Drives: Subaru BRZ Limited
Knock on e85 not a problem?
So pretty much title says it all. My tuner said that knock on e85 is nothing to worry about. I am a bit skeptical. My latest tune from him is getting occasional knock correction of -2 to -4.
Should I be concerned? Or is e85 really that much safer? Ecutek Data logs Last edited by gdrider77; 10-13-2013 at 11:09 AM. |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
With the extreme knock resistance of E85, I'd be concerned. I'd find a new tuner who understands that you can tune right past MBT without knock on E85 in most cars, so knock is certainly a problem.
| The Following User Says Thank You to Sellout For This Useful Post: | slicktop (10-13-2013) |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Knock is no bueno.
#4 | |
I Love custom Turbo kits
Drives: Limited BRZ
Even more, DISCARD that tuner after trying to sell you that Bullshit. Anyone more educated than me is more than welcomed to correct me.
| The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post: |
Dismember
Drives: 2013 Red Scion FR-S
E85 can knock like any other fuel. It can also destroy your engine the same way. I would be nervous. Is this an online tuner or an in-person tuner?
Drives: Whiteout FRS
I miss read this early...I thought you had 91 or 93 and knock and he was telling you to go to E85..If you are on E85 and knocking run away from that tuner fast...KNOCK IS KNOCK and KNOCK is BAD! or have him fix that shit
#7 | |
This experience is making me think that i should just politely ask for my money back and that i should give remote tuning a try... On a related note....the knock is not all the time, maybe once out of every 3-5 drives. I have been logging every second i drive in my car right now. Is that less of a concern, or is any knock bad? Just trying to understand the severity of the situation. I am guessing that constant knock under WOT is no good, but every once in a while? Please excuse the ignorance, as i am new to the tuning and FI /e-85 thing. |
#8 | |
Drives: Limited BRZ
Wanted to add, that the difference between constant knock and rare knock is the same as a slow painful death or a faster one, but both result in the same.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | gdrider77 (10-13-2013) |
#9 | |
So i am trying to give him the benefit of the doubt, but i am just getting to the point that i think it might be best to stop working with him and try remote tuning. My thought is, he took money for a tune ($850), a bit over 3 months ago. And has yet to finalize it. At this point i should be justified in demanding a resolution via a new complete tune, or a refund, or at least a partial refund. Just frustrated that its been close to 3 months and i have yet to get on a track, as i have not yet got a complete safe tune. And of course, now winter is coming and i will be driving my car even less. Ok....my rant is over. |
| The Following 2 Users Say Thank You to gdrider77 For This Useful Post: | aagun (10-13-2013), Sportsguy83 (10-13-2013) |
#10 |
Drives: 2013 Black FR-S
Is the sporadic knock correction always when you first enter WOT or when you first apply load on the engine? It could be tip in knock. I see knock every once in a while on 91 and it is always just tip in knock.
#11 | |
This is where it tends to happen most of the time, around 3800-4300 or so. |
#12 |
Drives: 2013 FRS Asphalt
I thought tip in knock is a big problem no?
2013 Scion FR-S AT Picked up 5/30/2012
#13 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
can someone graph this log
#14 |
Knock is things hitting against other things at thousands of revolutions per minute. Hundreds of miles per hour of aluminum hitting aluminum.
I'd venture out to say its bad either way. Your choice, I'll be selling my block soon so if you need another, lemme know.
| BC Racing Coilovers - Knock? | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 12-09-2015 10:41 PM |
| FR-S Rod knock | pozer | Issues | Warranty | Recalls / TSB | 95 | 11-03-2015 09:39 AM |
| ca-fi knock off questions | fionnsfrs | Electronics | Audio | NAV | Infotainment | 2 | 10-27-2013 01:47 PM |
| Active Knock sensor | Fat Spider | Engine, Exhaust, Transmission | 13 | 07-14-2013 08:37 PM |
| Would you rather buy knock off parts for your car? | EJ20 | Engine, Exhaust, Transmission | 63 | 11-02-2011 06:17 PM |
