Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-29-2013, 07:36 PM   #29
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by zombieite View Post
So someone does make a mount! Awesome!
However, I've gone far enough down the road of making one myself that I'm kind of looking forward to it. Additionally, I have already stripped one of the seat bolt heads even though I was using a proper splined socket. They are just too small in diameter for how much torque they were installed with. Rather than drill it out on my brand new car, I thought I'd look into the console idea again. I removed the trim thanks to this helpful video:
And now I've made a Lego prototype of what I'd like to machine. The plan is to make it out of 1/2" 6061 Aluminum plate. But I have no idea what I'm doing with regard to materials or machining, so feel free to advise. The shape has to be kept as simple as possible, because I'm new to machining. A shaped plate with holes in it should be do-able. I realize those screws are angled in weird ways, so I am planning to try to cut some angled holes in my piece instead of just trying to force the steel to bend too much.
http://www.flickr.com/photos/zombieite/10564382234/
If you're going centre console why not just this http://www.ft86club.com/forums/showthread.php?t=15588
There's already two bolts under the centre console liner.
nzer is offline   Reply With Quote
Old 10-29-2013, 07:44 PM   #30
zombieite
zombieite's Avatar
Drives: 2017 Limited Edition, manual
I saw that and liked it, but the Big Bend Open Road Race requires a 2.5 lb extinguisher which is too big for that space. It's also pretty heavy, so my setup will have 4 mount points instead of 2.
zombieite is offline   Reply With Quote
The Following User Says Thank You to zombieite For This Useful Post:
nzer (10-29-2013)
Old 11-06-2013, 01:56 PM   #31
zombieite
zombieite's Avatar
I moved this thread to the track forum. I have an updated prototype.
http://www.ft86club.com/forums/showthread.php?p=1316240
Old 06-02-2014, 01:21 PM   #32
existensil
existensil's Avatar
Drives: 2014 BRZ Limited
Sorry to revive an old thread, but how did you guys remove the bolts holding the passenger seat rails down? They appear to be E-TORX bolts and must have some thread locker on them as I was unable to break the seal.
My fire extinguisher (2.5lbs) won't fit in the center console so I built a custom brace to mount in front of the passenger seat and attach to the rail bolts.
Buying a breaker bar to try and get more leverage. Will that be enough? Currently using an 8mm socket, but figure I should get a proper E-TORX socket. Any idea what size the bolt is in E-TORX sizing?
existensil is offline   Reply With Quote
Old 06-12-2014, 04:56 AM   #33
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Make sure you use a eTORX socket, e10. As you'll most likely thread the nut if you use a normal socket.
Rumbaar is offline   Reply With Quote
Old 09-16-2016, 03:07 PM   #34
sickmint79
Drives: bmw
i ended up going the bracketeer route. great option!
https://www.pointmeby.com/2016/09/16...keteer-review/
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 04-18-2017, 01:40 PM   #35
ka-t_240
Bump!
Any new options or ideas?
I liked the look of the one, but links are dead.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
Scrappydoo (05-21-2017)
Old 05-03-2017, 09:24 PM   #36
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I have an aluminium bracket on the front seat bolts, its fucking annoying!
I am thinking of putting nutserts into the floor, then mounting it to them
Also, CAMS now say the bracket has to be mounted with high tensile bolts...
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 05-21-2017, 12:22 PM   #37
Purist
Purist's Avatar
Drives: Subaru BRZ
Made an aluminium plate that bolts in using the original center console bolt holes. Extinguisher bracket mounts to the plate. Very securely bolted in and has passed scrutineering. Looking at it I'm sure it was designed deliberately.
Purist is offline   Reply With Quote
Old 05-21-2017, 05:15 PM   #38
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by ka-t_240 View Post
Bump!
I think Speedtech went into liquidation last year. Perhaps someone from NZ can confirm?
Scrappydoo is offline   Reply With Quote
Found the perfect spot for an extinguisher RazBRZ Cosmetic Modification (Interior/Exterior/Lighting) 30 04-04-2017 10:17 PM
Fire extinguisher install ICantAffordAnLFA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-18-2012 06:37 PM
Lachute performance has been damaged by fire on the night of August 20 Cotnoir Off-Topic Lounge [WARNING: NO POLITICS] 1 08-22-2012 09:23 AM
Radiator Mounting and Cap SupremeGunman Engine, Exhaust, Transmission 7 04-30-2012 05:16 PM
where are you mounting your plates??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 28 01-31-2012 04:41 AM
