Old 10-26-2013, 01:40 PM   #43
xDanger_208x
xDanger_208x's Avatar
Drives:
I just received my shifter from BPS along with a rear tranny mount and shift springs. I installed the mount and springs last night and the car feels amazing! So much so that I'm considering sending the shifter back. I'm so happy with the way it feels now that I'm satisfied, and I could use the $200 towards go fast stuff.
Anyone else feel this way?
xDanger_208x is offline   Reply With Quote
Old 10-26-2013, 01:41 PM   #44
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
Originally Posted by James1990 View Post
I wish I would have read this before I ordered the BPS shifter earlier this week. Now I'm a little worried that my car that has no issues and I love driving will now be plagued with this rattle lol. I guess I'll install it without modifying it at all and see what happens. I'll update everyone once I have it installed and have driven it.
Install it..see what happens if it rattles send it back. Here in louisville ky there is a company called dynosty that will be selling one for 135.00. They r also a vendor on here. Your close enough you could just drive down and pick one up.
http://www.frsmod.com/products/shift...er-for-frs-brz
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 10-27-2013, 10:47 AM   #45
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I have this shifter but was also plagued with problems. Tons of rattling and the final "solution" was to heat shrink the shifter arm and then grease it up and install the reverse lockout. I've done this part 3 times and within a day or two the reverse lockout becomes so stiff you have to be ripped to get it in reverse. Once in reverse the lockout doesn't return to its standard position so when you're done reversing and are ready to put in first you just end up in reverse again.
I spent so much time emailing Mat to get no solutions at all that I gave up. I've spent more time than it's worth and now I need to spend some time in the garage to get this fixed once and for all. Maybe Kartboy is the solution because BPS isn't.
chadstyle is offline   Reply With Quote
Old 10-27-2013, 12:23 PM   #46
cnk
Drives: '13 DGM BRZ Limited
I actually swapped back from the modified parts to the original lockout without the heat shrink because I got tired of the lockout not going back down after coming out of reverse. Still get a muted rattle around 4k, but I don't want to spend another $200 on a different shifter and still have a rattle.
Sent from my SAMSUNG-SM-N900A using Tapatalk
The Following User Says Thank You to cnk For This Useful Post:
chadstyle (10-27-2013)
Old 10-27-2013, 12:34 PM   #47
chadstyle
chadstyle's Avatar
Glad it wasn't just me.. I spent $200+ on my WC Lathewerks knob and another $200 on BPS and I did all the supporting trans mounts and rear shift bushings so after $500+ in the shifter alone you can understand my frustrations. I have been able to silence the rattle for the most part but the reverse lockout is a safety issue and BPS should fix this for the early adopters. I haven't seen any posts by BPS lately so I doubt they care.
Old 10-27-2013, 12:38 PM   #48
xDanger_208x
Drives:
Well I guess my mind is made up. I'm sending the shifter back.
My $200 can be better spent elsewhere on the car, and I'm continually reading about shifter problems. The stock setup with bushings and springs is phenomenal! I'm not messing with a great thing.
Old 10-28-2013, 11:18 AM   #49
xDanger_208x
Drives:
Originally Posted by normancw View Post
Which tranny mount and springs did you get?
Mtec tranny springs and can't remember on the bushing. Huge difference though.
The Following User Says Thank You to xDanger_208x For This Useful Post:
normancw (10-28-2013)
Old 10-29-2013, 08:58 AM   #50
James1990
Drives: Scion FR-S
The shifter arrived last night and after looking at it I think that they might have changed the washers. I'll post pics tonight but my small washer looks slightly smaller than the first pics on the thread and the larger washer looks slightly larger and it's a some sort of hard rubber or plastic washer. I could be wrong though.
EDIT: I recieved an email from Sylvain at BPS after I asked him if my shifter was modifed in anyway recently. He said "You have the latest revision. Few are still having minor rattling issues due to the OEM linkage design. We are looking at this and will inform you of any changes."
James1990 is offline   Reply With Quote
Old 10-30-2013, 09:28 AM   #51
James1990
Drives: Scion FR-S
Installed the shifter last night.. Drove it through all six gears and redlined a few.. And guys.. NO RATTLE.. I think think their revised version does the trick. Least we hope so! I'll drive it some more today and see if it will do anything but the shifter feels great! Now a Flossy knob and I'm set.
Sent from my iPhone using Tapatalk - now Free
Old 11-10-2013, 11:21 PM   #52
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Just installed mine today (purchased back in August) and have the dreaded rattle. Thought it might be the updated version, but not sure.
Mine had a spring clip to go on the side next to the cotter pin. Their web instructions said not to re-intall the original little washer next to the pin...just put on the spring clip, and did not mention using any additional washers...so I didn't. Maybe I should have used the washer included in the kit, but their instructions were so vague I didn't know what it was for.
It does, however, look and feel great. Just doesn't sound great. Maybe the headers will drown it out!
cfordart is offline   Reply With Quote
Old 02-17-2014, 09:25 PM   #53
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I installed the BPS Short Shifter last weekend and have the rattle over 5k rpms. I got mine in January of 2014 so I dont know if this issue was ever fixed. Kinda sucks but it is a better feel. Might have to try some of the solutions that were discussed in this thread.
Shneegle is offline   Reply With Quote
Old 01-07-2016, 03:56 PM   #54
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Any updates on this? Anyone got the latest revision of the shifter that supposedly doesn't rattle?
Seems like every aftermarket short shifter is plagued by rattles. What gives?
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 01-07-2016, 06:42 PM   #55
_gt86_user
Inactive
Drives: .
There are 2 small o rings that slide on the pivot shaft, some shifters require one while others require 2, my Kartboy came with 2 and I only used one since there was one from my OEM shifter already on there, I get a tiny barely noticeable rattle if I'm at low rpms (2-2.5k) I think even the stock shifter did this, haven't had any issues or any strange noises ever.
Bottom line i think people over look those small o rings or maybe they just didn't receive them in the kit, but that's just based on what I've read on other threads.
_gt86_user is offline   Reply With Quote
Old 01-07-2016, 09:21 PM   #56
SHIFTEVO
Drives: Lightning Red
Originally Posted by GTB/ZR-1 View Post
Wonder if it'll get rid of the notchiness--let us know, thx.
Notchiness is the beauty of it! whyyyy
SHIFTEVO is offline   Reply With Quote
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 08:19 PM
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 08:02 PM
Short Shifter paulieblaze Engine, Exhaust, Transmission 33 01-20-2014 11:55 AM
For sale: RAZO GT Advance 340 Short Shift Knob Vicious LED Interior Parts (Incl. Lighting) 8 09-16-2013 06:23 PM
LT Short Antenna now available for the 86/FR-S/BRZ/GT-86 lordtakuban Exterior Parts - The Rest 1 07-25-2012 07:22 AM
