Drives: 2015 Mustang GT (on order)
17x9 +42 & 245/40 w/ RCE yellow and maxed camber bolts
DOES NOT FIT
I've read this fits from some, I've heard it doesn't from others, I've heard "maybe" from another camp. But for the record, it DOES NOT FIT in front, due to clearance with the front strut assembly. It is a very small amount of rub, but it is not something I would drive on. I have 3mm spacers on the way that should resolve this, but I figured I'd make a thread that is easy to find when searching.
Drives: Some rust bucket
@jeebus, I think those people were running the OEM bolts (i.e., 0 camber). Even at 0 camber, you're really close to the front spring perch. I wouldn't recommend it especially on 245 tires.
There are a couple of options. Run spacers at the front. Run aftermarket coilovers with smaller diameter springs/shocks. Run less camber. Run slimmer wheels/tires. I have OEM crash bolts with 17x7.5 +50 wheels on 215/45/17 tires and there's rubbing under high loads. If you're using OEM suspension with crash bolts, I'd personally use wheels with +42 or lower offset and no wider than 225 tires. |
Drives: BRZ Limited
For the record, this is how much clearance I have with op's exact setup using stock bolts.
#4 | |
I'm really hoping the 3mm spacers (should be here today) do the trick. Otherwise I guess I'll ditch the camber bolts and order some plates. Not really in the budget this week though...
Drives: Vortech Supercharged FR-S
Spacers
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
1337
Drives: 2013 BRZ WRB S/C
Yup, I coulda told you that, my wheels are the exact same offset and width. In fact the question has been answered a few times in the will it fit thread.
well...I did a little grinding on the spring seat and put 3mm spacers in. It "clears". Even with the bolts maxed out. It's pretty dang close though.
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
Any pics of how close? I want to order the same wheels you have eventually. Not interested in coilovers unless I can get super high quality ones.
here ya go. With the 3mm spacers and a tiny bit of grinding to the spring seat, there's about 3mm of clearance. Without the grinding, maybe 1.5mm...
#10 |
Drives: 2019 Mazda Miata RF
If this was a 17x8 rim, would there be more clearance? ie is the rim stretching the tire closer to the spring perch?
#11 |
I can def see where it would rub under hard cornering with some tire deflection. How do you like the Titan's?
#12 | |
LOVE LOVE LOVE the titans though. Light, cheap, look great IMO.
#13 |
Drives: 13 Whiteout
This is new news?
I still have my 5mm spacer from my +42 setup I had.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#14 |
It is new for tards like me.
| H&R Camber Bolts | deedz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 09-08-2013 09:00 PM |
| Camber bolts question | AceNiNe | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 08-14-2013 09:50 AM |
| RCE Yellow spring kit, should I get the camber bolts? | jflogerzi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-20-2013 07:36 AM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
