Old 09-19-2013, 10:09 PM   #43
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Here is the thread on the oil laminova unit mentioned
http://www.ft86club.com/forums/showthread.php?p=1093643
Sent from my Nexus 7 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 09-19-2013, 10:27 PM   #44
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by Kostamojen View Post
That's why I think cuscos kit is a bad idea. No turbo subaru has used coolant routing like that for the oil coolers... its better to use coolant coming from the appropriate areas.
I agree getting this engine up to temperature faster is a big benefit.
My issue with air to oil coolers is pin-hole leaks, very easy to lose the oil in the engine. This should be a great alternative should we find an inexpensive means to route the coolant.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-19-2013, 11:27 PM   #45
nix
nix's Avatar
Drives: AVO BRZ
I was looking at this on my car and waited agesss for someone to give feedback on a turbo car. Getting a bit pissed off at the heat soak & management needed from my mocal air/oil cooler.
nix is offline   Reply With Quote
Old 09-19-2013, 11:32 PM   #46
ATSAaron
Drives: 2013 Raven FR-S
Originally Posted by ATSAaron View Post
What is the part number for the bolt?
Thanks,
Aaron
Please?
Aaron
ATSAaron is offline   Reply With Quote
Old 09-20-2013, 02:19 AM   #47
Kostamojen
Please?
Aaron
I didn't get it. I'll have to call my dealer again... But you don't have to wait for me to do that, you can do it yourself too you know :P
Old 09-20-2013, 03:19 AM   #48
Kostamojen
I wonder if one of these thermostat housings will fit on the fa20...
Old 09-20-2013, 09:12 AM   #49
xwd
The accessory belt driven water pump on the BRZ looks a lot different than the other models, I don't think there is room for the nipple part.
Old 09-20-2013, 09:42 AM   #50
regal
Got back last night from the JY with an oil cooler from a WRX, looks just like the new one. $50 with the bolt.
Mods:
Old 09-20-2013, 12:40 PM   #51
xwd
I completely forgot I had an extra one laying in the garage, anyone have the PN for the bolt?
Old 09-20-2013, 03:25 PM   #52
Kostamojen
21317aa070
Old 09-20-2013, 03:34 PM   #53
Kostamojen
I think you are right. I took a few more looks at the stock header location and that extra nipple would be right up against the header.
I think the best route will be the hole next to the heater hose and then T off the heater hose for the return line.
Old 09-20-2013, 04:22 PM   #54
Trac Toy
Trac Toy's Avatar
Since the factory coolant tubing looks to be fairly small from the pictures, what about re routing the coolant lines that feed the throttle body? Then you also be preventing the throttle body from being heated.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 09-20-2013, 04:43 PM   #55
Kostamojen
Well you do want coolant coming from where it just leaves the radiator, so coming from right near the water pump as its pumping is a good spot. But back there with the throttle, won't it be hot coolant?
Old 09-20-2013, 04:48 PM   #56
Kostamojen
Ya, don't think it will work...
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 06:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 07:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 09:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 08:45 PM
