Old 06-30-2012, 01:01 PM   #1
Hbomb
Drives: Scion Fr-S
SOUND LEVEL TO LOW!! Not loud enough
Anyone else having problems with the low sound output with the base Pioneer? With my IPod plugged into the USB it's just not loud enough to Rock! Any suggestions or observations?
Hbomb is offline   Reply With Quote
Old 06-30-2012, 01:30 PM   #2
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
First check that the vehicle mode is set to FR-S and not tC. Then check to make sure that it isn't faded out to the rear (mine was a good 80%).
eriktherod is offline   Reply With Quote
Old 06-30-2012, 06:09 PM   #3
Dan86
Drives: Red Scion FR-S
I don't know how the USB audio works, but with bluetooth I know you must turn it up on your device.
Dan86 is offline   Reply With Quote
Old 06-30-2012, 06:35 PM   #4
My1FastFRS
Drives: 2013 Ultramarine Scion FRS
Might try turning up the devices volume, as said here, I had to turn up my phones volume to full to get it to sound right using bluetooth and pandora.
My1FastFRS is offline   Reply With Quote
Old 07-01-2012, 01:20 AM   #5
Mild2Wild
Drives: Firestorm FR-S
When using a device like an iPhone with bluetooth, often the best sound quality can be obtained by turning the device to 75-80% and then adjusting the volume on the stereo. This has always resulted in less distortion for me at least...
Mild2Wild is offline   Reply With Quote
Old 07-01-2012, 02:30 AM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I suggest messing with ALL the options.
1) Turn OFF the audio console.
- Press down the multiknob for options (I think it was hold down)
- Adjust the settings for TC to FR-S (I think all stereo headers are set to TC)
2) Turn ON the console
- Press the multiknob
- adjust treble, bass, fade, and the centering whatever its called option
^ lol
3) Set Aux device to 90% max audio for better audio quality
Old 07-01-2012, 12:19 PM   #7
Hbomb
Drives: Scion Fr-S
Thanks Folks. I'll go back and try all your suggestions. I did reset to FR-S.
Old 07-01-2012, 03:26 PM   #8
killa.sushi.robot
Drives: 12 Sienna Se, FR-S Asphalt 6MT
What i have found, is if i turn on BTA, i can adjust it before i start playing audio... Any else with a Droid RAZR able to do also? One i start playing audio, i cant adjust anymore...
killa.sushi.robot is offline   Reply With Quote
Old 07-02-2012, 12:39 AM   #9
Hbomb
Drives: Scion Fr-S
Fixed.
^ lol
I did as suggested. Main issue was the different sound options. I forgot which setting I changed it to but, the volume went up tremendously. Then I went into the settings and reset the bass and treble for a cleaner sound. Last, I changed the Fade to more front loaded sound. Big diff. Thanks!
Old 07-02-2012, 01:46 AM   #10
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Glad to hear this all worked out in your favor!
Old 07-02-2012, 02:25 PM   #11
Hbomb
Drives: Scion Fr-S
Thanks. Sounds great. Man, I love this car.
Old 07-05-2012, 03:21 AM   #12
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I forgot to mention that there is also a sub-w (I'm assuming its sub woofer) while the header is off.
Its stock set to OFF, try ON for an extra kick haha
Old 07-05-2012, 09:24 PM   #13
Hbomb
Drives: Scion Fr-S
I'll try the "Bass on". Thanks again
Old 07-17-2012, 08:35 AM   #14
Itsjustjoe
Itsjustjoe's Avatar
Drives: Whiteout FR-S
I have a Razr. I started playing with the bluetooth this morning and I couldn't adjust the volume on the head unit itself. I turned off the BTA, turned the head unit's volume up to where I like it, but when I turned it back to BTA, the volume was back down to where it was before I turned it up. I am going to mess with it more at lunch today - the volume level it was at this morning was way too soft. If I can't turn it up, the BTA will be a big disappointment.
Itsjustjoe is offline   Reply With Quote
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 54 12-09-2016 01:14 AM
Anyone heard any loud popping? Kimsey47 BRZ First-Gen (2012+) — General Topics 103 07-30-2013 09:27 PM
Break-in Period and Octane level MattM232 Scion FR-S / Toyota 86 GT86 General Forum 10 06-05-2012 11:00 PM
An entry level FR revival? aliphian Other Vehicles & General Automotive Discussions 9 11-14-2011 08:09 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
