Old 09-20-2013, 12:57 AM   #15
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
i have 17x9 et45 on factory bolts and have about the same clearance. im only getting .5 degrees of camber and wanted close to 1.5 in the front. was hoping to add 3mm spacers and max out crash bolts. im glad i read this thread because that would put me at et42 and it didnt fit for the op.
garfull is offline   Reply With Quote
Old 09-20-2013, 11:45 AM   #16
jeebus
might depend on what tires you have. The 245 rivals look kinda beefy to me.
Buy yeah, get some plates.
jeebus is offline   Reply With Quote
Old 09-20-2013, 12:39 PM   #17
bfrank1972
Drives: 2013 FR-S Argento
I was gonna say the same thing - the rivals might be exacerbating the issue.
Old 09-20-2013, 02:52 PM   #18
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
good thing i went with 35 instead of the 45 for rpf1's whew
bkblitzed is offline   Reply With Quote
Old 09-20-2013, 03:10 PM   #19
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
So it sounds like if you did want to go 17x9, it's better to go +35 huh?
Aznsky is offline   Reply With Quote
Old 09-20-2013, 04:29 PM   #20
jeebus
It seems that way. I'm pretty surprised that places like tirerack even sell 17x9 +45 for this platform.
Old 09-21-2013, 08:29 PM   #21
garfull
garfull's Avatar
So I decided to give it a try and have also confirmed that 17x9 et45 245/40 setup will rub with crash bolts even with a 3mm spacer.
However this setup will work with the factory 14mm bolt in place of the larger 16mm oem bolt. It cleared without spacers, but I added 3mm spacers just in case.
I also couldn't find any toyota or subaru dealer that had the oem 14mm shock bolt so I got some grade 8 9/16-20x2.5 bolts, washers and nut from the hardware store. The 9/16 bolt is a hair larger than 14mm but just fit. I'd prefer to get the oem bolt to match but it's a weekend and my alignment appt is Monday. Out here in CA, we don't get much corrosion so I didn't need the coated oem bolt.
The Following User Says Thank You to garfull For This Useful Post:
DAEMANO (10-08-2013)
Old 09-22-2013, 01:33 PM   #22
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Why not use the crash bolts to ad some positive camber back to the setup, to push the wheel away from the strut.(if the only negative camber you have is from lowering springs) Then use camber plates to properly get the camber you want without moving the wheel in. Cheaper then buying coilovers and safer then using wheel spacers.
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
Joe-G (03-16-2016)
Old 09-29-2013, 09:52 PM   #23
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
You should also take into account not every 245/40/17 has the same sidewall shape.
MPI_Jack is offline   Reply With Quote
Old 09-30-2013, 10:25 AM   #24
wparsons
wparsons's Avatar
+35 9" wheels will poke quite a bit, especially on stock springs and alignment.
flickr
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Camber bolts question AceNiNe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-14-2013 09:50 AM
RCE Yellow spring kit, should I get the camber bolts? jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-20-2013 07:36 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
