Old 10-15-2013, 11:17 PM   #57
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
If I were you and had time time, I would drive to FBM or delicious.
consider Bob @Drift-Office , he's the master tuner for AVO for real....
If none of the drive up options works out, remote tune @FA20Club.com
Just my personal educated opinion.
Yeah, I was not sure that bob does remote tunes. I was actually just up in Seattle for business a few weeks back and almost stopped by his shop to check it out, but didnt really get the time.
One problem with driving the car....friggin cruise control!!!!!!!!! cant go over 69, ugh...Actually, i take that back. I could probably flash back to the AVO base tune. run 91 in my car and be good...Cruise control works on the other tunes. Plus wont have e-85 on most the drive anyways.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Sportsguy83 (10-15-2013)
Old 10-16-2013, 02:13 AM   #58
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
http://www.ecutek.com.au/ecu-tuning/...gnition-timing has good info.
I took a long look at the logs. Then again, I know nothing. Ignore this.
I would call the guy and have him send you a flash ASAP where he has scaled the ignition advance map way down, like 50% down, if not to 0%. I would assume that he can just enter a scaling value and press save, but he might have to actually adjust the map. Pretty much all your knocking seems to happen when that table is maxed at 10+. At half that, you might have a lot less knock, possibly none. KingTut is saying that you're possibly running rich much of the time, and the AFR is maxing out the sensor. When the injectors are working their hardest, you're getting the most knock, which supports what he says, but that's when you're running hardest too, so it makes sense for there to be knock then. Rich knock is, I have heard, the worst kind for your engine. Then again, that's all when the advance is way high too. Fix the advance.
I wouldn't be driving the car hard right now. If you do, I'd keep a really light throttle and low revs. Keep off boost. If you can open your wastegate and run without boost, I'd do so until you can get re-tuned. Then get a wideband and see what your fuel is actually doing.
And this, sirs, is why I sure as hell won't tune until I can log well and mod it myself. I will not be beholden to some tuner far away who has a booked schedule.
The Following User Says Thank You to EAGLE5 For This Useful Post:
whitefrs (10-16-2013)
Old 10-16-2013, 09:45 AM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you pull any data off your AEM Failsafe? Do you have the RPM hookup? I would like to see what your actual AFRs are during boost.
Old 10-16-2013, 11:11 AM   #60
gdrider77
gdrider77's Avatar
I do have the rpm hookup, and did pull the log. Not sure if you are looking for info, the log, screenshot, etc....
What i can say, is that on average the afr is around 10.6 most the time during boost. Lowest it ever went during that full log 3hr+ was a 9.4
Here is the .daq file from AEM if that helps.
http://d.pr/f/9gKH
Old 10-16-2013, 11:15 AM   #61
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
http://d.pr/f/9gKH
From personal experience, Anything under 10.5 is not good. Anytime I dip under 10, I get misfire CEL for being that rich. 10.6 is TOO rich.
I honestly sense your tuner is not a bad guy and hes doing as much as he can, but he honestly doesn't know yet hoe to tune this car. He might learn and be great, but he is not there yet and who knows when he will be.
Old 10-16-2013, 11:23 AM   #62
King Tut
NASA SpecE30 Racer
King Tut's Avatar
As I expected. Unless you are giving that data to your tuner, he might not realize you are running that rich since the scaling of the OEM AFR only reads down to 12 on your plots.
Old 10-16-2013, 11:29 AM   #63
gdrider77
gdrider77's Avatar
Correction.....9.24 was the lowest the afr has went...
Old 10-16-2013, 11:31 AM   #64
xjohnx
Grip>Slip
xjohnx's Avatar
http://d.pr/f/9gKH
Here's a screenshot from one of your runs showing RPM, PSI and AFR.
gdrider77 (10-16-2013)
Old 10-16-2013, 11:45 AM   #65
EAGLE5
Dismember
EAGLE5's Avatar
That's not good.
Old 10-16-2013, 11:58 AM   #66
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Ouch, peak of 15+ psi trailing down to 11 psi. What are you using for boost control?
Old 10-16-2013, 11:59 AM   #67
gdrider77
gdrider77's Avatar
Grimmspeed mbc....I have the grimmspeed ebcs installed, but tuner couldnt get it working, so he put in the mbc for a temp controller till he could figure out the ebcs...
Old 10-16-2013, 12:50 PM   #68
Sportsguy83
Drives: Limited BRZ
I'm doing the pressure test next week. I believe @gdrider77 already did leak test on the kit. I'm starting to think that the AVO turbo with anything over 13 psi it just can't keep up up top. I got new boost plots with shorter WG lines and new MBC and even though it does hold it better than before, (instead of just peaking and shooting straight to the floor it now holds 16 psi from 4K-5.5K) then it tapers down from 6-7.5k to about 11-12 psi.
All of this quest for a flatter boost curve has me also thinking and wondering if my WG is pre-loaded too tight and that is keeping the WG from being able to contorl boost more accurately up top. (Of course just a theory because my boost plots of 12 psi were very linear and I haven't touched the WG at all since).
Old 10-16-2013, 12:59 PM   #69
gdrider77
gdrider77's Avatar
Correct. I did pressure test for leaks, and found a major one on the turbo inlet. Fixed all that.
When i put my new actuator on, i played with the WG preload setting. In the end 3 halfturns seemed to be about the right preload...from what i could tell, might play with it a bit more though once i ge tthe tune figured out.
The Following 2 Users Say Thank You to gdrider77 For This Useful Post:
Sportsguy83 (10-16-2013), whitefrs (10-16-2013)
Old 10-19-2013, 02:48 PM   #70
gdrider77
gdrider77's Avatar
So i tried reflashing to an older tune. This was the original e-85 tune my tuner gave me. This has always ran the best. So thought i would give it a try again and see how it runs. Well runs great. CC still does not work, but thats another issue.
Lowered boost to about 10psi, will be pulling out the mbc and just running wastegate for some tests soon.
Knock is only occasional and its always a -1 or -2. Thats the most i ever get with this tune. Under all conditions. Also, on my AFR wideband. Pretty much around 11-10.6 on most full boost. A couple times dropped to a 9.6, but out of alot of pulls and time (60min) it was only around 10times?
Probably just run this tune for now till i can get it sorted out.
Can pull some logs and post those later.
Thoughts?
BC Racing Coilovers - Knock? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 12-09-2015 10:41 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
ca-fi knock off questions fionnsfrs Electronics | Audio | NAV | Infotainment 2 10-27-2013 01:47 PM
Active Knock sensor Fat Spider Engine, Exhaust, Transmission 13 07-14-2013 08:37 PM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
