.. poser with intact shiny car, or cool guy at body shop getting chevy stamp removed... I'd take the former vs latter all day every day.
Old 01-21-2013, 10:37 AM   #11
jmaryt
Drives: 2012 honda civic ex
unfortunately,most people view our cars as clown,or toy cars,so no surprise there. i have had people comment to me,that they would be frightened to even be a passenger in it! tons of people are safety conscious these days,so i can understand this!
jmaryt is offline   Reply With Quote
Old 01-21-2013, 10:40 AM   #12
jmaryt
i love train horns! actually they would be more appropriate on the tahoe!
make people think they was gettin' run over by a f**kin' train! ehe! he! he!
Old 01-21-2013, 10:41 AM   #13
mangostick
Tons of people are idiots these days too.. so, have to add that in accordingly and adjust fire to match. I'd take our "clown" car over any domestic lump of crap even if it was given to me. The FRS/BRZ are pretty safe cars regardless of size. Bigger is not safer, that's a huge misconception. Especially if the driver of bigger vehicle is texting, putting on her makeup, eating cereal and yelling at her little brats in the back while driving with her knee's...
Yes I've seen this!
Loud horns save lives. .. if not add some entertainment when the driver next to you just about shits themselves.
Old 01-21-2013, 10:46 AM   #14
jmaryt
you forgot to mention the "creeps" doin' the cell phone thing strapped to their heads in their f**kin' "excursions" pissin' along next to ya,not just the day dreamin' morons not paying attention! ehe! he! he!
Roof metal = embarrassingly weak? Dzeremijs BRZ First-Gen (2012+) — General Topics 94 10-17-2012 08:41 AM
Weak battery or bad alternator from factory? empower-auto Issues | Warranty | Recalls / TSB 2 09-21-2012 02:17 PM
weak paint on bumper 1strwdcar Cosmetic Modification (Interior/Exterior/Lighting) 6 08-15-2012 09:19 PM
driving in 1st weak/stuttering feeling deedz Scion FR-S / Toyota 86 GT86 General Forum 19 07-25-2012 06:33 PM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 05:15 AM
