Drives: BRZ limited GBS
Windows make loud clip sound when going up/down
When i roll the windows all the way down right after turning the car on, the drivers side window makes a pop/click sound from the top.
and when going up the window motor makes a low rumble sound. slightly slower then passenger side the passenger side window squeaks when all the way up. |
Drives: 2013 Whiteout FR-S AT
i just started hearing my driver side window squeak whenever i rolls up. I'm hoping it's just dirt on the window rubbing against the door?
Default User Title
Try lubricating the window seal with a little bit of silicon grease. I had the same issue and that helped.
Mine squeak when they are super-clean, as in anal-retentive clean, but mine squeak at the rubber seal on the lower part of the window.
| WORKS x FRS ABM Sound Clip | PANDA86 | Engine, Exhaust, Transmission | 1 | 04-09-2014 05:57 PM |
| TRD Exhaust Sound Clip | Purdue FR-S | Engine, Exhaust, Transmission | 10 | 03-30-2013 12:34 PM |
| Sound clip request | Hardrock4445 | Engine, Exhaust, Transmission | 6 | 02-19-2013 12:56 PM |
| SOUND LEVEL TO LOW!! Not loud enough | Hbomb | Electronics | Audio | NAV | Infotainment | 24 | 12-21-2012 09:02 AM |
| Sound clip for Invidia exhaust? | genometuning | Engine, Exhaust, Transmission | 13 | 09-28-2012 02:55 PM |
