Old 09-20-2013, 09:39 PM   #57
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by Kostamojen View Post
Well you do want coolant coming from where it just leaves the radiator, so coming from right near the water pump as its pumping is a good spot. But back there with the throttle, won't it be hot coolant?
Does it matter? Coolant should be constant around 190f at operating temp no? Oil would be happy to be heated up to that point faster and if the oil is hotter it would be cooling it off to keep the temperature constant? I honestly don't know what the temperature delta is between "fresh" coolant from the rad and heat saturated coolant going into the rad.
industrial is offline   Reply With Quote
Old 09-20-2013, 10:17 PM   #58
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by CHUMPC4R View Post
Since the factory coolant tubing looks to be fairly small from the pictures, what about re routing the coolant lines that feed the throttle body? Then you also be preventing the throttle body from being heated.
This is what AVO turbo uses to water cool the turbo. I also think water temp shouldn't be much higher the steady temps the coolant always keeps so I think this is a good idea.
Old 09-20-2013, 10:26 PM   #59
Trac Toy
Trac Toy's Avatar
Coolant is coolant, the "coolest" it gets is whatever the thermostat opens at... Otherwise it's always going to be cooler than the engine oil once everything is warmed up. I do like the idea of getting the oil up to operating temps a little quicker as well.
Do as you wish, Just figured it was an easy place to get a supply and return, just moving it from one location to another.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 09-21-2013, 01:40 AM   #60
ft_sjo
Drives: GT86
Dear @regal,
You are a silly sausage. Manufacturers have been using this type of heat exchanger for twenty years or more. They're a very low warranty item. I've never seen one fail, personally.
Yours sincerely,
Unicorn
The Following User Says Thank You to ft_sjo For This Useful Post:
Sportsguy83 (09-21-2013)
Old 09-21-2013, 01:56 AM   #61
Kostamojen
I'm open to anything This is an open idea thread of course!
I just spent a few minutes staring at the coolant lines on top of the engine...
The inlet coolant on the throttle comes from the heater hose, and the outlet goes into the crossover pipe. It might be good to splice it from the heater hose pipe side, but I'm not sure the piping is large enough... Its pretty small, I need measurements!
The Following User Says Thank You to Kostamojen For This Useful Post:
nokia7190 (09-27-2013)
Old 09-21-2013, 02:27 AM   #62
Kostamojen
Ok, here is the throttle and the coolant flow in general...
This was something else I saw that might be possible, turn this elbow into a T fitting and use that to send coolant to the cooler or as a feed back into the cooler if it comes from somewhere closer to the water pump.
Old 09-21-2013, 02:57 AM   #63
Sportsguy83
Drives: Limited BRZ
AVO replacement hose diameter is 5/16". Hope it helps!
Sent from my HTC One X using Tapatalk 4
The Following User Says Thank You to Sportsguy83 For This Useful Post:
mabviper (08-03-2021)
Old 09-21-2013, 03:02 AM   #64
Kostamojen
Need the oil cooler diameter now XD
Old 09-21-2013, 08:29 AM   #65
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
38mm 1.5" top & bottom radiator hoses
Brzzee is offline   Reply With Quote
Old 09-21-2013, 09:31 AM   #66
Kostamojen
Didn't need that... need the oil cooler pipes sizes.
Old 09-21-2013, 09:38 AM   #67
Shit Luck
Drives: red frs
any particular wrx year i need to be looking for at the yard?
Shit Luck is offline   Reply With Quote
Old 09-21-2013, 09:45 AM   #68
Mikem53
Drives: FR-S 6MT
Originally Posted by regal View Post
IMHO this is the ticket, someone also posted about an aftermarket coolant to oil cooler but it had oil line feeds.
What makes this so awesome is there is zero increase in a risk for a catastrophic oil leak (IMHO.)
And there will be no added pumping losses due to flow resistance from extra lines and oil cooler..
Mikem53 is offline   Reply With Quote
Old 09-21-2013, 10:11 AM   #69
Kostamojen
Any turbo model. The DIT one is better though because it has the spill tray on top.
Shit Luck (09-21-2013)
Old 09-21-2013, 02:58 PM   #70
Kostamojen
I keep forgetting there is a Forester XT in the garage thats perfect for getting measurements off of, LOL!
Anyway, the oil cooler coolant lines are 1/2"... MUCH larger than the throttle body coolant lines, so those are not an option :/
I need to find out the thread/size of that bolt hole on the water pump that might work for adding an extra coolant nipple thingy to.
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 06:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 07:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 09:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 08:45 PM
