Old 07-19-2013, 11:00 PM   #1
jflogerzi
jflogerzi's Avatar
RCE Yellow spring kit, should I get the camber bolts?
I am only looking for a mild drop. Will be using stock rims for a while with 225 tires once I burn through the OEM ones. When I do buy aftermarket I am looking at 17x9 or 18x8 max. Will I need them. FT86Speedfactory has a basic kit for 300$ and then another one for 400 with front and rear camber adjustment.
Old 07-19-2013, 11:26 PM   #2
infinite012
Drives: 13 DGM BRZ Ltd
Get the Subaru/Scion crash bolts. Should cost around $20 for both bolts. That should give you enough negative camber up front.
I've got RCE Yellows with the Whiteline (SPC) camber bolts in front and my alignment came back with -1.2 camber in the front and -2.0 camber in the rear (no stock adjustment, so it is what it is).
infinite012 is offline   Reply With Quote
Old 07-20-2013, 01:31 AM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I paid $6 for both at my local suby dealer.
supramkivtt2jz is offline   Reply With Quote
Old 07-20-2013, 02:37 AM   #4
jflogerzi
jflogerzi's Avatar
Thanks. I will stick with the basic kit.
Old 07-20-2013, 07:36 AM   #5
invzabomaster
invzabomaster's Avatar
Part number please?
invzabomaster is offline   Reply With Quote
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Camber bolts question AceNiNe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-14-2013 09:50 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
