Old 04-25-2012, 12:30 PM   #1
SupremeGunman
Drives: 1989 Camry, 1993 Legacy
Radiator Mounting and Cap
I was wondering if anyone could explain what i'm seeing in the engine bay.
The radiator cap on the left side of the image looks like it's not actually connected to the radiator. Instead it's built on to a piece of hard piping connected on both sides with soft piping. One side heads off to the engine and the other im guessing goes down to the radiator?
I can't say i've seen the engines in many newer cars, but having the radiator cap not actually on the radiator is a first. Although it helps move the radiator out of the bay, seems like it will be a pain to replace the radiator... which I had to do to my car recently.
Cropped image attached. Full size here:
http://www.scion.com/images/cars/frs..._engineBay.jpg
SupremeGunman is offline   Reply With Quote
Old 04-28-2012, 05:40 AM   #2
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Its a remote radiator filler cap. The radiator is tucked away in the engine bay and otherwise inaccessible if the rad cap were mounted directly to it. Ive seen it tons of modded cars, but I cant say Ive seen on a production car.
To swap the radiator, from the limited time Ive had in the engine bay and looking at pics, its probably easiest to remove the bumper to R&R the radiator - which shouldnt be incredibly difficult.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-30-2012, 12:13 PM   #3
SupremeGunman
Ok, so I guess it's more annoying than normal, but necessary for styling and fitting everything in. Is this fairly normal now?
Old 04-30-2012, 01:32 PM   #4
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
There are a lot of other cars like BMW and Nissan, they have identical radiators and remote caps so I think this is the new design trend. I have replaced radiators on them and they are not too hard to do so don't worry !
AJ PwR is offline   Reply With Quote
Old 04-30-2012, 01:41 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
they started putting radiators where they need to be and not where the drivers would like them to be.. all they had to do was move the filler cap.. brilliant!
Old 04-30-2012, 03:05 PM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The radiator cap just needs to be at the highest point of the cooling system so you can burp air out easier.
Turbo Subarus have a secondary coolant tank on top of the engine so that after shutdown, coolant will continue to flow through the turbo (which is why turbo timers on Subarus are mostly a waste of money). But the early WRX didn't have a cap on the radiator, only on the secondary tank. Newer ones have two caps because it was cheaper to just produce one radiator for both turbo and non-non turbo engines.
Old 04-30-2012, 04:09 PM   #7
Sasquachulator
Pavement Grey
plus the radiator is tilted some degrees (not sure which way, towards or away from engine) so even if it was visible it may still be difficult to access it.
Old 04-30-2012, 05:16 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's on a number of production cars too. I've worked on a number of GMs (especially northstar caddys) with the same setup, except that they just put the cap on the resevior instead, but it's the same concept.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
License plate mounting options (update: photos added) Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 27 04-16-2012 03:21 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
where are you mounting your plates??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 28 01-31-2012 04:41 AM
