Old 10-16-2013, 10:15 PM   #15
Silverpike
popular among the JDM
Silverpike's Avatar
Drives: 2014 BRZ Limited
This is most likely your problem:
http://www.ft86club.com/forums/showthread.php?t=10986
Silverpike is offline   Reply With Quote
Old 10-16-2013, 10:22 PM   #16
Originally Posted by Silverpike View Post
Yep, I'd suspect the differential.
You might try changing the fluid in the differential and see if the sound goes away. Even if that's not it .... the fluid change may benifit the differential.....
Old 10-16-2013, 10:30 PM   #17
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
When you install a solid T tranny mount ie: Perrin or similar this sound is amplified 100% to note.
high pitched sound, whine
Engine high pitch sound Munki Engine, Exhaust, Transmission 8 10-15-2013 02:11 AM
Windows make loud clip sound when going up/down DarkestBuddha Issues | Warranty | Recalls / TSB 3 07-06-2013 07:42 PM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-17-2013 11:00 PM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 01:05 AM
SOUND LEVEL TO LOW!! Not loud enough Hbomb Electronics | Audio | NAV | Infotainment 24 12-21-2012 09:02 AM
